I ve just bought lexmark z2300 printer, how do i connect it to my laptop which is on wireless broadband with perlico? ta caroline.
  • cjwren Oct 16, 2008
    i have a windows vista home basic laptop, do I need a usb cable? It does nt come with the printer,
    I thought I could connect via wireless. I have nt use computers in awhile so I m very green.
    I use the internet via google. is that what you want to know.. cheers Caroline.
  • Puneet Jain
    Puneet Jain May 11, 2010
    Could you please tell me what operating system running on your Laptop?
    If you have purchased printer recently, use the installation CD and it will automatically load the drivers, and when it prompts for connect then connect the printer via USB cable to PC and power on it.
    If you found any difficulty then reply me the current status as well.
    Regards
    Ellin
    Guru:
  • 558 Answers
You need to connect the printer with an extra cable which can join it through its 25 pin parallel cable. That cable then with USB end connect with the Laptop. and its drivers can be automatically detect by your Vista system.
For Vista 64-bit, the driver for printer and cable should be digitally signed.
Otherwise you need this method for Driver Installation in Windows Vista 64-bit:
The 64-bit version of Windows Vista is the first version of Windows that will only allow signed drivers and this restriction is built-in. For most cable drivers are unsigned and we request you to follow some prerequisites before installing the driver.
Preparing Vista 64-bit for Driver installation:
  • Using the F8 option: Press F8 key on your keyboard while booting your PC. You will get into “Advanced Boot Options”. Select “Disable Driver Signature Enforcement”
  • An F8 Advanced Boot Option introduced with Windows Vista—“Disable Driver Signature Enforcement”—is available to disable the kernel-signing enforcement only for the current boot session. This setting does not persist across boot sessions.
  • Note: Make sure to use F8 option every time you boot/reboot your PC before start working with MCS77XX.
  • Make sure that the User installing the driver must be a member of the Administrator group on the system.
And for printer driver if you dont have CD then go through this link and follow the steps:
http://www.fixya.com/support/r1133275-drivers_installation_problem
Let me know if you need furhter assistance, I will help you to run your Printer with Laptop.
Regards,
Ellin
Posted on Oct 17, 2008
  • Puneet Jain
    Puneet Jain Oct 18, 2008
    Reply please if the soluton work for you.
    Give your rating to the solution either Helful or Fixya.
    If you dont fix the problem yet by the solution given then I would suggest you more options, let me know for it.
    Since your voting is precious to me in providing the help for others.
    Have a Nice day.
    Regards,
    Ellin
Will my lexmark z2300 print wirelessly, if so how do i hook it to my wireless router
please install cpu printer driver and right side vifi setting repair connection vifi
Apr 23, 2012 | Lexmark Z2300 InkJet Printer
My Lexmark z2300 sends to the printer & it says it's printing, but it doesn't actually print. I've tried several file types & programs to print from but none of them work.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
Sep 14, 2011 | Lexmark Z2300 InkJet Printer
The printer will no longer print. It sends the job to the printer and after a couple seconds it disappears
The following link to Lexmark support has an optional diagnosis tool to assist you with your problem: (you did not indicate any error messages)
Lexmark Z2300 Print Job Disappears
Jan 14, 2010 | Lexmark Z2300 InkJet Printer
Lexmark z2300 eplacing ink cartridges
Go to www.lexmarkz2300.com. There will be instruction on how to replace the cartidges. you will b e able to print out the instructions after you fix the problem.
May 21, 2009 | Lexmark Z2300 InkJet Printer
Printer Installation Failed Lexmark Z2320
I 've lexmark printer z2320, and I've download softwer from internet, but after installed, not appear the driver of z2320 but z2300, i want to download the driver propely
Apr 19, 2009 | Lexmark Z2320 InkJet Printer
Paper load
This plastic piece you are talking about have to be squeezed for it to be able to move from side to side, Try squeezing it and see what happens.
Thanks,
Lolita
Feb 24, 2009 | Lexmark Z2300 InkJet Printer
Computer cant read printer
now i got to pay yall to fix the **** i cant see that
Jan 08, 2009 | Lexmark Z2300 InkJet Printer
Going wireless with Lexmark X5470
NO you cannot go wireless with the the Linksys wireless-G broadband Router WRT54GS for this printer, to check the wireless print sever you need to click on this link and then click hide/show additional results and it will cost you $149,
http://search.lexmark.com/printer/US/en/22N0000
instead you can buy a wireless printer from Lexmark X6570 which is also $149.
May 18, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x73
Sorry the hardware of the printer is not compact able with vista ,it wont work,as there no driver for vista by lexmark ...
Mar 21, 2008 | Lexmark X73 All-In-One InkJet Printer
Poor Wireless Reception on DELL Inspiron
It is likely your wireless card reception. try an external usb wifi adapter it shouldn't be expensive.
regards
Mar 01, 2008 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
93 people viewed this question
David Payne
David Payne
