Question about Canon ZR500 Mini DV Digital Camcorder
Zr500 windows movie make will not reconise my canon zr 500
  • KLBERATIS Nov 15, 2008
    HI, I AM A REAL NOVICE BUT I HAVE READ MY INSTRUCTIONS AND CAN'T GET MY VIDEO TAPE ON A DISC...I HAVE THE OLDER MODEL ZR 200 MINI DVD CAMCORDER. THE INSTRUCTION CD WAS DOWNLOADED BUT CAN'T GET WINDOWS MOVIE TO FUNCTION. CAN YOU HELP ? K. BERATIS
  • Canon Master
  • 2,794 Answers
Windows Movie Maker doesn't recognize digital camcorders.    You need a program such as Pinncale Studio to do that.
Posted on Oct 16, 2008
SOURCE:
Cannot connect device to computer
ZR500 doesn't support windows 7 64bit. Your camcorder will say DV-in if plugged into any such input.
Jan 21, 2013 | Canon ZR500 Mini DV Digital Camcorder
My zr 500 will never do anything ....will not playback.....will not record .. not even take a CASSETTE ....AWFULL IS IT ?
Tape mechanism problems can be quite complicated. This will require disassembling the camera to repair and can be done fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Aug 27, 2011 | Canon ZR500 Mini DV Digital Camcorder
No power to Canon ZR500 I Have No Power g in Canon Camera ZR 500 it kind of new camera. There is no power going into it to run or charge the battery. The power supply CA-570 has output: DC of 8.4v and is...
This is usually caused by a failed component in the power circuit within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Jun 21, 2011 | Canon ZR500 Mini DV Digital Camcorder
Can get mt canon zr500 camcorder to get reccognized on my laptop.. i have windows vista on my laptop...i'm trying to transfer my mini dv tapes on my canon zr500 to my computer..what do i have to do?
You have to use a firewire connection in order to transfer your videos. The cambera will not transfer the videos through the usb ports. There is no specific driver for Vista, and this isn't a driver issue. Use your firewire port and cable, and you should be fine.
Good luck,and hope this helps.
Mar 19, 2011 | Canon ZR500 Mini DV Digital Camcorder
When i connect canon zr 500 cam, a message says "no driver installed" can u help
You need to have a Windows operating system later than Windows 98 Second Edition or a Mac with an OS later than 9. The driver for your camera is include with all later operating systems. Canon does not supply a separate driver for it.
There is software that can be downloaded from: ZR500 Downloads but it will not help without a driver installed.
Thanks for using Fixya.
Jan 13, 2010 | Canon ZR500 Mini DV Digital Camcorder
FireWire for camcorder mini dv
Go to this link. Click on "Frequently Asked Questions" and then click on the appropriate link (#4). Basically, once the firewire cable is connected, make sure that the camcorder is in the playback mode, is turned on, and you see "DV IN" on the LCD. If all that is happening, your computer/software should be able to "see" the camcorder and download the video.
Aug 21, 2009 | Canon ZR500 Mini DV Digital Camcorder
Canon ZR 500
you need to open a video capture program like windows movie maker to capture the video and audio or I have adobe premier pro 8.0 it will allow you to edit and add features and burn DVD's and render the movie and burn to DVD with special effects.
Jun 26, 2009 | Video Cameras
I need to import video from my canon zr500 to my pc
Hi, connect the cam and PC using 4 pin firewire cable. Switch on the cam. Open Windows Movie Maker and import the video from device.
Dec 28, 2008 | Canon ZR500 Mini DV Digital Camcorder
Zoom Lens Problem
Sorry there is something wrong with the mainboard when we get these at work thats usually what it is sometimes on the newer models the flex comes loose but not on this one if you have a warranty send it in if not its not worth fixing sorry
Dec 22, 2007 | Canon ZR500 Mini DV Digital Camcorder
Canon ZR 500 Problem
try turning your camera mode to the box with the "P" inside. Then, change the "EXP" all the way to -11. this should darken you surroundings and bring what you want to film into view
Apr 19, 2007 | Canon ZR500 Mini DV Digital Camcorder
Canon ZR500 Mini DV Digital Camcorder Logo
173 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
