Garden Logo
Bob Lewandowski Posted on Jan 22, 2012
Toro524 5hp snowblower auger diconnected or shear a key or gear box
Last year when clearing snow.it sounded like i shear a key or snap the shaft that drives the unit
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Feb 05, 2012
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
9
Questions
Helped
1720
Points
15
Remove plug wire and try to spin augar by hand .If it spins freely you sheared a bolt located on either end of shaft that runs thru augar drum.You will see a notch in augar drum to access this bolt .If it is this bolt insure you replace it with factory bolt they are meant to shear to prevent costly damage .if the augars don't turn then damage is deeper .Go to toro web site with model number and serial number to view brake down drawing.
2 Related Answers
Anonymous
  • 70 Answers
  • Posted on Dec 22, 2008
SOURCE: where is toro 31820 auger shear bolt?
Shearbolt is located at #54 in this diagram.
https://homeownersolutions.toro.com/portal/server.pt?space=CommunityPage&cached=true&parentname=CommunityPage&parentid=1&in_hi_userid=19462&control=SetCommunity&CommunityID=214&PageID=238#drawingDiagramPage
part#322-9
It may be hard to spot on the auger shaft as it may have sheared flush with the holes so look close. You may also need to remove the part of the bolt remaning inside the shaft.
ToolBoxHero
Paul Sikkema
  • 171 Answers
  • Posted on Jan 10, 2011
SOURCE: I have an Ariens 926LE
Hi, The blower spins at full speed? If it does the belt, pulley, and shaft are good. Look at the shaft from the fan to the gear box while it's running and that shaft should be turning at the speed of the fan.
If the blower spins at full speed and the auger doesn't the most likely problem is the worm gear transmission from the blower shaft to the auger shaft.
A good way to visually inspect this is: With the machine turned off and the spark plug wire unhooked go to the front and try to rotate the auger by hand. If the gear box is good you will only be able to move the auger less than an inch. If the box is bad you will be able to move the auger a lot farther. While you are there recheck your shear pins.
You can also remove the blower drive belt and have someone turn the pulley by hand while you watch the auger. Put resistance on the auger with your gloved hand. If the box is good the auger will move smoothly in you hand. If it is bad, it will ****, move roughly, or stop.
While the other person is turning the pulley and you have some resistance on the auger look closely at the shaft running from the gearbox back to the blower. On some models there is a connecting sleeve and the roll pin that connects the sleeve to the shaft and gearbox will break.
If the gearbox is bad, it will have to be replaced as a complete unit.
Was this helpful? If you have any other questions, please ask.
Testimonial: "Have not tried the trouble shooting steps yet. I does make sense to me and will try them when I get home. Hope it works. Getting a lot of snow."
2answers
The impeller is turning but the blades are not. Belt seems ok
Depending on your make of snowblower, At the impeller there is usually 1 or 2 shear pins or bolts circled in red. If the impeller and the impeller shaft are turning but the augers are not, the gear may be stripped inside the gear box circled in yellow or the keyway may have sheared between the auger gear and the auger shaft.
Jan 24, 2016 • Garden
My Husqvarna snowblower is grinding when the auger is engaged and it will not throw snow.
Most snow blowers have "Shear Pins' that connect the blade to its drive shaft. These 'shear' off when hitting rocks or other debris that gets caught in the blade. Check those and by new Shear pins. If it is not that, then you have problems in the gear box, or shifting mechanisms.
Feb 18, 2015 • Garden
2answers
Mtd yardmachine snow blower 305 cc auger wont turn
This is a fairly frequent problem that is easily fixed. What happened was the snowblower's auger was either overloaded or got jammed (ice, debris - something other than snow). Rather than twist, damage or break the auger itself, an inexpensive part called a "shear pin" is designed to fail. A shear pin employed between the auger sleeve and drive shaft that is inside the sleeve. You may have broken one if one side of the auger spins) or both (if both sides of the auger spins). Purchase several replacements for your particular machine to have on hand. Do NOT replace s shear pin (or shear bolt) with a regular bolt under any circumstances! Check the video linked below on how to replace the shear pins. Good luck!
1helpful
2answers
Rear auger turns front auger not turning
From your information above, it sounds like a broken gear or tooth on the auger gearbox. (this could happen if you hit an object and your shear pin did not break, instead breaking your gear) Hope this helps.
Right side of snowblower is constantly clogged with snow
Check the R.H. auger my guess is you have a shear pin that has broken and needs to be punched out and replaced. If it rotates freely (cleaned out of snow) then that's likely your problem. You can prove that by watching the shaft the auger is riding on if the shaft moves with the auger shear pins ok. If the auger moves seperate from the shaft the shear pin is at fault.
Aurgur not turning on Simplicity Snow blower.
The Woodruff key that splines the drive shaft to the drive pulley could be sheared. I had this problem, and could not get a new key to work as the cut in the shaft for it opened up. I drilled through the collar and the shaft, put a grade 8 bolt with a locknut on it, and that fixed that
Feb 08, 2013 • Garden
I have a snow king 5hp snow blower. while clearing snow, the snow only oozes out the shoot.
IT SOUNDS LIKE YOU HAVE A TWO STAGE SNOWBLOWER WITH ONLY ONE STAGE WORKING. I BET THAT YOUR PROBLEM IS THE AUGER IS TURNING BUT THE IMPELLER BLADE THAT IS BEHIND THE AUGER HAS PROBABLY JAMMED UP WITH SOMETHING AND IS SPINNING ON THE SHAFT. YOU WILL HAVE TO REACH BACK AND GRAB IT AND TRY TO TURN IT ON THE SHAFT BY HAND.MAKE SURE THE BLOWER IF OFF!!!! . IF YOU CAN TURN IT BY HAND EASILY IT HAS EITHER BROKE A SHEAR PIN OR BOLT OR SOME TIMES THEY WILL TACK WELD THEM TO THEM TO THE SHAFT. GOOD LUCK
2helpful
I have a new Troy Bilt Snowblower. My father ran over a large extension cord while blowing snow, which in turned wrapped the cord around the auger shaft ends. I can now only get one side of the auger to...
Your snowblower has 4 shear pins keeping the front auger safe. Use the manual to locate them if you are unsure where they are and how to change them. Since your snowblower is new I am going to assume you have the manual.
Your snowblower came with 2 spare shearpins. Check up by the handles and see if they are still there. If you don''t have them go to your local Lowes, Sears, or MTD repair shop to get new ones. DO NOT USE STANDARD BOLTS!
The drive shaft coming out of the gear box is one, solid piece all the way across the snowthrower so if one side is turning there is a 95% chance it's the shear pins.
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
