Question about Canon imageRUNNER 5000 Copier
Compatible drum.... Hi there, can you plz tell me wether can I use Np6030 drum or any other drum which can fit into the 5000 series copier machine....???
  • Pravesh jhunjhunwala Oct 18, 2008
    Hi...there....thnx for your suggestion...if possible..can you tell me the dimentions of the 5000 series drum....because i have about three drums of 6030...and I want to sell it to the market...someone had suggested me that this drum could be fitted into the 5000 series...and ya tru as u said...it has good shining and it is not very big as of 6060 drum.....pls suggest....???
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
No not the 6030 it is a different type of drum (OPC)
yours is an A-SI ( silanium ) drum which is shinier, much bigger and more expensive.
http://www.precisionroller.com/catalog_display.php?fm=0&step=3&MfrID=114&ModelID=118&CategoryIDs%5B%5D=13
check the type that are good here
Posted on Oct 16, 2008
Can ati xfx hd 5770 be crossfirex compatible with msi r6450 yes or not?
my examination of AMD's AMD Radeon HD 5000, HD 6000, and HD 7000 Series CrossFire Compatibility Chart tells me that these cards are not interoperatible in crossfire. See for yourself at AMD CrossFire Compatibility Chart
18.January.2016
Dec 04, 2015 | ATI Computers & Internet
Hi, I want to know about Canon Image press 1110/1125/1135 these copiers use which type of toner. Can we put IR 5000 or IR 7105 toner in them How is the drum
no you can not, the toner in a image press is a dual component toner. in the 5000 and 7105 are a mono component toner please dont and if you did please tell the tech because it will drive him crazy trying to figure it out unless he is a veteran in the copier business.
Oct 17, 2015 | Canon Office Equipment & Supplies
My np6030 canon copier, prints out a black line running through the page when coping content on page.
that is the lifetime of Drum is over.
you must change Drum and cleaning blade.
have you ever done ?
May 14, 2011 | Canon Office Equipment & Supplies
How do you change the cleaning blade and drum in Canon 5000 copier.
why do you want to change the drum, the drum goes about 5 000 000 copies and its too expensive.
The drum cleaning blade goes about 150 000 copies and to change him on your own you need service manual.
For service manual write me on emma.servis@gmail.com
Sep 18, 2010 | Canon imageRUNNER 5000 Copier
The stipler and sorter does not work can u give me the solution?
I can not give you a solution if you can not tell me which sorter you have. I asked wether you had a 10 bin sorter or 20 bin sorter. See previous question.
Jan 10, 2010 | Minolta EP4000/5000 CS/PRO Copier
How to change the drum
On this machine it is beter to get a technition out to replace the drum.It is not as easy as the NP6030.
Oct 31, 2008 | Office Equipment & Supplies
Canon ir 5000
The N series was networked, whereas the S was Standalone and about $3000.00 less expensive. :)
Sep 11, 2008 | Canon imageRUNNER 5000 Copier
NP6030 copier manual availability
you may get lucky on this site
http://www.eserviceinfo.com/equipment_type/Copiers_58.html
otherwise you need to buy it, there are son=me good sites, and cheap $12- up
Aug 11, 2008 | Canon Office Equipment & Supplies
Canon NP 6030 dark copies
Have you cleaned the slit-glass located behind the drum? Its a thin piece of glass that is about the length of a drum assembly. Check that the drum voltages on the drum label have been correctly installed. Perform a AVPC in service mode to set the primary charge value.
Oct 23, 2007 | Canon imageRUNNER 5020 Copier
Canon imageRUNNER 5000 Copier Logo
59 people viewed this question
old marine
old marine
