Wiring for GPH1548 & Honeywell Themostat Th8320U1008
I have a Goodman GPH1548 2 stage cooling and 2 stage heating via the heat pump. The unit has had field installed heat strips.
Wiring as best as I determine is as follows -
Y2 - yellow
AUX -brown
RC+R - red
O/B - orange
Compress relay 1 - yellow
Fan Relay - green
Compress relay 2 - purple
I have a white wire (W1) where does it go?This unit has a 2 stage heat/cool and aux heat strips.
I am starting to think I do not need the white wire since the rev. value will give me the two stage heat and the 2 stage cool. The brown wire would control the heat strips?
any help is appreciated
  • ustepr Oct 16, 2008
    The thermostat is a Honeywell model number Th8320U1008
5 Suggested Answers
pierre1811
  • 144 Answers
SOURCE: replacing thermostat: tstatccshp01 with th8320u1008
Hook up o to o/b, then in the installation programming set the change over valve to energize in cool. Then hook up w to aux. Good luck.
Posted on Jan 21, 2009
  • 340 Answers
SOURCE: GOODMAN CPLT36-1 WITH HONEYWELL VISION PRO STAT 8000
what is the trans former voltage needs to be 26- 28 v. and is the board fused max 3-5 amp fuse I know it is on of the two check all of your wiring. good luck Tom
Posted on Jul 12, 2009
  • 233 Answers
SOURCE: Wiring Trane/Honeywell TH8320U
use the outside designations for heat pump, and inside for standard, I would assume a heat pump since you have more than five wires attached to it now. Use the colors of the wire to match to the designations, use tan for y2, black for w2 rc and rh should already have a factory jumper. I would have to trace out the "U" and see where it terminates, I have not seen a bare wire on a stat in 27 years of doing this. before powering, verify the tan and black at the indoor unit circuit board and see if they are landed on the terminals designated at the stat. hope this helps
Posted on Jul 27, 2009
  • 587 Answers
SOURCE: Heat PumP: Rheem Two Stage Heat, One Stage Cool Thermostat Replac
R = R with jumper to RC hot side of transformer
B = Reversing valve
Y = Compressor relay
G =Blower
C = common on transformer (X on old t'stat)
W2 = Auxillary heat
E = Emergency heat
Posted on Mar 16, 2010
  • 4 Answers
SOURCE: Wiring a Honeywell VisionPRO TH8320U1008 Thermostat
on the honey well tstat you have to go into the installer set up and set the swithover valve for energized in cooling
Posted on Jan 19, 2012
Airhandler- the themostat is on auto/I understand cool,heat.emerg heat,The (G) terminal-then why heat mode or,emer heat fan blows?Only when i switch to cool mode the handler still want start up blowing...
the fan fill come on with the sequencer (stack switch you call it) it will also come on with the fan relay. on some goodmans the fan relay is the black box on the circuit board. use a jumper to jump red to green, this should bring the fan on sounds like you could have a broken green wire, try using a different wire instead of green
Sep 12, 2013 | Goodman Heating & Cooling
Tip
Thermostat Wiring and Terminal Designations
Here is a list of each common terminal and what their commonly used for. Also listed is what colors are commonly used. NEVER ASSUME these are what you have. Verify all your wires by following each to each piece of equipment. This will help you to be able to match your equipment with the terminal.
- R, Rc, Rh Red wire, hot side of transformer
- C various color wires Usually the common side of transformer
- Y Yellow wire, Energizes the compressor, cooling or heating and cooling for heat pumps
- W White wire, heating for most units
- G Green wire, energizes the fan or blower relay.
- O Orange wire, energizes cooling on most heat pump units
- B Blue and sometimes Orange wire, energizes heat on most heat pump units
- B or X Blue, Black, or Brown wire, the common side of the transformer when the t-stat needs a common. Some brands use B as the common (York, GE, and Trane)
- E Pink, Gray or Tan wires, Emergency heat relay on heat pumps with auxiliary heat
- T Tan or Gray wires, For units with outdoor anticipator reset control (Trane, American Standard, GE, and Carrier)
- W2 Pink, or Brown wires energizes second stage heating on 2 stage units
- Y2 Blue or Pink wires, energizes second stage cooling on 2 stage units
- L Can be most any color, energizes service indicator lamp on units that are equipped with that.
The wires that always cause the most confusion are the B and X wires.
Check out the B terminal first. The NEMA standard for the B terminal to be the heating changeover valve but with some units it is different.
Trane, GE, York and some other manufactures which includes older Honeywell thermostats often use it for the common side of the transformer.
“X” Usually is the standard for common, but just like “B” some manufactures do use “X” or “X2” as the terminal for the emergency heat relay.
on Dec 12, 2009 | Heating & Cooling
Carrier OEM to Honeywell Programmable Tstat - NEED HELP
you likely have a "two stage" system, but not a two stage heat pump. the first stage is probably the heat pump itself, and the second stage is the auxilliary resistance heat that suppliments the heat pump at lower temps. if i knew the terminals that are available on the new stat, i could advise you on the proper wiring.
