Question about HP Office Equipment & Supplies
HO 2710 All-In-One printer is extremely slow, both in printing and copying documents
    Sergeant:
  • 352 Answers
Hi awbridle, try updating your printer drivers, this may speed things up.
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done.
anaanymous
Posted on Oct 16, 2008
HP 2410 photosmart all in one, copies and prints extremely slow, it will eventually print the job but it might take 20 minutes, ant idea of the reason?
Probably you are printing very high quality images/documents. Try reducing the DPI's in the settings. That should help
Apr 09, 2010 | HP PSC 2410 All-In-One InkJet Printer
I get error codes 0x887ffd78 & 0x6b900004b when I attempt to print a document. -hp photosmart 2710 -wireless network
there something wrong with the installation of your software printer...
install again so that the error appear will not come back more
Oct 19, 2009 | HP Photosmart 2710 All-In-One InkJet...
Long (25 seconds) cleaning wait after each page
You may have a feature on that needs to be turned off or there is somthing that the printer companey needs to fix.
May 01, 2009 | Xerox Phaser 6350DT Laser Printer
Slow Printing
it may just be a slow printer head, maybe an upgrade is in order. look on the box for page printing speed.
it may also be that you have the resolution set too high for basic printing. try turning this down slightly.
hope this helps.
kev
Oct 03, 2008 | HP PSC 1350v All-In-One InkJet Printer
Extremely slow printing
below is the document that i want you to follow. Though, its a very long document, but surely it will resolve your issue.
CLICK HERE ==>> DOCUMENT
Please let me know the out come after you follow the steps.
thank you so much. i remain
adonscott
Jul 20, 2008 | HP Photosmart C5180 All-In-One InkJet...
Printer won't print word perfect doucments
try a different pint driver such as a pcl4or5e.
Apr 15, 2017 | Office Equipment & Supplies
HP 2710 Printer
Issue When using colored paper in the all-in-one, printing or copying is slow. Solution This issue is a result of the automatic paper type sensor misreading the colored paper as photo paper. The print out takes longer because the unit is printing in Best mode instead of Normal mode. Follow the steps below to temporarily change the Automatic Paper Type setting from within the application that you are printing from.
  1. Click File , then Print or Print Setup .
  2. Select the appropriate all-in-one from the drop-down list and click Properties .
  3. Click the Paper/Quality tab and under Type is: select Plain Paper . Changes made within the application might not be permanent and the setting will default back to Automatic after closing the application. The setting will have to be changed each time colored paper is used in the all-in-one.
Follow the steps below to change the default Automatic Paper Type setting to plain paper.
NOTE: By following the steps below, the default Automatic Paper Type setting will be changed to Plain Paper. In order to use a different paper type in the all-in-one (e.g., photo paper), the setting will have to be temporarily changed to reflect the new paper type.
  1. Click Start , point to Settings , and then click Control Panel .
  2. Double-click Printers and Faxes .
  3. Right-click the appropriate all-in-one, and then click Printing Preferences .
  4. Click the Paper/Quality tab and under Type is: select Plain Paper . This sets the default paper type setting to Plain Paper.
May 30, 2008 | HP Photosmart 2710 All-In-One InkJet...
Yellow Hue when color copying
I understand your situation, however let me explain you that whenever you try to make a copy or print, yellow cartridge takes part and provides its color in all the aspects. Please do check that you use the HP ink cartridges and try to clean the cartridges for every 15 days as this may reduce the issues of colors.
Feb 07, 2008 | HP Photosmart 2710 All-In-One InkJet...
Hp Officejet 7210 all-in-one
Random Extremely slow printing !! same !! changed cartridges . i cant figure out the problem !
Nov 21, 2007 | HP Officejet 7210 All-In-One InkJet...
96 people viewed this question
Ben Johnson
