Question about Dryers
Dryer not heating
My dryer (Maytag Performa PYE/G4500) stopped heating last night. I've tried all the different cycles and still no heat. Is it a coil or heating element? I have NO idea what these even are or where to get them to replace. Thanks!
  • 943 Answers
Hi thanks for the question. disconnect the dryer. remove the front 2 screws remove front. element is on the right in a cylinder check and replace. thanks the appliance doc
Posted on Oct 16, 2008
Ignition works but doesn't stay on long enough to heat dryer
its either the hi-limit switch is weak on the burner tube,or the gas valve coils on the gas valve are weak and can no longer keep the gas valve open to supply gas,if they appear warm after operation they are most likely bad
May 24, 2012 | Maytag Dryers
My dryer will not start when I push down on the dial. There is power to the dryer. When I turn the dial on to the timer, I can here the ticking sound, so the timer is working, but it wont start when I...
Maytag Performa Mod.PYET244AYW wont start has power door switch good thermo protection good at element cant fin any fuses timer has 120v and selecter switch
Oct 14, 2010 | Maytag Dryers
Maytag washer squeaks when spin cycle stops
We have a Maytag Performa G3300 that we bought on 8/13/2001. It still works great, but on 2/25/10 it stopped heating. We found that by removing the front panel and vacuuming the accumulated lint on the inside of the dryer and the door, the problem was resolved. There were no parts to replace, just vacuuming.
Jan 18, 2010 | Maytag Performa PAV2200
Maytag performa dryer suddenly stopped working, as if no power. i replaced both fuses and it worked. ran for about 15 mins and stopped again. any suggestions?
did it blow the fuses a second time.try this .put your dryer on a cycle that wont call for heat and turn it on.if the heat strips are not on and it still blows a fuse it is the motor.if the heat strips are on and it blows a fuse the heat strips are the trouble.
Nov 05, 2009 | Maytag Performa PAV2200
Dryer not heating as it should. Gets warm, but takes several cycles to dry clothes
Could be 2 things... either your heat source is out of repair or your vent is blocked. Since you say it only gets warm I'll assume the problem is with the gas coils inside the unit. These parts are replaceable
May 12, 2009 | Maytag Dryers
My maytag performa pye2300ayw dryer will start but will not heat up. No matter how long I leave it on, it just won't heat up. what could be the source of the problem? the model number - pye2300ayw rev - 10...
You have a thermal overload switch that may be bad. It is located under the top of the dryer. Check first the breakers. Turn them off and then back on, then check the wiring in the back of the dryer and then the element itself. It may take 30 minutes to do all of this, but it will save you a lot in the long run.
Mar 04, 2009 | Maytag Dryers
Need ohm readings for Maytag Performa Model PYE 3200AYW
Go to this site for info on your dryer type, you may find what you need there...
http://www.applianceaid.com/ww-and-mc.html
Jan 14, 2009 | Maytag PYE2300AY Electric Dryer
No heat from dryer.
Do not buy or use a maytag performa dryer model number pye2300ay at all. I fyou have one unplug it and take to the landfill or scrap yard. They are complete junk and nothing but a hassle. One problem after the other on this model no matter what you do. they are complete trash and a waste of your money.
Nov 24, 2008 | Maytag Performa PAV2200
Maytag performa dryer pye/g2200
hi .thanks for the question .no the element does not go bad a little at a time. but the venting gets clogged up a little at a time . remove the venting and clean to the outside wall . also if the dryer is noisy you could have a blower problem. if the dryer is noisy .but check the venting thanks the appliance doc
Oct 01, 2008 | Maytag PYE2300AY Electric Dryer
Dryers Logo
175 people viewed this question
Top Dryers Experts
