Question about Euro-Pro Shark GI490 Iron
Shark steam iron
Model g1405z,,,120V-60Hz,,,,,1600 watts
This is the fourth Shark iron i have own,,,,and have had the same problem with all four,,,,
They short out at the cord inside of the swivel,,,,,This iron however sparked and burned,,,,,
I take in ironing,,,,so want a profesional iiron,,,,But there has to be a way almainate this problem,,,,
please respond, asap,,,,,,
thank you,
Janet L. Broussard
  • Anonymous Mar 07, 2009
    The same thing happened to me, i dropped my iron and before it hit the floor i caught it by the cord, it started smoking and smelled like an electrical fire so i assume it shorted out.. i just wanted to make sure the company was aware of the problem but when i tried the website I found that it is no longer available. back to Sunbeam for me
  • Anonymous Mar 16, 2014
    shark iron steam buttun stuck
I always purchase your Product and Irons. I like your product very much. so please provide me with address to sent this Iron back for repair. It has always made the lights in the room whenever I Iron go on and off. Also shuts off and on during ironing, then and water leaks from the iron. " Please Help"
Posted on Oct 17, 2008
  • PapaRG May 28, 2011
    My wife has the Shark X-tended Steam Burst Iron with the same shorting out in the power cord. A very easy repair of about 30 minutes.
    Remove the 4 screws in the back cover plate.
    Pry out the 2 rubber coated resting pads on the bottom of the cover plate to expose 2 additional screws.
    The cover plate will lift off exposing the wiring and power cord
    Remove 2 screws that attach the brace that pinches the cord to the iron frame.
    Remove 2 screws that connect the power cord. (note which wire, ribbed or smooth, is attached to which screw.
    Cut the power cord just above where the brace pinches the cord.
    Crimp a connector to each wire and attach the power cord as it was before.
    Attach the brace which supports the chord and then attach the 6 back cover plate screws.
    Insert the resting pads back into the cover plate.
    Your shorted out power cord should now be fixed and you just saved yourself $50 or $75 bucks.
  • C M Mallard Apr 01, 2013
    What did you use to remove the screws from the back cover plate?
Shark iron wont turn on
take it back to were you got it from i think the regulator has just packed up
Jun 20, 2010 | Euro-Pro Shark GI490 Iron
My shark steam iron is leaking when ironing
It is quite possible that this is a defect in the shark G1490F... I had the same problem and it was a crack in the water holding tank caused by tightening the two front screws (hidden) that hold the tank to the base... It seemed fine at first but after a full heating it developed a crack where it had been weakened when it was assembled... I suggest returning it or if warranty is up , throw it away and get something else..
May 23, 2010 | Euro-Pro Shark GI490 Iron
My Shark Iron leaks....
fill with water turn iron on max keep turning steam dial all the way to the right until you get to self clean hold iron horizontal and make sure you have a towel or something to catch water drips and debris coming out of iron let iron steam and spit water out until it stops on its own turn dial back to regular steam settings wipe residue off of the plate with a towel adjust temp settings back to normal
Aug 14, 2009 | Euro-Pro Shark GI490 Iron
Stopped producing steam
Iron not heating up sufficiently to produce steam. Threw it out!
Jun 24, 2009 | Euro-Pro Shark GI490 Iron
Paid $50.00 for Shark model G1405Z. It lasted 3 weeks.
WalMart would have replaced it with or without a receipt for an identical priced product. You can take the bad one back with the receipt and ask for a refund, provided they ARE identical. The barcode is scanned onto the receipt.
Feb 12, 2009 | Euro-Pro Shark GI490 Iron
Euro-Pro Shark GI490 Iron Logo
2,692 people viewed this question
Top Euro-Pro Irons Experts
Gil Shultz
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
