Is it possible to set this amp up with simply an iPod/iphone etc as the sound source, connected to its own set of speakers?
SOURCE: Bose amplifier does not work with a 6 speaker selector
your wall speakers may not be connected.... disconnect each speaker from the selector box and test with a small AAA battery to see if they are connected by putting the battery between each speaker's wires , you will hear it crackle ,then gradually connect each wall speaker onto the speaker connector box . If the first set does not work i suggest there may be a problem with your speaker selector box . Good luck
SOURCE: bose terminal block connector
http://www.4electronicwarehouse.com/products/bose/ta2-adapter.html
SOURCE: we have just installed a Bose lifestyle system,
Make sure you unplug your sa 2 and sa3 amplifiers after setting the codes. Wait at least 60 seconds, then plug back in. I would also unplug the in and out boselink cables as well. Once youve waited for a minute, then plug everything back in. Should work. If not, call Bose technical support. They are really great. I have 15 SA 3 amplifiers throughout my home. They are great.
Use only a BOSE cable. I used to have one and it was a pain when it came to the cables. Only worked with original equipment replacements. You can get your users manual from Bose in Adobe PDF format for free.
The Lifestyle
stereo amplifier is designed for use with Bose non-powered environmental speakers or
Bose non-powered accessory speakers ONLY
