Question about Maytag Refrigerators
I have a Maytag refrig model MZD2669KEW. I am loosing power to my in the door ice and water dispencer. Power will go away, I then unplug power to the door unit for a couple of minutes. When I reconnect power it works for a while (from 15 min. to 15 days) and then goes out again.
  • billmaltbie Oct 16, 2008
    There is no problem with the electrical cord or its connections. The refrig works fine except for the in door ice and water dispensing panel.
    Genius:
  • 1,239 Answers
HI If the cord of the unit looks frayed, or if you see burn marks on the prongs of the plug or at the terminal screws -- on the terminal block, under the rear access panel of the unit -- the cord may be faulty. Test the cord with a VOM set to the RX1 scale
Posted on Oct 16, 2008
  • 1 more comment
  • ABHISHEK.C
    ABHISHEK.C Oct 19, 2008
    hi
    sorry sir i sent you a mislead information that i have to send to other customer your vote changed my ranking please change it please......................
  • ABHISHEK.C
    hi
  • ABHISHEK.C
    ABHISHEK.C Nov 10, 2008
    hi sorry for the solution please change the rating
Side by side ice maker won't stop letting ice out of dispencer unles you open freezer door
It sounds like a sticking actuator switch. the door light switch shuts off the auger motor when you open the door.
Aug 15, 2014 | Refrigerators
Front door drip
Inside the refrigerator there is a coil of clear tubing that goes to the water dispenser. Pinch off this line and then you can have ice once again
Jan 23, 2014 | Maytag MZD2669KEW Side by Side...
I am getting NO water out of dispenser. The ice works fine. It makes ice and dispences it. The only issue id the water. I have already replaced the 5 button control unit and this has not corrected the...
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . If the line is frozen in the door , pt # WR49X10173 , is the dispensor water line heater , which comes with installation instructions .
Nov 18, 2009 | General Electric GSH25JSXSS Stainless...
Burning smell coming from front door selection , compartment for ice and cold water .When lifting up grey pad area which you press to dispence the water and ice , behind is black and burnt
You have a clear and present fire hazard that should be looked at ASAP. Do not leave this appliance unattended and you should unplug it any time you are away from it until professional repair arrives.
Good Luck.
Aug 12, 2009 | Maytag Freezers
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Icemaker and water dispenser not working GE GSS25JFPA stopped working and i thought it was water filters (have not changed in 4 years changed the internal filter and a aux one in basement in line no...
generic troubleshooting video: http://gei.portals.streamos.com/cc/channel.php?emcid=1416&empid=4533&packageid=0000
as the video shows a kinked line may be the culprit. or
if your ice maker is making ice and it is your ice dispencer that is not working along with your water dispencer and when you press the dispencer button the light dims on the door. I would replace the main board. I experienced the same problem and the board fixed it This board is shared by many models and brands of fridges and the transformer goes bad from power surges this board powers the solenoid valves that open for your water
Apr 03, 2008 | Refrigerators
On electronic control panel and water/ice despensor the ice cube door keeps opening and closing and the buttons on the panel do not respond tempratures of fridg and freezer keep flashing. Tried unplugging...
you have a maytag ice and water in door 3 door refrig???? if so you needs a new high voltage board, its gone bad. locatdon back wall behind the refrig. only resolution is to replace the board..
Mar 16, 2008 | Refrigerators
Maytag mfd2561 water dispencer and ice maker issues
ther first refrig id have to see for better idea of problem but hte second with the flaps open and closing is going to need a high voltage board part num(12920710)---thats the part number i get wehn i look it up with the model MFI2568AEW. dont know where you got 12002608(that to is a h.v. board. which ever itssan easy enough repair to do yourself, its mounted on the rear of refrig and comes with programming instructions in the box
Mar 12, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Refrigerator
it has a bad main control board call maytag they will most likely repair it in warranty for you
Dec 09, 2007 | Maytag MFD2560HES Bottom Freezer French...
Maytag MFD2561HES
Texas, sounds like your water reservoir is frozen up. Remove your 2 cripser drawers, you will see the reservoir behind them. Take a hair dryer and go over the tank and tubing ends. See if the water starts flowing. I find a lot of frozen water reservoirs on these french door models. They have a insulation kit for them. Catriver.
Sep 29, 2007 | Maytag MFD2561HE Stainless Steel Bottom...
Refrigerators Logo
59 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
