Question about Fujitsu AMILO D-7820 Notebook
Rec'd flash of notice something failed Did not see flash long enough to identify
Now have "on" signal, battery and charger but will not close or turn on. Something is running but I can't tell what it is
I have replaced joystick, batteries, motors and the chair still losing lights will go about 1/4 mile and loses all green lights with in 1/2 mile loses all the yellow lights, drove on 1 flashing light for...
Janice check your charger it could not be charging the batteries. Now always charge your batteries overnight while you sleep When you get up lights on the charger should be red and green if they are red and yellow then the charger hasn't fully charged the batteries and overnight should be more than enough time to charge fully. This could indicate a bad battery remember new doesn't always mean good. Like they say always charge before use and this goes for new batteries too you need to charge new batteries nightly for 10-15 days before they start operating at 100%. If when you plug in the charger before bed and the lights are red and green then there is a problem with the charger or the batteries or the charger circuit Hope this helps you
May 23, 2011 | Spirit Activecare /wildcat Foldable Power...
Hi, At my dell 1525 the battery status led flashes 4x orange folowed by a blue flash a.s.o. The dell manual identifies the battery as the cause. But, except for this optical signalisation, the laptop works...
Dell Inspiron 1525 PC Notebook Hi,\r\nAt my dell 1525 the battery... Answer Hi, At my dell 1525 the battery status led flashes 4x orange folowed by a blue flash a.s.o. The dell... (More) Hi, At my dell 1525 the battery status led flashes 4x orange folowed by a blue flash a.s.o. The dell manual identifies the battery as the cause. But, except for this optical signalisation, the laptop works well, the battery is charging, the AC adaptor is working properly. What is happening? Stefan
Feb 19, 2010 | Dell Inspiron 1525 Notebook
2006 pt cruiser on drivers side rear turn signal
The turn signals flash depends on each and every bulb working correctly. When one bulb fails, you will notice a change in the flash frequency, as you describe.
Replace or repair the bulb that is not working, and you should be good to go.
Doc
Sep 14, 2009 | 2006 Chrysler PT Cruiser
My 6 month old Nuvi 760 turns on, but no signal
It is entirely possible you need a new battery. Use and abuse shortens the battery life. Starting the engine while GPS connected or overcharging on AC or PC.
If it fails to acquire on full charge or replaced battery then it has a damaged chip from the usage i stated above. Not warrantble either.
Jun 30, 2009 | Garmin Nuvi 660 GPS Receiver
Key signal
UNLESS YOU HAVE WARRANTY LEFT,IT'S UP TO YOU FOR REPAIR COST..THE WIRELESS CONTROL MODULE THAT CHECKS FOR THE PROPER KEY SIGNAL MAY HAVE FAILED OR YOUR KEY TRANSPONDER MAY BE DEFECTIVE..ANYTHING ELECTRONIC TODAY IS EXPENSIVE TO REPAIR
Jun 19, 2009 | 2006 Dodge Charger
Yesterday, when driving, I noticed that the device said i was receiving no signal, even though I was out on the interstate... I got frustrated and turned it off... I figured that it would give it ample...
The green light does not necessarily mean there is power to the unit or charging the battery. If the unit is more than 3-5 years old, you may have success with replacing the battery. If you have a power source with sufficient current output capabilities then you could try that with the battery removed.
Jun 16, 2009 | Tomtom GO 910 GPS Receiver
O/D Off Warning Light Flashing
this is typicaly caused by an internal fault. it is very likely that the o/d band has broken. a quality transmission shop can identify this quickly. it is very rare for anything other than internal fault of trans, but still possible
Jun 01, 2009 | 2003 Ford Windstar
Razr 3Vc freeze up
the phone firmware need to be reflash to correct this issue you will need to take the phone to a mobile service center to hvae this done.
Nov 23, 2008 | Motorola Mobility RAZR V3
Motorola Razr V3c freeze up
take the phone and have the firmware reflash to correct these issues
Nov 18, 2008 | Motorola Mobility RAZR V3
Ford Taurus Signal light failure
i can tell u this the multifuncion switch is in the steering colum signals,highbeam flash to pass and wipers chuck
Jul 09, 2008 | 1998 Ford Taurus
Fujitsu AMILO D-7820 Notebook Logo
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
