Question about Cuisinart CPT-60 Custom Control Total Touch 2-Slice Toaster
Cuisinart CPT-60 Handle falls off
I cannot get the carriage lever handle to stay on this toaster. I have taken the top off the toaster and discovered there is a little clear plastic piece that goes behind the carriage lever (inside the interior of the toaster.) I cannot position the white plastic handle so that it will stay on the metal arm. I can't figure out how to twist/turn the handle so that the little white prong fits into that clear plastic piece within the toaster. Help, anyone?
  • Anonymous Feb 10, 2009
    I have the sane problem.
  • Anonymous Mar 15, 2009
    Thanks for your question. I am having the same problem.
SOURCE: when i push the lever down to make toast, it does not stay
no solution, problem, my lever (sometimes) will stay down, sometimes not, but it makes a loud "ractething" noise many times when the lever is pushed down>
best, randy
Posted on Dec 12, 2007
venexcsd
  • 1185 Answers
SOURCE: my cuisinart cpt 160 toaster won't start
Do any of the lights come on ?
If not then have you checked the plug top fuse
If the lights come on and then when you press the lever down it does not latch a solenoid has gone open circuit
Good toasters can be fixed
Cheap ones go in the trash bin
Posted on May 29, 2009
  • 16 Answers
SOURCE: When I depress the carriage control levers they do
my toaster did this once, i suggest that you get a new toaster from a different company, because if you've only had the toaster a month
and its doing this already that's a crappy toaster
Posted on Apr 20, 2010
SOURCE: toaster won't stay in down position
We opened up our toaster and scraped some baked-on crumbs off the top of the electromagnet that controls the carriage catch. When we closed it back up, it worked again.
Posted on May 10, 2010
mc1bean
  • 3053 Answers
SOURCE: My compact 2 slice toaster
Hello, anton
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about toasters andpossibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/how-to-repair-small-appliances1.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
Lever won't stay down
They are disposable items these days, just buy a new one. They aren't made to be repaired.
Jun 10, 2015 | Cuisinart CPT-70 Classic Style 2-Slice...
Lever won't stay down. Have removed all screws and could take off top but handle on lever prevents this. How do I remove the end of the lever in order to get the top off to check latching mechanism?
My toaster turned out to have an electromagnet that makes its lever and the toast carriage stay down. It turned out that the problem with my toaster was that it was plugged into a faulty outlet. Unfortunately, I destroyed part of my toaster's darkness mechanism trying to understand its latching mechanism before I realized that it was not made like traditional toasters. So my first recommendation to you: try plugging it into an outlet that you KNOW works.
Feb 13, 2015 | Kitchen Appliances - Others
Lever will not stay down
There is a catch thatvis not free to move in place when pushed down. It may be jammed.
Feb 12, 2013 | Cuisinart CPT-70 Classic Style 2-Slice...
Toaster latch does not stay down on Cusinart CPT-120 compact two slice toaster
for Cuisinart cpt160: If the latch will not stay down it is because the electromagnet at the base of the toaster, which is supposed to activate when you push the handle down, is burnt out. I pulled my toaster apart and did a test of that mechanism and found that the solenoid was fried (open circuit). There are no replacement parts.
Jan 09, 2011 | Cuisinart CPT-160 Metal Classic 2-Slice...
The handle on the toaster popped off. the hooklike thing is still there and not broken. how do I get it to stay on?
Get a metal epoxy from the local hardware store for about $5. Most are heat resistant to 300 degrees (confirm on the package). Apply it to the cover according to the instructions.
Wish I did that when mine came off. I've lost it now and there are no replacement parts!
Dec 26, 2010 | Cuisinart CPT-60 Custom Control Total...
Apr 20, 2010 | Cuisinart CPT-180 Metal Classic 4-Slice...
Toaster won't stay in down position in order to toast - Cuisinart CPT-160 - although it will toast if I hold the lever down as it toasts
Dec 22, 2009 | Cuisinart CPT-160 Metal Classic 2-Slice...
My cuisinart cpt 160 toaster won't start
May 29, 2009 | Cuisinart CPT-160 Metal Classic 2-Slice...
When i push the lever down to make toast, it does not stay
This is a problem, our old toaster had this problem, and it would only work if we jammed the handle down, but don't try this, only because ours broke after we tried this, but if you can send it to the manufacturure, they should be able to fix this. If you don't what to do this, please phone me at 505 9181, but please call me from 8:00-10:00, 2:30-8:00.
Oct 21, 2007 | Cuisinart CPT-60 Custom Control Total...
4 slice toaster
open the unit. look for disconnected wires from sloppy factory
May 20, 2007 | Cuisinart CPT-140 Cool Touch 4-Slice...
Cuisinart CPT-60 Custom Control Total Touch 2-Slice Toaster Logo
107 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
