Question about Sharp AL 1631 Copier
Average useful life of Sharp AL-1661CS
I have a Sharp AL 1661CS and am having problems with the drum unit. I've already replaced this twice. The copier has 46,492 copies on it. I'm debating wether or not I should spend the $199 to replace the drum or put that towards a new copier. I'd like to know what the expected average useful life is for this copier to help me make my decision.
Thank you.
  • 1 more comment
  • Donna Lam
    Donna Lam Oct 16, 2008
    When I use the copier/printer, toner is left on the edge of each page. I've taken the toner cartridge out and the drum cartridge and cleaned everything to the best of my ability. When I look inside the copier, you can see a little pile of toner underneath of the drum unit which is on the same side as on the toner on the paper. When I was checking the price of a new drum unit, I saw it was $200 for the unit and thought I'd see what the expected life of the copier is. I make a little over 1,500 copies per month. I'm trying to figure out if it would make more sense to put that $200 towards a new copier.
  • Donna Lam
    I found the white foam seal which is actually black with toner. That is where the excess toner is getting on the paper so I will try a new cartridge. Lots of toner hanging out on the bar that faces the drum. Don't know if that is normal or not.
  • Inno Laur May 11, 2010
    The drum is scheduled to be replaced on those machines I believe every 25k copies. If you've already done it twice and it still needs replacement that's kind of pre-mature.
    I've seen similar machines over 150k (sometimes even more) with no significant problems as long as parts are changed on the recommended schedule.
    If it's in a particularly dusty/dirty environment those numbers can be greatly reduced and you will go through more parts, drums included.
    What are the symptoms you are having? Perhaps it's not the drum.
    Scholar:
  • 92 Answers
With that machine the toner cartridge also contains developer. Without getting too in depth, it sounds like maybe your toner cartridge is leaking a bit of developer which takes with it a bit of toner. Developer is made up of tiny metal particles which are supposed to stay inside the developer unit. As the seals wear in the developer unit (which is part of the cartridge) it allows a little to leak out causing the problems you are seeing.
When you take the toner cart. out, at the rear side (part that goes the furthest into the machine) you'll see a white foam seal. If you notice some excess toner (and probably developer) sticking straight out from that, it could be that the seal has a jagged edge which is dragging developer off of the magnetic roller and depositing it on the drum making the line you speak of on the left hand side.
Also check to make sure the copier is sitting level, if it's not then the concentration of toner at one end of the developer unit is too great and some can be allowed to spill out.
So in short, it's probably not the drum that's at fault, it's more likely the toner cartridge.
Is it worth replacing? There's no easy way to answer that. If the machine is used in a fairly high volume workplace, it's probably worth replacing. If you could get by with a smaller cheaper machine (brother, HP, lexmark etc.) that does printing, scanning, faxing and copying you may be better off.
Posted on Oct 16, 2008
Replaced drum cartriddge on model AL-1661CS and still has error reading to replace cartridge
After replacing drum catridge you should reset the drum counter in the following way
1.Identify the buttons used for adjusting exposure (darker or lighter copies), amount of copies, clear copies and start copying
2.Now press the following sequence of buttons: [CLR], [AURO], [CLR], [AUTO] all thes one by one
3.Your unit should turn off the numbers in the panel
4.Now press 24 as if asking for 24 copies and press [START].
4.Now press 07 as if asking for 7 copies and press [START].
This should reset your drum and it should stop flashing
RNJ VINOD KUMAR
Sep 15, 2009 | Sharp Office Equipment & Supplies
Put new drum in and the light is still flashing. have already changed the ink,
did you clean the printer first? see if you can clean all over the connection around the old drum and reset the printer.
Sep 13, 2009 | Sharp AL-1661CS All-In-One Laser Printer
Bad copy from Sharp AL-1661CS
Try print from a pc, if those lines still appear then you should replace the drum unit. If not then clean the copy glass and the scanning mirrors.
May 10, 2009 | Sharp AL-1661CS All-In-One Laser Printer
Printer has stopped printing copies even with a new toner and drum. Help!
Try the old one back in it? does that work if so Faulty unit take it back
Apr 23, 2009 | Sharp AL-1661CS All-In-One Laser Printer
Locked up AL-1642CS with blinking Drum Light
Older Sharp AL copiers will go on working with the drum light blinking, but yours will not. Newer models do stop working when the drum reaches its limit. Now keep in mind that just as almost every copier in the market, these units count the copies they make in order to determine toner & drum life. So it is possible to reset the drum counter if you inspect the unit and see no markings or visible wear & tear. Also keep in mind that the toner & drum units have been the same for all AL units through time, so there are plenty of good replacements in the market (not recycled, but re-manufactured or brand-new compatibles).
As for your unit, if the drum is Sharp original or a good quality replacement, you should have to do nothing after installation, for the internal chip in the drum will tell the copier to reset the counter and begin working automatically. However if that is not the case, or should you want to reset the counter on your existing drum, this is the correct sequence to do so.
  1. Identify the buttons used for adjusting exposure (darker or lighter copies), amount of copies, clear copies and start copying.
  2. Now press the following sequence of buttons: [CLR], [EXPOSURE], [CLR], [EXPOSURE]
  3. Your unit should turn off the numbers in the panel.
  4. Now press 24 as if asking for 24 copies and press [START].
  5. Press 07 as if asking for 7 copies and press [START].
  6. Your unit should restart by itself and start working normally.
Be blessed.
Nov 07, 2008 | Sharp AL-1641CS Laser Digital Copier
Drum cartridge - generic
Sharpe are correct there is no known button sequence I know about as the drum normally has a resistor that blows when installed resetting the drum count.
Thanks J
Dec 26, 2007 | Sharp AL-1661CS All-In-One Laser Printer
Sharp AL-1631 - would not copy.
Your unit definetly needs a new drum. The usual yield for this consumable is upt ot 15,000 pages, so at the stated rate, the unit yielded more than average. AL-1000 series share the same toner and drum, so finding remanufactured (or recycled) drum units should be no problem. In Puerto Rico, they are sold for about $79.00.
Oct 05, 2007 | Sharp AL 1631 Copier
Drum light
Check a service manual on resetting the drum counter. You have to reset this counter to tell the machine it has a new drum
Aug 25, 2007 | Sharp AL-1641CS Color Copier
Please Help -- Erroneous Lines from Auto-Paper-Feeder
Not familiar with this particular machine, but it sounds like one which uses a seperate scanner when drawing originals from the sheet feeder. Have a look to see if there's a glass strip to the side of the main copier face. If so, give that a careful clean. A.
Apr 04, 2007 | Sharp AL-1661CS All-In-One Laser Printer
Sharp AL 1631 Copier Logo
1,059 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
