Question about Canon DC20 DVD Camcorder
Disk Error My DC20 camcorder will not recognize any disk - I have tried several brands. I know I am using the right type because they use to work. But now I put the disk in an it makes a noise (like something is loose) as it tries to find the disk. Then a disk error appears on the screen. I tried cleaning the lens but that didn't work. Thanks!!
  • kbecerra7 Oct 22, 2008
    Same problem, disc error even with the expensive sony discs. Won't initialize....can't do anything with it. An old disc will play on the camera and I was able to record on an old disc that came initialized. Since then, nothing...
  • jsolomon_76 Nov 17, 2008
    I keep getting a disk error message.
  • Canon Master
  • 19,396 Answers
If the camcorder does not read any disk, and makes noise when reading a disk and does not start reading, then the problem concerns either motor assembly or lens pickup.
If the disk is spinning and lens had been cleaned already, then the lens must be replaced.
Posted on Aug 14, 2009
Can i use other braqnds of memory cards in the camcorder?
Yes. You can use any brand of memory card, as long as it's the correct type. Personally, I'd stick with the major brands, but I use several different brands with my several cameras and none of them have ever caused any problems.
Nov 29, 2012 | JVC Everio 25x/20GB Hard Disk Drive...
The disk plays fine in the camcorder, but not when I put the disk in a computer. I finalized the disk before i put it in the computer.I
you need to install the dvd playback software on the Pc to read the disk. the codec of the camcorder is not installed so the Pc can't read the video format. use for exemple dvdplayer you can download it from this link it's free: http://www.dvdvideosoft.com/products/dvd/Free-DVD-Player-Software.htm
Dec 24, 2010 | Canon DC20 DVD Camcorder
When trying to video keep getting message no disc'' even though there is disc in camera
Check the laser lens for any dirt or obstruction. If there is, clean it carefully with a "Q" tip and alcohol. Insert a disk and listen for the disk turning inside the drive. If you don't hear anything then something is wrong with the read laser. It's either damaged or burned out. The laser must focus, read, and then spin the disk to not show "no disc".
Nov 10, 2010 | Canon DC20 DVD Camcorder
Camera will not allow me to finalize some dvd's
If your camera finalized the same type (+R, +RW, -R, -RW) of disk previously, the problem may be the disk itself. Some 2% of the disks (no-brand and copy-brand disks even higher %-age) are faulty and either do not allow recording at all or fail at some point.
Dec 05, 2009 | Sony DCR-DVD610 DVD Camcorder
Either my computer or dvd does not read movies recorded by this camcorder. Why?
hi. in many DVD camcorders. you are suposed to closed o finalize the dvd disk . by doing this it will be playback compatible with your pc or dvd player.
NOTE
after finalizing a disk you will not able to record any longer on that disk (DVD-R, DVD+R, DVD-RAM, DVD RW) If you record for 5 minutes and finalized the dvd it will have a 5 min movie !!!
Oct 08, 2009 | Canon DC20 DVD Camcorder
Error C:13:02 - Can't recognize any disks
Not good. It sound as though it will need the disc mechanism unit replaced.
Dec 29, 2008 | Sony Handycam DCR-DVD201E DVD Camcorder
Try to use a cotton swap to 1st clean the recording lens or blow gently on it. Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
Drgadgt
Oct 28, 2008 | Sony Handycam HDR-UX7 Camcorder
Mini DVD Camcorder Problem
You will never be able to recover the information. Sony's system really will have problems with third party brands; there is particular engineering that makes this so. In my shop (Sony authorized), I have seen this problem many times. If you insist on using other brands, get used to problems. As your laser assembly wears it will become more problematic. Good luck, magic seadog
Jun 14, 2007 | Sony Handycam DCR-DVD201 DVD Camcorder
Canon DC20 DVD Camcorder Logo
422 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
