Quad 405-2 just went bang when i switched - changed fuse but stayed dead
  • 4,234 Answers
The outputs are shorted. These are relatively simple designs. figure on about $25-$50 for the parts plus hte local labor rate for repair. I just did one of these recently. Nice units worth about $400+!!
Dan
Posted on Oct 16, 2008
I Ask a Mechanic to change Starter and now most light are dead.
i would say check all the fuses again, both in passenger compartment and under the hood. plus, the mechanic should be responsible for this issue. it also sounds like you battery is not fully charged. i would also suspect, the starter was changed without disconnecting the battery and something was shorted as he installed the starter. good luck
Sep 11, 2015 | 2000 Mazda MPV
Fire basically went bang I changed light bulbs and fuses but every time I plug it in it goes bang and trips the switch???
You have a short circuit in there. The bang is the short-time heavy current causing trip-out.
Jul 29, 2015 | Cars & Trucks
Have a yamaha quad has no spark.. dead at the plug
Sounds like its the coil. I had same problem with my pocket bike. Changed coil, first pull away she went
Jun 24, 2012 | RTO Mini Quads
My 405 diesel was running fine then I changed the battery to swop.\r\nThe newer battery which was running ok in another similar car was connected up in the 405 but the car is dead, no power to anything....
no you have forgotten to re connect a lead on the positive terminal ,i think their are three cables ,one big thick one and two smaller ones that supply power to the fuse supply under the bonnet
Nov 04, 2010 | 1991 Peugeot 405
Using my EOB5630 oven went bang
the fan element will have shorted out. if you remove the panel from inside the oven you may see where the circular fan has shorted. It will have blown a fuse poss in a plug if connected that way.or tripped a circuit breaker. remember to set the clock when power is restored as it wont work until you do.
Jul 29, 2010 | Electrolux EOB5630 Ultrafan Electric...
Engine banging going over pot holes ive changed the wishbones and suspention struts and it still bangs
by bang do you mean bang into the ground? if so you may need new shocks and or springs.
if you mean it bangs inside the engine compartment then you may want to inspect the motor mounts / stabilizer.
Apr 22, 2010 | 1991 Peugeot 405
Electric range heard a loud bang then it went dead
I WOULD DISCONECT THE POWER AND REMOVE THE BACK PANNELS AND LOOK FOR A SHORTED WIRE OR A BURN MARK ON THE BOARD. ALSO CHECK WHERE THE CORD ATACHES TO THE STOVE. GOOD LUCK!
ERIC
Jan 17, 2010 | Kitchen Ranges
Insignia ns-pdp50hd: power went dead, no standby
This could be your Power Supply Module or your Main board. I suggest taking it in for a diagnostic check.
Nov 17, 2009 | Televison & Video
Microwave fuse mystery
AHD_NZ
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
Guest
We're happy to help and we appreciate your thoughtful rating of our answer.
May 28, 2008 | Microwave Ovens
187 people viewed this question
 Grubhead
Grubhead
