Question about Dell Inspiron 1000 Notebook
Inspirion 1000 with XP won't come out of dormant phase. What is wrong ?
Three year old Inspirion1000 with XP won't come out of dormant phase.
  • Dell Master
  • 787 Answers
Unplug the computer.
Remove the battery.
Leave it for a few minutes - go for a coffee.
Put the battery back, plug it in and try it.
Posted on Oct 16, 2008
  • 352 Answers
Hi dj,
Reboot, at reboot look for the F button option to "enter setup", press F? button. Navigate to boot options, choose safe mode, save changes exit. When os comes up and is stable click start>all programs>accessories>system tools>system restore. Choose date before issue arises and click next/ok/continue. When restore is complete reboot, enter DOS enviroment(F button option "enter set up"), choose normal boot, save changes and exit.
What is the motor hp?
Please see below courtesy of
Electrical power is in general rated in watt (W) or horsepower (HP). A horsepower is a unit of power equal to 746 watts or 33000 lb ft per minute (or 550 lb ft per second).
A watt is equal to the power produced by a current of 1 amp across the potential difference of 1 volt. A watt is 1/746 of 1 horsepower.
Even if the watt is the base unit of electrical power, it is common to rate motor power in either horsepower or kilowatts.
Power in Watts
Direct Current Electric power supply to a direct current (DC) motor:
PkW = ?m U I / 1000 (1)
PkW = power (kW)
?m = motor efficiency
U = voltage (V)
I = current (A, amps)
Electric power supply to a alternating current (AC) motor:
Single Phase PkW = ?m U I PF / 1000 (1b)
PF = Power Factor
Two Phase Four Wire PkW = ?m 2 U I PF / 1000 (1c)
Three Phase PkW = ?m 1.73 U I PF / 1000 (1d)
Power in Horsepower
Horse power can be expressed as:
Php = PkW / 0.746 (2)
Php = (?m U I / 1000) / 0.746
= ?m U I / 746 (2b)
Php = horsepower (hp)
Feb 03, 2016 | Boating
I have Hobart D300 mixer which operates at 220V, 3phase supply and whereas the facility has 208V, single phase supply. Is there any recommended phase converters available for this product. Thanks
Hi Bill
I may be wrong here......
But I've been around Electricity for a long time.
Have Never seen a device that does phase conversion.
A Building site or home will either have Three Phase or Single Phase Power Available
BUT...A portable (Hired) generator could be "three phase" and you could use any one of those phases individually or all three phases.
I have 3 Phase supply to my house!
But I use 230 volt Single Phase for appliances.
My Bore Pump uses a 3 Phase Motor,
(so with a voltmeter it would read about 440 vAC to the pump motor).
Some Further Info:
A GENERATOR is basically a motor used the opposite way. Rotate a motor and it Generates.
The Phases refer to the THREE Windings in the supplying generator in your suburb.
A Large Magnet passes each winding in sequence giving you the three ripples in the supply.
Our houses can choose to have 1 Phase or Three Phases from the street when you set up your electric supply.
So... to confirm, look at the wires on the supply poles to the premises. Usually three in our area (Oz)
Most people are not aware that a car Alternator is actually three phase. The Rotor is the magnet that rotates.
The only difference with an Alternator is that each "Phase" is connected to 2 Diodes (6 total) to convert the three phase to DC to charge the vehicle.
The Regulator controls the voltage to the Rotor, thereby controlling the output.
So.... An Alternator could in theory supply 3 Phase in a mobile generator. Custom Made. Constant speed would determine the frequency of 50Hz or 60Hz.
Not sure what country you are in
Hope this Helps or gives you food for thought!
Three phase electric power
Jul 08, 2015 | Hobart Food Mixers
Live wire connection has 3 connectors for 3 phase. Do I put in all there bridges when connecting to single phase
Your question is not mate. What do you exactly want to do? If I understand that you have a single phase apparatus you wanted to connect it from a three phase box. If that is the case, then you have three options:
1. If the wires are new colour coded ones then you have to take your neutral wire from the blue wire and the live from any of the other three.
2- for old colour codes , take the neutral from the black wire and the live from any of the other three.
3- finally. Connect the neutral from the black or blue and the live from any of the other three red ones if the wires are in a conduit or trunking. I hope this answers your questions. Good luck
Jan 13, 2015 | Ovens
Changing motor
the three wires are all phase wires (it's a 3 phase motor), and must be wired in correct order. if you do it wrong, the motor simply will not work, and you can tell this very quickly, before damage is caused, and then change two of the wires and it will be correct. just wire it temporarily while testing.
Nov 06, 2013 | Haier Washing Machines
Three of my hobart mixers are spining wrong what is the problem
These must be 3 phase mixers (electrically there are two choices, single and three phase) Three phase cables typically have 4 wires, black, white, red and green (green is ground of course) To reverse the rotation of your mixers you would have to swap two of the three colors, and it doesn't matter which two of the three you choose, DO NOT SWAP THE GREEN, LEAVE IT ALONE. for example, just change red and black wires where it they connect to the plug. Of course turn off the power, unplug the the mixer, and usually you can take the plug apart and reverse the wires. If your units are hardwired you should call an electrician in to do it, it will only take a couple of minutes. cf652f29-33fe-4eee-8e37-1addfd1bcb1a.jpg aec28350-7e8b-4d45-a617-78e7a23dbf21.jpg
Sep 04, 2013 | Varimixer W20J Stand Mixer
We just bought a Mini Plus B31 coffeemaker and the cord will not plug into a standard three prong outlet. Other appliance cords do plug into the same outlets.
if you have a four pin plug, check that it is not three phase for heavy electrical use. ask your electrical supplier if your house has three phase, if your house had electric storage heating there is a chance it had three phase to balance the electrical supply to the property this can be dangerous so check please (some old boilers were two or three phase years ago)
Jan 18, 2012 | Dryers
DRYER: Switched a 3 prong to a 4 prong and heard a pop when pluged into the wall. I then noticed my hot and cold wire were mixed up. Fixed the switch and nothing works now. Breaker switched off and on many...
Hi - why did you convert the plugs in the first place? In elctricity theres no such term as hot or cold wires. Besides what do you mean by a 4 prong or 3 prong? electrical equipments are designed to operate on 3 pin single phase power or a 4/5 pin three phase systems.
the voltages in both systems are totally different pending on where you live - 110v or 230v for a single phase or 230v - 415v three phases.
A single phase cannot be converted to the three phases or vise versa unless you use sophisticated electronics to do so. Unless you know what you are doing you can modify the 3 pin to opertae safely on a 4 pin by choosing the correct conductors in relation to the three wire conductors in the 3 pin plug.
The sad story for you is this will be a rather expensive lesson - I wont be surprise if the extra voltage has zapped some of the components in your machine.
Jul 09, 2011 | Dryers
How to connect the 3 phase power supply to a 3 phase synchronous motor with control panel
I assume you have 3 phase power where this is going? The panel has 3 legs, 2 are 110 volt and one is 208 volt, you will need a tester to find out which is which if it is not marked, the motor should have a map on it for the wires to attach to, they go the same way, two, 110 and one, 208, I hope this helps, There will be one wire for a ground or a solid wire separate from the unit.
Feb 13, 2010 | AO Smith Three Phase Swimming Pool Pump...
Microsoft wireless desktop 1000 keyboard problem
not being a smart alek but did you try changing the batteries? and if you did did you try a new set?
Jun 22, 2009 | Microsoft Wireless Optical Desktop 1000...
Dell Inspiron 1000 Notebook Logo
106 people viewed this question
Alun Cox