Jan 27, 2013 | Carrier Heating & Cooling
I installed a new Honeywell Programable thermostat, When I turned on the AC it turned on the Heater... I followed the wiring but some of it is not making sense... G=Green, Y=Yellow, R=Red, C=Blue,...
Hi, the problem is you have bought the wrong thermostat for the unit if it is not a heat-pump. A heat pump will have W-1, W-2 for heat strips, and Y-2 is for 2nd stage cooling. G is Green for Fan, R is Red for Power, Y is Yellow for cooling, and W would be for Heat. This is all you need if you have gas heat, Orange is for a reversing valve for a heat-pump, and the blue is also for the reversing valve on a Rheem heat-pump. The stat you need will have these terminals, if you are sure its not a heat pump, which I am sure you would know. The stat you need has these terminals. RC and RH. It will have a Red jumper wire connecting the 2 terminals. This is where the Red wire connects, to either one, as they connect together. Connect G to Green, Y to Yellow, and W to white. Since you only have one control transformer, that's why the stat has RH for Red Heating, and RC for Red cooling tied together. Just hook the red coming in to either one. You need only, R, G, Y, and W, to run this unit. Look at your old stat and check the terminals. A heat-pump, uses many more conductors to operate it. O or orange for the reversing valve, blue also depending on the unit. C for common, W1 for stage one heating, W2 for stage 2 heating, Y1 for stage one cooling and Y2 for stage 2 cooling. This stat is used for a commercial unit with multible stages of heat and cooling. If you have a common wire and no batteries on the old stat, go to the indoor unit, remove the panel, and see if you have a common wire hooked up, such as the brown, black, or maybe blue. If so, you will need to hook it up at the stat if it has a C terminal. If it has batteries, just take all of the extra wires and shove them in the wall. You won't need them. Just the R, G, Y, and W, and you will be back on line. Very easy.
Please rate me. Take it back and have them sell you the right stat. Please keep me posted and I will be here if you need my help. Thank you for using Fixya.
Shastalaker7
A/C, and Heating Contractor
Nov 23, 2010 | Goodman Heating & Cooling
Need wiring diagram for Honeywell RCT8100
The old thermostat has a second stage heat which is W2. The new one doesn't have second stage heat.
The wiring your describing on the old thermostat is telling me you have a heat pump with second stage heat and the new thermostat is for air conditioning only. You will need to get a thermostat for a heat pump.
Apr 02, 2010 | Honeywell Electronic Programmable...
No heat, got great a/c....
W1 and W2 are the differences from the single stage to the two stage. Im thinking its your thermostat is not programed for 1 heat / 1 cool. You probably had 2 heat / 1 cool before.
Oct 17, 2009 | Goodman Heating & Cooling
I am installing a Honeywell T841 onto existing RGYW wiring. The fan kicks on, but I notice the air conditioner is not running. Were one or more of these supposed to go on the W2 or B terminals? Thanks!
Need to have more numbers in model number to be sure There's about 30 T841 t'stats and some are1, 2, and 3 stage heat pump and some 1, 2, and 3stage AC.
If you have
R to transformer
G to fan relay
Y to contactor in outdoor unit
W to Gas valve
You have the thermostat wired right.
Depending on the T'stat B could be the common side of the transformer or 2nd stage heat.
W2 terminal are for 2nd stage heat
You need to put the thermostat on cool and lower the setting to bring on the cooling. Then go outside and see if you have power to the outdoor unit and 24 volts to the contactor coil.
Sep 06, 2009 | Honeywell Electronic Programmable...
Honeywell Thermostat
Make sure G from indoor unit goes to G on thermostat for fan continous fan, if that doesn't work and you have 24 volts to R and C then the t'stat is bad.
For 2nd stage heat or aux.heat, on the indoor unit you need to make sure the wire W2 from the indoor unit goes to W2 on t'stat.
You don't need any wires from W1on the indoor unit to W1 at the t'stat because with a York heat pump Y1 is the contactor which turns the compressor on and you will get 1st stage heat, and for cooling the t'stat will also bring on O which is the (reversing valve) or cooling changeover relay for the cooling mode.
C = common usually black wire
R = hot usually red wire
Y or Y1 = contactor
W1 = 1st stage heat not needed for heat pump
W2 = Aux. heat indoor heat
G = fan
O = Cooling changeover relay
B = Heating changeover relay
L = System monitor
E = Emergency heat relay
Dec 23, 2008 | Honeywell Electronic Programmable...
Changed out a Honeywell Thermostat with an Aprilaire Thermostat
The smell is usually dust on the wires for electric resistance heat.The thermostat shouldnt have anything to do with it.
Nov 19, 2008 | Heating & Cooling
the thermostat will to any temperature but will not shut off
Nov 25, 2007 | Honeywell CT3600 7 Day Electronic...
Heating & Cooling Logo
159 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
