Question about Sony PCS-DSB1 (PCSDSB1) Video Conference
Can a webcam connect to a SONY PCS1?
Greetings PCS1 guru's I am looking for any info pertaining to whether a PC/MAC webcam is able to connect to the Sony PCS1, any info on this topic would be most apprciated. Many thanks.
John
1. Windows XP Pro does NOT have a shortcut set up in the Start menu or Program Files, to launch NetMeeting please click Start> Run
2. At the Run Window type conf.exe then click OK
3. Fill out the info
· First and last name
· E-mail address: use you AdFarm Email
· Location (your location)
· Comments leave blank
4. Click Next… Do NOT check the boxes, Select Local Area Network…Keep both check boxes selected… click Next… Click Next again…
5. Make sure speaker volume is set to a comfortable level then click Test you should get sound, adjust accordingly.
6. Your camera should have a microphone attached you will see the Record Volume when you say “Testing 1… 2… 3… Testing”
7. Click Finish… NetMeeting will launch…
8. Enter the appropriate IP for Video Conf under quick connect and call
John S (LVS - Calgary, AB)
Posted on Dec 12, 2008
  • SHAOLiiN Dec 12, 2008
    Note for External connections into Video Conf from Netmeeting meeting attendees whom are not prt of the LAN/WAN (user accounts) will ahve to set up via External IP the above solution si for internal and those who can VPN internally for authentication.
    Steps are the same use quick connect, enter the external IP and click call.
огромное спасибо, очень выручили, только с камерой в ноуте не заработало, а а подключил внешнюю веб камеру и заработало, хотя продавцы сони утверждали что подружить Соньку ни с чем кроме соньки не получиться, СПАСИБО.
Posted on Jan 27, 2010
Connecting a EVI-D100 to a Macbook Pro Laptop Help.
Hi, I have a Sony EVI D100 that works. I have a Visca USB Cable and an s-Video cable and video cable. I will be connecting it to my MacBook Pro. What else do I need to use this Cam with my Mac to feed video to the mac? I also have a Mini Display Port To AV/CVBS/RCA/S-Video Converter Mac
Jul 29, 2012 | Sony EVI-D100 Webcam
Webcams for Apple and Windows PC
Nov 12, 2009 | Computers & Internet
When I am chatting on Yahoo IM and turn on my internal MacBook webcam, it works for exactly 1 munute and then goes black on the receiving end. Repeatable every time and always exactly 1 minute.
Maybe your internet connection can't handle the amount info being uploaded. ( by this i mean the fact that the cam filming and immediately sending all that over the internet to your chatfriends might be taking just a little bit too much of the upload amount you have.)
maybe it's caused by the Yahoo messenger, or maybe it's just your friends connections that's not heavy enough.
The easiest is to try to deinstall the camera and messenger software, reinstall them and reboot it all...
Hope this is useful, and greetings,
Olivier.
Oct 20, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
How can we connect the sony pcs-1 to a pc?
GO TO A SHOP AND GET THE CORRECT LEAD,OK,MATRICK.
Sep 28, 2009 | Sony PCS-1 (PCS1) Video Conference
How do I enable the inbuilt webcam on my DELL D430 laptop?
Hi scottie_dorn,
this isn't a webcam, it's an ambient light sensor, I'm afraid. Just to make sure: assuming that you're running a Windows-system, please open the device manager and have a look at "Audio, Video..." whether there is an entry regarding a webcam. I'm pretty sure, there isn't one... Greetings from Germany,
noris017
PS: Please don't forget to rate this solution after you've tested it out! Thanks in advance and have a nice day!
Feb 26, 2009 | Dell D430 Notebook
I have a 250 Gig WD hard drive originally hooked up to Mac OSX 10.5.6.  I put files on it and then a co-worker looks at those files on a PC. Now, she's given the drive back to me to add more files. These...
Greetings.
files bigger than 4 gigs cannot be save on fat32 drives. NTFS file system is capable of saving files bigger than 4 gigs.
The MAC - to PC did nothing to change it. It did not change while she look it at her pc.
If u want to be able to copy files bigger than 4 gigs to your drive, change the format to ntfs.
  • It is easy to convert partitions to NTFS. The Setup program makes conversion easy, whether your partitions used FAT, FAT32, or the older version of NTFS. This kind of conversion keeps your files intact (unlike formatting a partition). If you do not need to keep your files intact and you have a FAT or FAT32 partition, it is recommended that you format the partition with NTFS rather than convert from FAT or FAT32. Formatting a partition erases all data on the partition and allows you to start with a clean drive. Whether a partition is formatted with NTFS or converted using the convert command, NTFS is the better choice of file system. For more information about Convert.exe, after completing Setup, click Start, click Run, type cmd, and then press ENTER. In the command window, type help convert and then press ENTER.
Link to steps and other info
http://technet.microsoft.com/en-us/library/bb456984.aspx
Hope that helps.
Jan 10, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Logitech QuickCam Connect: Driver for Mac OS?
yes u can go staight to logitech web site and get the download for a mac
Jan 07, 2009 | Logitech QuickCam Connect Webcam
Webcam not working
hi,
what you can do is find out if your camera has an update device driver and check the device manager if there is any issues regarding your camera drivers and other drivers of your computer.
hope this helps.
Jan 28, 2008 | Lands Phones
DSC F55 - Macintosh
I don't think as yet that it is possible to hook up a DSC-F55 via a serial cable to a Mac. And that's a f#$%^ SHAME! So now i'm waiting for a coolpix 950, and there's a long waiting list. The only solution on offer here now (that's Europe i guess) is a pc-card reader for memory sticks, but it restricts you to a powerbook. Boooooh!!! I guess Sony and Apple aren't friends anymore. If anyone disagrees i'd like to know.
Sep 08, 2005 | Sony Cyber-Shot DSC-F55 Digital Camera
Sony PCS-DSB1 (PCSDSB1) Video Conference Logo
644 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
