Question about Sega Dreamcast Console
Dreamcast just resets
When I play my dreamcast, it sometimes just resets in the middle of playing. I can play for a few minutes or about an hour or so and it would just reset to the Dreamcast screen you get when you first power on the system, I tried different power cords and different connector cables.
Runken is right about it being the power supply board, but don't go slapping it about like in the video as there is an easy and permanent fix. The power supply pins need to be cleaned and pushed slightly so they lean on the contacts in the plastic connector they slide into. The link below will help but it only shows a PAL/European DC and does not demonstrate the slight pin adjustment required, when you look at the pins and the connector it slides into, it will be come obvious which way you need to push them and how little you need to push them, don't go mad and snap them or bend them really far!
http://uk.youtube.com/watch?v=1VVGoha9BhY
Good luck and enjoy some DC gaming.
Posted on Nov 11, 2008
Hey man this is the best soloution
Posted on Oct 31, 2008
  • runken Oct 31, 2008
    that is the dreamcast power supply board are dirt so you can repair it with some tapping in the back on dreamcast for clean and joining the power supply cable that is easy also you can open up and clean the power supply board that are in the left side
My Dreamcast is able to play any game for a couple of minutes, then resets to the main title screen after a period of time (this varies from around 1-10 minutes), sometimes just showing a black screen. I...
Sounds like your dreamcast is getting cut of from its power, the dreamcast sometimes gets a build of of dirt around the power connector pins that supplies the entire unit with power, try this youtube guide here for cleaning http://www.youtube.com/watch?v=3rizeLEQyzs&feature=related you don't need to do the bending section of the pins. just clean them and the actually plastic socket section where the pins go in.
Regards,
Omeil
Nov 07, 2010 | Sega Dreamcast Console
It will freeze in the middle of game play a some games not play
I believe your device is overheating, you need to make sure that the Dreamcast is well ventilated, don't set it on a carpet or enclosure. BLow any dust from the unit, pull the Dreamcast out of whatever nook it is sitting in, and set it on a flat surface like a hard cover book, etc. See if your issues resolve themselves.
Apr 08, 2010 | Sega Dreamcast Console
Dreamcast wont read games more detailed problem
you need to replace the hdd[hard drive]
Jun 20, 2009 | Sega Dreamcast Console
When i am in the middle of playing a game on my Sega Dreamcast it will cut out on me sometimes and go to the Dreamcast menu,with the controller and music stuff in background and then it tries to reload the...
Your Dreamcast sounds like it's overheating.
I had the same thing, and the cooling fan was worn out and needed to be replaced. I did this, and now it works like a charm.
Apr 14, 2009 | Sega Dreamcast Console
Freezing problem with Games
The Dreamcast is no longer supported because it was to easy to copy the games, but there are still a loyal few who keep the scene alive. I have no idea how much you want to put into fixing the problem, but the only way to fix your problem is flashing the Dreamcast BIOS.
Modification 101:
http://www.youtube.com/watch?v=v7v8cEU1I50
The Dreamcast is basically a computer; with the right programming you can do anything; and having a Dreamcast Keyboard is nice.
Other links you should check out...
DreamChip and 4 in 1 Connector
Another Dreamcast Mod Chip
The Ultimate Dreamcast Survival Guide
Sega Dreamcast VGA Mod
Modified Dreamcast BIOS
www.dc-scene.net
Nov 27, 2008 | Sega Dreamcast Console
Dreamcast turned off when there's a disk in it
madarchod band kar de ......from ayush yadav lps lko
Apr 08, 2008 | Sega Dreamcast Console
Sega Dreamcast console problem
First off, NEVER store a game console on top of a subwoofer. It is like a giant magnet, and electronic devices do not handle magnetics. I don't think i've ever heard of a VGA box, Sega brand or not, killing a console. Millions use aftermarket AV cables and adaptors on all consoles without problem. I think it likely died from being on top of the sub. Relocate it and you should be fine. Running it for a few hours isnt likely either unless you had the vents entirely blocked.
To the guest who's drive isnt spinning, I would say your drive motor has burnt out. This doesn't indicate a defect in Dreamcasts, per se, it just means bad luck or excessive dust which killed it. Either buy a different Dreamcast or see if you can find a drive replacement.
Hope this helps.
Feb 28, 2008 | Sega Dreamcast Console
My dreamcast randomly resets itself!
Its been a while since i've owned a dreamcast.My suggestion wouild be to make sure the parts on the inside are clean.Game consoles are known to collect a lot of dust over a long period of time.I would wipe it down with acohol, since it drys fast and leaves no residue.Your reset button might not be getting a connection.
Sep 20, 2007 | Sega Dreamcast Console
Dreamcast Randomly Resetting
this the best solution it work for me
Jun 11, 2007 | Sega Dreamcast Console
Sega Dreamcast Console Logo
440 people viewed this question
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Josh Whitehead
Josh Whitehead
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
