Question about GE GDS18LBR Bottom Freezer Refrigerator
How do you access the evaporator fan on a GE model GDS18LBR refriderator?
I need to replace the evap fan as the fridge is not getting cold and the fan was making a lot of noise before finally stopping altogether. Can't figure out how to access it.
Thanks,
Dennis
    Problem Solver:
  • 5 Answers
Your fan is probably not the problem, most-likely the problem stems from a design flaw in GE fridges. Access the evaporator fan through the bottom of the fridge by removing the bottom drawers, the floor and insulation of the fridge and de-ice the area around the fan by using a hair drier and hot water. After completing this you will then want to move to the back of the fridge where you will remove the metal insulated cover covering the upper drain section of the water drainage system. This will expose a snake-like section of tubing, this is where the underlying problem stems from. Remove this section and clean it out with warm water, a turkey baster can make this a little easier. If you notice that the blockage was caused by a build up of dirt and mould then re-install the section of line and replace the insulated metal cover. If the blockage seems to be caused by a ice build up, then re-install the section of line and do not re-install the insulated cover, this will prevent this section from getting too cold and causing a blockage.
Posted on May 22, 2011
  • 943 Answers
Hi the fan is located under the floor of the fridge 6 screws on the floor remove the floor remove foam . replace the motor. thanks the appliance doc
Posted on Oct 16, 2008
Where is the defrost heating element
Freezer side at the bottom and maybe middle of evap coil. Need to remove screws to access
Jan 20, 2013 | GE J Series 18.2 cu. ft. Top Freezer...
Freezer staying cold but fridge side is HOT
The Evaporator fan is not working. Located in the freezer above the evap coils is the circulating fan. Remove the cover to access the evap coils and circulating fan. If fan runs you have a defrost problem and the evap coils will be frozen over.
Nov 06, 2009 | Refrigerators
Fridge not cold, freezer on bottom works fine
you have defrost problem 1 timer defrostthermostart or heater
Jan 19, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
Maytag PBF 2255 HEW refrigerator Freezes up, won't defrost
To rule out the evap fan.
The evap fan should run all the time except when in the defrost mode.
Dec 27, 2008 | GE GDS18LBR Bottom Freezer Refrigerator
GE fridge GDS 18 LBR
Have u check the moisture control in the frezzer? If so make sure that all the vents are clear of all food and/or food containers and such... Turn ur fridge temp control to max.. Wait 5 hours WITHOUT opening fridge or freezer. Good luck! Let me know how everything tur out
Nov 10, 2008 | GE GDS18LBR Bottom Freezer Refrigerator
Evap fan not working
you must remove baqck panel from bottom of freezer compartment, there you can access fan and other freezer components, check for open defrost thermostat as well.
Mar 30, 2008 | GE GDS18LBR Bottom Freezer Refrigerator
Fridge stopped working
if freezer section is still cold yuo have either abad evaporator fan or a defrost issue, is the back of the freezer compartment frosty? if so look for defrost problem, (open defrost thermostat, open heater, or bad defrost timer.
Feb 04, 2008 | GE GDS18LBR Bottom Freezer Refrigerator
GE GDS18LBR Bottom Freezer Refrigerator Logo
737 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
