Sansa c200 earphone jack stoped working - Audio Players & Recorders
  • marvanw Oct 16, 2008
    Already tried 3 different sets of earphones and 2 external speaker sets. The right channel doesn't work at all, and now both channels are cutting off.
  • 103 Answers
Hi
this is a common problem. Try replacing the ear phone.
Posted on Oct 16, 2008
  • Hemant Ramyead
    Hemant Ramyead Oct 17, 2008
    You need to get a qualified person to replace the main jack in that case
Only one of my earphones work for my mp3 player
Make sure that you've pushed the earphone plug all the way in. Some Sansa players have very tight earphone jacks. If that doesn't work, it's likely that the player is broken.
Jan 28, 2010 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sound from 1 side only!
your ear input female jack is stripped try another new pair of earphones if not you may have to take it in for service.
Nov 05, 2009 | SanDisk Sansa E280 MP3 Player
Left side of earphones don't work
I have the same problem as well. you just have to take the headphones out, and not put them in all the way. just put them in partway, wait until you can hear out of both.
Jul 28, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
I NEED HELP!!!!!!!
buy new ones or plug it into something else and see if it is working. you can also wiggle the jack at the end and see if that'll work or go into music settings see if it can play the music or see if music player is turned all the way up.
Jun 30, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Music not coming from both earplugs.
Buy another- seriously. You can view this video if you want to try to replace the headphone jack, but you will probably cause more damage in the process:
http://www.youtube.com/watch?v=zgz8h8aHUDU
-Tha Mp3 Doctor
Nov 18, 2008 | SanDisk Sansa e250 MP3 Player
Only one side of my earphones work. I have tried several other earphones and when plugged into my sansa mp3 player that one side still does not work?
Headphone jack repair
· http://www.pcpages.com/thebishop/nomadfix/
· http://www.instructables.com/id/Zen-Micro-Headphone-Jack-Fix/
· http://www.noboundrees.com/micro_fix/
Jan 14, 2008 | SanDisk Sansa e260 MP3 Player
Sound Only Comes Out Of The Right Earphone
If its less than 1 year old, have it replaced. Its a loose connection on the circuit board. SanDisk Technical Support 1-866-726-3475 Best of Luck.
Sep 24, 2007 | SanDisk Sansa e200 MP3 Player
Headset jack
Ok often this is caused by one of the cables in the earphones breaking.. try another set. Sometimes it can be the socket on the unit breaking at the solder joint on the PCB, if it is, and ya can solder? it is a pretty easy fix. But I would "Punt" for a broken earphone lead.
Aug 08, 2007 | SanDisk Sansa c200 MP3 Player
One earphone works
i had the same exact problem with mine. Reading around it seems to be a common problem with the Sansa line. I opened mine up and found that one of the solder points that holds the ear phone jack to the main board had come loose. I soldered it back and it works like a charm. Pretty easy too. If you have a soldering iron, just open it up and resolder the solder point that has broken off. You can read instructions for disassembly here: http://www.anythingbutipod.com/archives/2006/11/sandisk-sansa-c200-disassembled.php When you have it apart, looking at it from the side, with the jack to the right, the broken point should be the rear (closest to the circuitry) point. You will see a very small, not sure what to call it, chip on the board you have to solder a connection to. here is a diagram: http://i42.photobucket.com/albums/e321/fuzzygoat/sansa-c200-disassembley-8.jpg Hope this helps.
May 10, 2007 | SanDisk Sansa e250 MP3 Player
Can't hear music from sansa
Hi. If you have to adjust your earphone (even if you used other earphones) just to get a normal stereo sound, then the problem is with the player's earphone jacks. If that's the case (and assuming the radio feature of the player also manifests the same problem), then you may need to call the tech support guys at SanDisk for advanced troubleshooting, or possibly replacing that player. I found their tech support contact number at their website upon consulting prior issues I had with my player. Here it is: 1-866-726-3475.
May 09, 2007 | SanDisk Sansa e260 MP3 Player
 Grubhead
Grubhead
