Question about GE Heating & Cooling
Wiring diagram i have a ge model # az21e09d5cv4 i replaced control board and i have one wire that i dont know where it goes could you email me a diagram please at dmon714@msn.com thanks
Gigatech
  • 259 Answers
SOURCE: REPLACED 10KW FAN/HEAT SEQUENCER AND LOST TRACK OF WIRING
Could not find the E1Eh-020HA but found the E2 series
http://www.nordyne.com/Literature/707716c.pdf
http://www.nordyne.com/Literature/901a.pdf
Hope this helps. :]
Posted on Dec 13, 2007
  • 4 Answers
SOURCE: GE JP350 wiring problems
a to black one
b to red one
d to orange
e to grey
a-e to red two
a-d to black two
a-c to orange two
a-b to grey two
a-a to white
Posted on Jan 20, 2008
ranger25
  • 72 Answers
SOURCE: wiring diagram
The white wire is nuetral, if you are trying to make a shop fan or something like that then you hook it to the white wire which goes to the wide spade on the outlet. The black one which is the hot and goes to the smaller blade (looking at an outlet in the U.S. on the right hand side) on the plug and should be for one speed operation. The other three should be capped off if you use it this way. If not, then cap off the black on on the motor and run the hot wire on the plug through a three stage switch. To find what speed corresponds to what wire you have to check resistance to the white wire and the lower the resistance, the higher the speed and hook up to switch accordingly. Also, ground the case with a solderless ring connector under a mounting screw attached to the ground prong on plug. Hope this helps.
Posted on Jan 28, 2008
4x4papa
  • 14 Answers
SOURCE: 917.271021 Wiring Diagram
here's one, not very good. Let me know if this doesn't help and I can clarify the locations of numbers. 4x4papa
Posted on Nov 15, 2008
  • 1861 Answers
SOURCE: replace the headunit
I have sent you the PDF that you requested.
Let me know if you need further assistance.
Posted on Jan 05, 2009
I'm trying to get help to fix my ge washer top load. it fills, drain, but will not spin or agitate. the model is wpre6150k2wt
1st thing to check is the lid switch in the right front corner. It is magnetic and keeps the motor from running when the lid is up. If it goes bad----no run. Next would be the motor itself or the main control board. Either is expensive. Sometimes the motor goes into a lock out mode and can sometimes be reset. The procedure is in the wiring diagram inside the control panel on top.
Apr 12, 2016 | GE Washing Machines
Wiring diagram GE side by side
Pretty easy to get the wiring diagram providing your model is similar to the Side by Side with a control board. Here is a link=> HERE There are more manuals on my website=> APPLIANCE 911
Jan 07, 2016 | GE Refrigerators
WIRING DIAGRAM FOR BRYANT 127ANA036-A
The blue wire from the Ac goes to the y2 on the board for the furnace the yellow and brown goes to c on the board for the furnace and the last wire goes to y1 on the board for the furnace
Jun 16, 2014 | Bryant 462AJC021BA Air Conditioner
I need a wiring diagram to help install a Honeywell st9120c-4057 control board
SHOULD BE A WIRING DIAGRAM WITH THE NEW CONTROL THAT HAS CONVERSION CHART TELLING YOU EXACTLY HOW TO CONVERT OLD CONTROL TO NEW ONE . MUST BE LISTED ON PAPER EXACT CONTROL NUMBER IF IT DONT LIST IT YOU HAVE WRONG REPLACEMENT CONTROL BOARD.
Jan 11, 2014 | Honeywell Heating & Cooling
Have reebok t3.1 treadmill.... took wires out of power switch box and unable to remember what wire goes where... where can i find out!!! Thanx
Usually their is a tech sheet under the motor shroud it should have a wiring diagram. If not the power cord has three leads Black some models use Blue ( Hot ), White ( Neutral ), Green (Ground ). The Black will have the on/off reset switch or on/off circuit breaker to Motor Control Board spade labeled black or blue. The white lead may go straight to the motor control board spade labeled white. Just follow the wire color s and match them. Good Luck!
Jun 11, 2010 | Reebok T 980 Treadmill
I have simon ? dont know which model it was installed in 1991/1993.. anyway someone removed the wiring to the phone jack.. last night .. how can i get a diagram and instructions on how to rehook up my...
If you had a 8 pin jack (RJ31X) hook you ring and tip to #4 and #5. You can also plug a regular phone cord directly into the unit ito the left hand outlet on the board.
May 10, 2010 | GE Security Simon 3 Wireless Home Security...
Fitted new mainoven thermostat to Stoves Newhome built-in oven & grill Model No. 444445062 Serial No.41209452 other data on plate EFa900h need a wiring diagram,couple wires can adrift. Every thing...
I can only speak for the 720. If you want a circuit/wiring diagram for this one, then I need an email address. I will then register this on my BT Digital Vault and you can the download the whole manual.
Looking at the diagrams, the neon for the main oven has white and black wires.
The white wire from the main oven neon goes onto the same connector on the thermostat block as the white wire to the oven element. The black wire from the neon goes to a common terminal on the top oven neon, which then goes onto P6 of the top oven switch (still black wire).
If you need any more info, then let me know.
Apr 01, 2010 | Stoves 720EF Electric Double Oven
Wiring diagram
send me an email at b4829@yahoo.com and ill send you a diargram dont forget my four boxes
Jan 19, 2008 | Frigidaire GLER341A Electric Dryer
Dryer Problem
houseconv email me at b4829@yahoo.com as i need to ask you some questions and dont know how to use this site yet tmg 2000i really dont see how you could wire it wrong at the control panel they are plug in connectors if i was you id plug them in to where it runs then check for 220 at outlet driers will run at 110 volts if its going to the motor but will not heat if you switch the wires and send the 110 to the heater drier will do nothing you may only be getting 110 at outlet partial trippep breaker bad out let bad cord bad terminal etc can get diagram if needed e mail me for diagram
Dec 24, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Heating & Cooling Logo
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
