Question about IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 won't let us clear the left margin
We clear the left margin, but the print head won't move all the way to the left.
  • IBM Master
  • 3,594 Answers
If the carrier (print head) goes to the left when you turn the T/W on then try this.
Return to the L. margin, press mar rel key, backspace to the location that you want the margin, press L. mar key the wheel should spin and reset the margin.
DickyO
Posted on Oct 18, 2008
  • Dick O Reilly Oct 18, 2008
    After thought;
    Put a little lube on the silver shaft that the carrier slides on (WD40 works well)
    DickyO
How to clear left and right margins?
Go to the margin, press mar rel key space or backspace to desired location press L. or R. margin key to reset it.
DickyO
Aug 17, 2010 | IBM Wheelwriter 30 Typewriter
Wheelwriter 30 Typewriter: I have a tab set that I can't figure out how to cl...
The "tab" is probably the R. margin. Go to that point, press margin rel, space to the place you desire, press R mar key.
DickyO
May 18, 2010 | IBM Wheelwriter 30 Typewriter
I do not have a manual for the IBM wheelwriter 3, but I need to know how to set margins for this typewriter. Each time I press return the left margin changes moves to the right. If I shut it off the margin...
The WW3 resets margins and tabs to default on every power up. If the margins change while you are typing then the silver shaft that nthe carrier slides on is probably gummy. A shot of WD40 on both sies of the shaft shouls free it up.
Go to lexmark.com, click on support you will find a downloadable manual there.
DickyO
Carriage won't return all the way to the left- almost as if a left margin has been set. Help.
if margin clear doesn't work try putting some light weight oil on the rails the carriage rides on. turn unit off, oil it and move carriage back and forth by hand then turn it on and see if that fixes it.
Nov 25, 2009 | IBM Wheelwriter 30 Typewriter
Print head moves left and stays horrible noise
The problem is either something is interfering with the carrier movement OR the carrier homing sensor is broken/defective. First, turn off the power and manually move the carrier to the right side frame, check for foreign objects in the machine (pens, pushpins, paper clips etc.). Put some oil (10 weight) on a cloth and clean the chrome shaft that the carrier travels on.(by the rubber cogged belt). This is a common problem. If the sensor itself is the problem, take to a repair shop.(not common)
Nov 24, 2009 | IBM Wheelwriter 30 Typewriter
When typing, left margin resets itself at the right margin.
The silver shaft that the carrier rides on is probably gummy put some light oil on it and move it back and forth.
DickyO
Jan 29, 2009 | IBM Wheelwriter 30 Typewriter
Wheelwriter 5 --cant set the right margin
A beep 5 spaces before the margin is all you are suposed to get, no lock or stop just a beep
Dec 07, 2008 | IBM Wheelwriter 30 Typewriter
Margins
L. margin - return to current mar. press mar. rel. key, backspace to the wanted location press L. margin key.
R. margin - space or backspace to desired location press R. mar key.
The margin keys are on the left side of the keyboard.
DickyO
Jul 10, 2008 | IBM Wheelwriter 30 Typewriter
Margin Problems
You are in auto return. Press code and R
This should doit
DickyO
Mar 10, 2008 | IBM Wheelwriter 30 Typewriter
MARGINS
Move carrier to left margin press margin release, top left hand side of keyboard, back space to desired position and press L Margin key.  Margins will reset to default if batteries are dead.   Right margin simply space to whever you want the margin and press R Margin.
Oct 24, 2007 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 Typewriter Logo
245 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
