Question about Ricoh 6513 Copier
Asaad z.essa dear sir i have a ricoh 6513 with error code sc130 when started please help me
  • asaad_z14 Oct 17, 2008
    thank you for help me by this solution ,the sensor of the scaner is dirty,after clenning this sensor the copier is normaly operation
  • Ricoh Master
  • 2,794 Answers
Check to see if there is anything stopping the scanner unit from moving freely.  Usually it is cause by a loose screw in the path of the scanner.
Posted on Oct 16, 2008
Ricoh 6513 Error Code Sc.387 Error Code Sc.457 Error Code Sc.350
1. Set SP3-125-003 to a value of
2 to enable Job End & Non-use
3 Self Check Mode.
fore more hrlp visit https://cbrtechsolutions.net
Jan 21, 2011 | Ricoh 6513 Copier
All service codes for ricoh aficio 1075 are required urgently.
RICOH ERROR CODES
Error Code Description
SC184 CIS Transmission Error
SC191 Bar Code Scanning Error SC192 Automated SBU Adjustment Error/Bar
Code Number is Different SC193 Image Transfer Error/IDU Error
SC194 SBU White Level Detection Error SC195 DF Gate Assert Error/Serial Number Error
Error SC196 DF Gate Negate Error
Code Description
SC197 DF Gate Error SC101 Exposure Lamp Error
SC198 Memory Address Error SC107 Scanner Lamp Regulator Malfunction
SC199 DF Scanning Finish Error SC120 Scanner Home Position Error 1
SC201: Polygon Motor Error HP Sensor Abnormal-Stays Off
SC220 Laser Synchronization Detection Error SC121 Scanner Home Position Error 2
SC221 Scan Length Detection Error HP Sensor Abnormal-Stays On
SC230 BCU Received no Feedback from LD SC122 Scanner Home Position Error 3
F- Gate Error SC123 Scanner Home position Error 4
SC231 Laser Beam Feedback Signal Error SC124 Scanner Motor Encoder Signal Error
F- Gate Timeout SC125 Scanner Motor Speed Error 1
SC240 LD Power Supply Excessive SC126 Scanner Motor Speed Error 2
SC260 HP Sensor Error SC127 Scanner Motor Encoder Rotating Direction
SC261 HP Sensor Not Turning Off Error
SC285 Line Position Error SC128 Scanner Motor Start Error
SC300 Charge Corona Output Error 1 SC129 Scanner Motor Speed Control Error
SC301 Charge Corona Output Error 2 SC130 SBU defective Error/Scanner Start
Charge Current Leak Abnormal
SC302 Charge Corona Output Error 3 SC131 F-Gate Asserted During Shading
Grid Voltage Error Charge Roller Current Leak
SC142: White level detection error. SC303 Charge Corona Output Error 4
SC143 SBU Auto Adjust Error Grid Leak
SC144 SBU Connection Error Charge Cleaner Motor Error SC150 Scanner ROM Mismatch SC304 Charge Roller Current Correction Error SC170 Scanner DA1 Abnormal/Video Processing SC305 Charge Corona Wire Cleaner Error 1
Error 1 SC306 Charge Corona Wire Cleaner Error 2
SC171 Scanner DA2 Abnormal/Video Processing Charge Roller Home Position Error Error 2
SC310 Potential Sensor Calibration Error 1 SC172 Scanner DA3 Abnormal/Video Processing
SC311 Potential Sensor Calibration Error 2 Error 3
SC312 Potential Sensor Calibration Error 3 SC173 Scanner Lamp Regulator Adjustment Error
SC314 Potential Sensor Calibration Error 4 SC174 Scanner DA2 Abnormal
SC315 Potential Sensor Calibration Error 5 SC181 CIS Lamp Abnormal
SC316 Potential Sensor Calibration Error 6 SC183 CIS Auto Adjust Error
SC317 Potential Sensor Calibration Error 7
www.smilecopy.com
Aug 11, 2010 | Ricoh Aficio 450 Copier
My ricoh aficio 2232c was unplugged and when I plugged it back in it keeps saying Please Wait across the screen and doesn't do anything else. Please help
If no error code comes up then you have a hard drive error in your Print controller.
Remove the back cover (unplug machine) remove the cover for the controller (controller is in upper right on rear side of machine and disconnect the hard drive.) Plug machine back in and see if it comes to ready. if so replace the drive, if not controller is bad.
Jan 19, 2010 | Ricoh 6513 Copier
Ricoh aficio 6513 error code 422
this is a corona leak could be a broken or dirty corona wire
Jan 03, 2010 | Ricoh Office Equipment & Supplies
Ricoh aficio 6513 error 326
This is because the image transfer belt is dirty
Nov 26, 2009 | Cell Phones
Solution for "code 373 ricoh aficio color 6513"
Hello sir; the error code you display is toner senser problem, now the first thing you have to do is make a full color copy find out which color missing then pull out developer unit from missing color the senser right underneath, replace it.
May 23, 2009 | Ricoh 6513 Copier
Aficio 6513
the proplem solved by adjusting the the home position of the trans fare belt cleaning unit .
May 24, 2008 | Ricoh 6513 Copier
Ricoh 6513 error code PM CAll
Preventive maintenance.....
It's for a clean up, and sometime there's some parts to replace...
Apr 04, 2008 | Ricoh 6513 Copier
Minolta CF900 error code C0030
this is not a ricoh,, re code this issue as minolta nd you will get a ready answer...it is in the back of he usermanual
Nov 29, 2007 | Ricoh 6513 Copier
Ricoh 6513 Copier Logo
73 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
