Question about Whirlpool MH6140XK Microwave Oven
Fuse keeps blowing.
My microwave is a Whirlpool, model #YMH6140XFB2 and I have replaced the properly fuse (20 amp). Yet, the fuse keeps blowing. I don't know if the fuse is the problem since it is a no name brand. Hopwever, the light turns on, fan turns on and display is on but only when I turn on the microwave it goes on for about 3 sec and then the fuse blows. I am thinking there is a short or malfunctioning mangetron. Does the magnetron need to be replaced?
Any input would be greatly appreciated.
  • 2,326 Answers
It appears like the high voltage capacitor is shorted or the diode connected to the capacitor. You might want to check the monitoring switch as well if the capacitor and diode are good.
Click here for more info on how to work around these high voltage devices.
Let me know if you need further assistance.
Posted on Oct 16, 2008
How do I fix a blown microwave fuse?
How to Fix a Microwave Oven - Simple Fuse Replacement ...
? 18:04
https://www.youtube.com/watch?v=IN0BqiVX5ds
May 21, 2013 - Uploaded by GuruBrew
How to Fix a Microwave Oven - Simple Fuse Replacement. GuruBrew .... I'm hoping it's just a blown fuse ...
Whirlpool Microwave Keeps Blowing Fuses - YouTube
? 2:35
https://www.youtube.com/watch?v=KGQgendKTR0
May 7, 2013 - Uploaded by AdamDIY
Whirlpool Microwave Keeps Blowing Fuses ... MicrowaveThermal Fuse Replacement - GE Microwave ...
Microwave Oven Repair 101 ' DoItYourself.com
Dec 06, 2015 | In Microwave Ovens
I have a whirlpool microwave model WMH31017AS1 it turns on but heat up is there anything i can do
All microwaves have a door open switch that keeps the magnetron from producing microwaves; this could be your problem. Most microwaves have a fuse hidden in the wiring that blows on overload like a lot of food spatter inside. They also have thermal overloads which may or may not self reset. If it died with a big flash you may be out of luck, if not you may be able to locate the fuse or thermal limit and replace it. Another sneaky part is a one time combination temperature and current overload called a thermal fuse:
51cl8ujqerl._sl1100_.jpgThese thermal fuses are marked in amperage and degrees Celsius and Amazon carries them.
Self resetting thermal overloads look like this Amazon # B00DM8JGQQ which is a Whirlpool part:
I didn't find a wiring diagram on line for your model, but you may be able to find one; whirlpool generally is pretty good with documentation. Most microwave manufacturers keep consumers as far from doing their own repairs due to the possible dangers involved.
Appliance Parts Store has a pretty good selection of replacement parts
WMH31017AS Parts
Jan 30, 2015 | Whirlpool Microwave Ovens
My Whirlpool microwave MT6120XEB-0 keeps blowing the fuse. Inststalled new fuse and display and timer works. Cooking blows new fuse. It turns on, makes grinding sound and blows a new fuse within a second...
You almost certainly have a shorted high voltage capacitor.
See the safety warnings and help information here.
Chances are you will have to remove the oven from the wall to replace it.
You can download Whirlpool owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 26, 2013 | Microwave Ovens
Whirlpool Microwave MH6700xW-0 Blows internal fuses regulary
Assuming your power line voltage is okay, it would not surprise me that after 27 years, your high voltage capacitor is drying out and increasing its capacitance. This will cause variance in the high voltage output, which can stress the magnetron and increase current consumption.
You can order Whirlpool parts my model number here.
http://tinyurl.com/gv383
For more free DIY and other help & advice, feel free to contact me via my site.
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 16, 2017 | Whirlpool Microwave Ovens
Microwave keeps blowing fuse
There are three possibilities, a bad magnetron, high voltage capacitor, and diode. In rare cases the high voltage transformer will be an issue but unlikely, if the microwave oven is more than 5 years old consideration should be given in replacement.
Nov 06, 2011 | Microwave Ovens
Does not heat
There is a slo-blow 20 amp fuse inside of the ac power panel. You will have to remove the front and locate the fuse inside. This fuse suplies the power to the Traveling Wave Tube that spplies the microwave energy.
Mar 08, 2011 | Whirlpool WMH1162XVS Microwave Oven
Viking Microwave Model VMOC205SS little over 4
9 amps is approx. correct. Does magnatron make an odd sound when running? If not, you will need to discharge cap then clean terminals with alcahol. Replace diode as well. Should run correctly.If blows again, replace magnatron. Suggest you put a 12 amp fast blow fuse in circuit and nor a 20 fuse.If you dont have a grill or an oven, use a 10 amp fuse.
Sep 17, 2009 | Viking VMOC205SS Microwave Oven
Microwave oven blowing 20 amp ceramic fuse
Chances are if the varistor fails, it fails drastically causing a short circuit across the supply. It will sit across the supply (it will look like a thick ceramic capacitor) and you can check for continuity after isolating that at one end. If it shows low resistance (it should show almost open circuit with a Digital meter), replace it.
It need not be the culprit. If you are familiar working with High voltage circuits ( they are lethal inside a microwave ovens as the current capability is high here), you can discharge the doubler capacitor and isolate the high voltage diode to check for shorts in the HT area.
Mar 18, 2009 | Microwave Ovens
Fuse keeps blowing.
couple questions -
what else is on the circuit,
and what current does the oven need
there are whirlpool over-range models with
1200watts of microwave,
1500watts of convection power, a
60watt bulb and a
375watt fan
over 15amps -20amp circuit needed
if you inadvertantly replaced a higher current fuse with a 15amp fuse, it will blow every time.
the install guide http://www.whirlpool.com/assets/pdfs/product/ZINSTALL/8206589.pdf reccommends 20amp
not a solution, something to check,
Oct 14, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave fuse keeps blowing
ckeck your door switches and h.v doides if you know how if do not get serviced by technician
Mar 21, 2008 | Microwave Ovens
Whirlpool MH6140XK Microwave Oven Logo
314 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
