Question about Kenmore 64732 Electric Dryer
WIRING DIAGRAM NEED A WIRING DIAGRAM FOR KENMORE ELECTRICAL DRYER MODEL#11060992990; NEED ASSISTANCE WIRING THE POWER CORD TO THE DRYER
  • 5,911 Answers
The following link explains the proper wiring scheme for installing a 220VAC power cord to an appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Make sure you also have a dedicated outlet and power source for your dryer. This means a single outlet with a single circuit breaker. Most homes are constructed this way to ensure safe operation of the appliance and to prevent improper loading. If you have questions, please let me know.
As far as a wiring diagram is concerned, most manufacturers place a schematic drawing inside the operator console of the appliance for troublshooting purposes. I hope this helps.
Posted on Oct 16, 2008
Kenmore Dryer Model #11060932990 Proper grounding when changing 4 prong cord to 3 prong.
According to the National Electric Code, you will need to install a grounding strap from the frame to neutral in a 4- to 3-wire conversion.
Jan 18, 2014 | Kenmore Dryers
Kenmore dryer 3prong cord installation diagram
if its a" flat cord" what-ever color jacketed 3 wire cord, the 2 outside wires are your 2 hot power wires they go to L1 and L2 on your dryer,the center is the N neutral wire and goes to the N terminal,usually the L1 and L2 are a gauge larger than the neutral: HINT: the center is normally neutral on both the cord and machines terminal board in the back of the dryer,there usually is a diagram on the dryer on how to install the input power at the place you hook up power
Feb 07, 2010 | Kenmore 62602 Electric Dryer
I need to connect a four wire cord without a manual where do the wires go?
Hope this helps, could use the model number thou,but usually the manufactor places a wiring diagram behind the panel for service technicians.
Oct 22, 2009 | Kenmore 800 6983 Electric Dryer
Kenmore Elite 110.7208201 won't heat up.
Hi
Please check the things that could stop a electric dryer from heating:
- House fuse or breaker (needs two of them), heating element, burnt wire, thermostat(s), thermal fuse (not all models), motor heat switch, timer, selector switch, burnt power cord/plug.
And also check the things that could stop a gas dryer from heating if you have a gas dryer:
- Glow bar igniter, thermal fuse (not all models), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 29, 2009 | Kenmore Dryers
Not heating
Hi
Things that could stop a electric dryer from heating:
  • house fuse or breaker ( needs two of them )
  • heating element, burnt wire
  • thermostat(s), thermal fuse ( not all models ),
  • motor heat switch, timer, selector switch,
  • burnt power cord/plug.
You can check these things using an ohmmeter/multimeter from here.
Things that could stop a gas dryer from heating:
  • glow bar igniter,
  • thermal fuse ( not all models ),
  • coils on the gas valve, gas valve, thermostats,
  • motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 20, 2009 | Kenmore 62802 Electric Dryer
Need to open the top to find the fuse
Two clips in the front - use a six in one tools to pop it loose
Nov 22, 2008 | Kenmore 63942 Dryer
WIRING DIAGRAM
The manufacturer normally places a wiring diagram inside the operator console. Remove the back panel and there should be a diagram taped inside. Some of these diagrams will show two circuits. One is for a gas dryer, and one is for an electric dryer. Make sure you reference the correct one. I hope this helps you. If you need further assistance please let me know.
Aug 13, 2008 | Kenmore 63942 Dryer
Correctyly wiring power supply to Kenmore dryer
A three wire pigtail is connected thusly. The two outer wires go to the two outer terminals on the dryer, the center lead goes to the center of the dryer terminal block. If its a four wire pigtail, the outer leads go to the two outer terminals on the dryer, the white goes to the center terminal. The jumper strap on the center is removed and the green goes to chassis ground.
Sep 16, 2007 | Maytag Neptune MDE7500AY Electric Dryer
Kenmore 64732 Electric Dryer Logo
540 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
