Question about Garden
18hp briggs will not start, fuel related
Just rebuilt carb, fuel adjustment seems to be off. if i take the fuel line off at carb, will start.
  • 48 Answers
Sounds like you may be getting too much fuel - when you rebuilt carb did you check the float ( by shaking it near your ear ) to see if it was full of fuel . if it is throw it away and get another - if not need more info like what did you adjust the jets to
Posted on Oct 17, 2008
I have a 18hp b&s inteck that want idle the govenor goes back and forth
I believe the condition your describing is called "hunting" this sometimes happens when engine has a problem with it's air/fuel mix usually due to a carb problem
id start by cleaning out the fuel tank and filters and then moving on to the carb
Jan 22, 2016 | Cars & Trucks
24 hp brig motor does not seem to be getting fuel
the additive in gas eth. causes fuel lines to break down and not deliver gas to the carb. replace fuel line.
check fuel pump, remove fuel line to carb. turn motor over, if fuel does not spurt out fuel line replace fuel pump.
float in carb may be stuck, remove bowl from carb. and check needle valve, if gummed up clean.
Jun 02, 2014 | Briggs & Stratton Briggs Stratton Intek V...
18hp twin cylinder Briggs & Stratton backfire
Check to see if the carb is clean, if so the anti diesel value could not be working. Apply 12 volts to value and see if it move's. If that works then you may what to check the fuel pump and see if it pumps. After you tried all that then you may have change the main jet size because these engines come with a small jet for the EPA.
Apr 19, 2010 | Briggs & Stratton Power Products 1539...
22 hp Briggs Intek will not run at full speed without choke on
sounds like you sucked up dirt in the carb needs to be taken off and cleaned
Jul 17, 2009 | Briggs & Stratton Briggs Stratton Intek V...
On my 18 HP, if you are facing the engine and the flywheel is on the left, the adjusting screws are all under the air breather. The best way to get at them is to take the breather mechanism off right down to the carb. They are all on the left side of the carb!
Jul 07, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and Stratton Vanguard twin stopping running and wont start
A couple of things you might the shelf from Lowe's or walmart is engine repair in a bottle...I've used it and it works, but read instructions. If that doesn't work, you may have a lacquer build up on carb. Pull the fuel bowl off carefully and check for a clear opening in the fuel pickup as they may be clogged. Remove gas tank and flush it and then make sure it's really dry...replace fuel filter and install two in series in place of one. Also, try to find a gas station that sells ethanol free gas and use it for your small engines. Hope this helps some.
Jun 27, 2017 | Desa International 18hp Briggs And...
Weird under load symptom briggs 17.5
a couple other checks would be to dump the carb resevoir where the float is, water under the float could be accumulated and closing the fuel off, due to density. out here on the farm we never use the gas to the last drop from the can. also the linkage between the motor fan blade, (govenor) might have been connected to the carb incorrectly. or a bad switch interlock on the mower blade.
some briggs motors are hooked wrong straight from the factory, where the throttle linkage is concerned. ( and the little spring is pretty hokey too)
May 16, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My briggs & stratton will not start
If the engine fires on starting fluid, then you are missing fuel, so you need to start with the source, is fuel getting to the carb? if not why not. Check fuel lines, shut off valves and filters.
If it is, is the carb float allowing the bowl to fill?
If there is fuel in th float bowl, then you need to look at mixture and idle settings.
hope this is of some help.
Apr 19, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
98 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
