Running windows xp media center edition and when displaying "All Programs" the programs are listed in order of installation, as expected. However, when right clicking on the "All Programs" menu, the pop-up menu that should appear flashes very briefly and then disappears, thus "Sorting by Name" is not available. Suggestions.
  • mtGrizly Oct 16, 2008
    I found the solution by right clicking the task bar, select "Properties", click the "Start Menu" tab, click the "Customize" button, select the "Advanced" tab and finally check the "Enable dragging and dropping" option. Although I do not remember unchecking this option in my system, it was. Selecting this option will enable the "All Programs" right click pop-up menu.
    I may try the Style XP suggestion. It sounds interesting. Thanks.
  • 103 Answers
Hi
Try downloading style XP to modify the behavior of your taskbar...Not only will you be able to do the sorting But you can even modify its appearance and transparency as well....
Posted on Oct 16, 2008
Windows media player won't work
Which operating system ? Which version of Media player ?
Though designed with Windows 7 in mind, Windows Media Player 11 (WMP 11) is fully compatible with Windows XP.
The trick is knowing which version of WMP 11 to download.
Different versions of the software exist not only for Windows 7, Vista, and XP, but also for both 32-bit and 64-bit Windows XP.
Additionally, WMP 11 is only compatible with XP if it is using Service Pack 2 or Service Pack 3. Before downloading the appropriate installation file, you will need to verify which version your system requires.
Open the "Start" menu.
Open "My Computer."
Click "Help", then select "About Windows."
This will display a window with system information.
Find the listing that specifies your Service Pack. If you are operating without Service Pack 2 or 3, you will need to install one (see Resources).
Open the "Start" menu and click "Run." Within the text field, type "winmsd.exe."
Click "OK." Select "System Summary."
Find the heading labeled "Item."
Under this heading should be the word "Processor."
The value associated with "Processor" will determine which version of Windows XP you are running.
If the value begins with "x86," you are running a 32-bit version.
If it begins with "ia64" or "AMD64," then you are running a 64-bit version.
Download the Windows Media Player installation file that matches your version of Windows (see Below).
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
Open the file once it has finished downloading.
This will launch the installation wizard.
Follow the onscreen instructions to install WMP 11.
The program should now run normally.
How to Fix Windows Media Center
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display.
The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall."
Click to check "Media Center Extenders."
Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup."
Click on "Set Up Your Speakers."
Follow the on-screen prompts to reconfigure your speakers.
Dec 01, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
No sound drivers on Compaq Presario M2000?
i can install it online if you want contact me
Jan 07, 2012 | Compaq Presario M2000 Notebook
I have Mavis Beacon teaches typing cd and I am trying to install it on windows 7 but it wont install i can only read the manual that adobe lets me, my questions is how do i download the program to windows...
What version of the typing program do you have? You have a few choices, depending on what OS runs the version you have.
If the program ran under Vista or XP (version 20 lists Vista compatibility), the compatibility mode is likely to work. For this, right click on the installer. Then choose Properties and then the Compatibility tab. Turn on Run program as Compatible with the appropriate OS. Then right click again on the installer and choose Run as Administrator. Then check if the program itself is running in the compatibility mode by right clicking again and choosing Properties.
If the compatibility mode doesn't work (for older versions of the software), you can use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software on the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them.
Your final option is to upgrade to the current version. The 25th Anniversary edition runs under Windows 7. Other editions are not listed as compatible at the Broderbund site. You can try the Microsoft Windows 7 Compatibility Center for more information on tested software. My ISP is slow to connect to the site.
I hope this helps.
Apr 13, 2011 | Broderbund Computers & Internet
Windows XP, error message!! Media Center TV don't work now, etc.. Error message pops up all the time!!! After I loaded a RipTiger software, had to unistall but still left with this pop up message!!! Media...
Try going into Control Panel, Add/Remove Programs, click on the Media Center software, if listed, and see if it gives a choice to Change and/or Repair. You'll probably need your Windows CD if/when it prompts for it.
Oct 28, 2009 | Microsoft Windows XP Media Center Edition...
Add/remove list
Download CCleaner,from here:
http://www.filehippo.com/download_ccleaner/
the link is on the top right in the green area...
Install, Run.... Click on tools on the left, and there you are your add/remove programs can be deleted from there...
Have a nice day!
Dec 24, 2008 | Microsoft Windows XP Media Center Edition...
Xbox 360-computer?
To connect the Xbox 360 console to this computer, you must be running Windows XP Service Pack 2, Update Rollup 2 for Windows XP Media Center Edition 2005, or Windows Vista.
To obtain your setup package or instructions for connecting your Xbox 360, select the version of Windows installed on this computer from the following list.
To determine the version of Windows XP Media Center Edition that you are running, follow these steps:
  1. Start Media Center.
  2. On the Settings menu, click General.
  3. Scroll down, and then click About Media Center.
  4. Click Software Version
    The version number of Media Center you are running is displayed.
To determine the version of Windows XP that you are running, follow these steps:
  1. On the Start menu, right-click My Computer, and then click Properties.
  2. On the General tab, under System, look for the version of Windows that you are running.
Oct 05, 2008 | Microsoft Xbox 360 Console
Programs missing from add/remove list
Once you have the "Add or Remove Programs" window open look at the left side and make sure you have "Change or Remove Programs" selected. Also make sure you have the checkbox ticked that says "Show Updates".
As for the other programs in the list without the chage / remove option. You need to first click on the progam in the list to show that option.
Jul 10, 2008 | Microsoft Windows XP Home Edition
Windows XP Unusually Slow Startup
from msconfig you disable all startup item and restart.Also you defragment your hard drive once in a month and use a good antiviruse and scan your pc at regular interval
Jun 23, 2008 | Microsoft Windows XP Professional
Antivirus2008
You can uninstall the software by following this :
Start-control panel-add/remove programs
All the installd programs will be listed.
Just select which you want to remove & click on remove.
Wait it will uninstall the software.
Restart the system.
Good Luck.
Live, Love, Laugh.
May 10, 2008 | Microsoft Windows XP Media Center Edition...
Problem installing all programs
soudns liek bad windows i would boot into cd do a repiar or redo it all
Feb 03, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
