Question about RCA Lands Phones
I have the RCA 25454RE1-A. It is a 4 line phone. I am only using 2 lines. When I am on the main line and receive a call it goes straight to my answering system. Line 2 does not ring. My previous phone did not have this problem.
SOURCE: Siemens Gigaset 2420 corded unit resets when calls received
OK, here's what happened. I had the same issue of the phone resetting when a call came in, I thought it was a power issue and through some testing it was not. Here's the fix...Menu \ system settings \ enter pin (if you haven't changed it it is 0000) scroll to factory default and reset. This fixed the problem somehow for me, make sure to write down any impotant messages because it will erase everyting (silly me). I hope this helps.
Posted on Jan 06, 2008
scanss2k
  • 166 Answers
SOURCE: answering call
Hopefully the user manual can help you
Right here
http://www142.nortelnetworks.com/bvdoc/norstarbcm/m7310-2.pdf
Posted on Aug 21, 2008
SOURCE: receiver dosen't pick up line that is ringing
go to programming section 5
You want Automatic Line Selection
Press feature00
left intercom button press twice (system program)
press right intercom once (central tel program)
enter # of extension to be programmed (intercom #)
press **
press line buttons in desired order line1 line 2 etc and
end with left intercom then press**
enter feature 00 to exit programming
Dave
Posted on Oct 17, 2008
consultel1
  • 860 Answers
SOURCE: Line can be answered, but the phone won't ring
Sounds like the extension needs to be programed to ring for incomming calls.
Programming2.gif is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming2.gif by pressing the feature key followed by **266344.
When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number.
Enter extension number you wish to program ringing on.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear only
press the Chng key till it says appear & ring
press next key (lower right arrow)continue with the remainder of the incoming lines that you have on your telephone
press the release key when finished
Posted on Oct 02, 2009
consultel1
  • 860 Answers
SOURCE: some 816 phones won't ring on incoming calls
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down, enter #20 the screen should say MMC DISABLED
enter in 1 2 3 4 1 # (that enables programming)
enter in #62 the screen should say day ring assn
press the line you wish to program
press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
press # when finished with the line
repeat steps 2 through 5 for the remainder of the lines you wish to change
press # when finished.
Posted on Jun 05, 2010
We have 4 RCA 25425 phones in our office. When someone calls, all phones ring. We only want main line to ring.
Page 15 of the manual shows how to turn individual phone ringers off using the "Ringer tone" setting option. RCA 25425RE1 User Manual Page 15 Hope this helps
Jan 10, 2014 | RCA 25425 / 25425RE1 4 Line Corded...
Can I hookup a Bose 901 EQ to my receiver and amp?
Your instincts are correct. In fact, the only way the 901's can live in an A/V system is with dedicated amplification.
Put that old amp back to work.
This is exactly how mine are connected.
For connection I would run a pair of RCA cables from the Front L&R Audio Line OUT to the Active EQ's Line IN; then the EQ's Line OUT to a separate amp's Line IN. Attach the 901's to the new amp, run through the receiver's setup procedures for volume, etc and you're done.
Aug 19, 2009 | Bose 901 VI Main / Stereo Speaker
What do I buy to use 2line phone and separate fax?
You can buy a 2 line phone, but to use the fax/dsl line for voice, you will also need a line sharing device.
"The stick" is a good brand....
All it does is recognize if an incoming call is a fax or a voice call. If fax it would go to a fax port on the stick. If voice, it comes out the voice port which you can call on.
The same rules apply to this line....if something is using it, the next call will get busy......But now you could have the phone company "Hunt" your line 1 to line 2 (fax/dsl) if line 1 is busy.......hence...2 incoming lines....
Apr 14, 2009 | RCA 25201RE1 Corded Phone
Need to connect phone and fax machine to one phone jack
You have the wrong adapter probably. Most common types are single line splitters and will not work like you want. They only split line one and 2 gets blocked out as they only have 2 copper connector on the plug centered to get line 1 only. If you want to use an adapter you will need a 2 line splitter like this one:http://www.trianglecables.com/tellinsplitl.html
A simpler solution is to plug your fax into your phone. On top of your phone are multiple jacks labeled L1/L2, L2 only or L2/data. Plug your phone into the wall using the L1/L2 jack then plug your fax into the L2 jack and this will work fine and still allow you use of line 2 on your phone. If you don't want to hear the ring then set your fax machine to auto answer. Hope this helps you.
Mar 29, 2009 | RCA 25201RE1 Corded Phone
Line 2 button light blinking, can't clear (and I have no line 2?)
Ok, i just figured this out a few min after posting the similar question. Reconnect your phone line to the data port and reselect the line one or line two selector swith position until the light goes out. I removed the phone from the wall to paint an must have accidently moved the switch. If the switch and the input port are out of sync you will get a red light on line one or two. Good luck!
Mar 13, 2009 | RCA ViSYS 2-Line Speakerphone
2 line phone rca 25205re1 only 1 line works not the rollover line
Most likely the problem is the cord from the wall to the phone. There are two types of cords and they look almost identical. Look closely at the connector. A single-line cord will have only two gold pin at each end. A two-line cord will have four gold pins at each end.
You need a two-line cord to get both lines from the wall to your phone. Since you have had the problem with several phones, that is the most likely cause.
Jan 14, 2009 | RCA 25205RE1 Phone
Problem receiving calls on fax line
Scroll through the MENUS and set your machine to MANUAL MODE, then you will have to push the START button to receive a fax.
Dec 09, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
RCA 25202 Default to Line 2
only when you have call foward from one line to the othe when in use. so lets say line 1 is in use then line 2 will ring but now line 1 is open and its ringing (activate forward ) and will go to line 2 and be able to be picked up.
Mar 07, 2008 | RCA 25202RE3 Corded Phone
Lands Phones Logo
35 people viewed this question
Top RCA Lands Phones Experts
David Burbee
David Burbee
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
