CANON NP 6012 ERROR CODE
HI GUYS!
I HAVE AN OLD AND FAITHFUL NP 6012 THAT HAS REFUSED TO STAY TURNED ON ANDFLASHES ERROR CODE EO OR E0. I READ ANOTHER SOLUTION ABOUT PRESSING A RESETBUTTON BUT CAN'T FIND ONE ON MY COPIER. IS THERE A POSSIBILITY OF LIFE IN THEOLD DOG YET? IT MAY BE OLD BUT IT HAS BEEN GREAT FOR WHAT I DO.
I'D APPRECIATE YOUR HELP.
MANY THANKS
PETE
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
Most likely it is the fuser unit.
as soon as you turn on it does not rotate it gives you an error and turns off.
take out the fuser (where it gets hot at the exit) and check hte lamp (probably burnt out)
or the fuse
Posted on Oct 16, 2008
Why error e2
Posted on Apr 23, 2010
Kenmore elite dryer error code E0
E0 is an eeprom communication error. Disconnect power for at least 30 seconds. Reapply power an observe for at least one minute if code returns you cave a bad control board.Before replacing the board check for loose connectors.
Aug 06, 2014 | Kenmore Elite HE4 Electric Dryer
How can i reset my selex gr 1020 error code E001 once I turn on the unit the error will appear like E0 after 2 second 01 again then automatic turnoff the machine
A Selex is a old Canon NP 1020 copier. If I remember Selex is the government version of a Canon. The only way to rest the code is to repair the problem first. Odds are the fuser lamp is blown, it looks like a candy cane. It also could be the thermal fuse or the thermistor or it could be all of them. You may have a had time finding the parts. I was factory trained on this model 23 years ago. Good Luck
Jun 16, 2013 | Office Equipment & Supplies
Error E0
Canon Copier np7130F Error E0. Please give sugation above this problem solutions.
Oct 26, 2010 | Canon NP 7130 Black and White Copier
I have an E0 code
Check the main thermistor,the thermal switch,the heater lamp.This components it is in open circuit.Reset the error code in service mode.
Sep 27, 2009 | Canon NP 6551 Black and White Copier
Canon NP 1215s photocopier error code E0
did you check thermistor, I think that you have a problem with thermistor, not only thermoswitch! what about black copy - did you check is expo lamp (under the original glass) is lighting or not, if not - it's normal to have a black copy!
Success!
Jan 03, 2009 | Canon NP 6551 Black and White Copier
Canon Copier NP 1020 - error code E0
pretty much the same, the codes are good for several models not just one.
you need to find the other numbers to know exactly which code it is, press the start or stop key to see it display the other #'s.
fuser is on the left side if you replace the parts might as well replace the claws and oil roller.
"E000" Heater lamp, Thermistor, DC controller "E001" Heater lamp, DC power supply / AC Driver circuit board, Thermistor, DC controller. "E010" Main motor clock sensor, DC controller PCB, Main motor, DC power supply / AC Driver circuit board
Sep 16, 2008 | Canon Office Equipment & Supplies
Error code 99 canon E0S 450D
Try this:
http://www.richardsnotes.org/archives/2005/04/29/50mm-lens-contact-points/
Jun 14, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon np 6012
Getting error code e0 and 07, and flashing, what is that mean.
Jan 28, 2008 | Office Equipment & Supplies
Error "E0" on a Canon NP 7130
E000 on a 7130 is a lockout error it needs to be reset. you need to remove the control panel remove the 2 screws that attach it to the body on the left and right sides open the **** shell and pull toward you. Flip up on the top of the unit with the circuit board facing you look for two metal jumpers labeled jp103 and jp104 short across the 2 with a small screw driver to enter service mode( can be verified by an "F" in the display) power down the copier reinstall the control panel and reboot. If the fixing assembly is good the error will be cleared
Oct 29, 2007 | Canon NP 7130 Black and White Copier
399 people viewed this question
jasbo
jasbo
