I ran out of black ink, bought a new HP-brand black ink cartridge, installed successfully, it prints fine now. Only problem, I still get a pop-up message every time I try to print that says "The black ink cartridge is low on ink". I know the black cartridge is full (it's new and prints well). Have already aligned, cleaned, reinstalled the cartridge several times, to no avail. How do I reset this message, or how can I disable the ink-level warning completely? I previously replaced the color cartridge and did not have this problem. Thanks!
SOURCE: Black ink stopped printing
Did you solve this problem, the exact same thing has happened with mine?!?
SOURCE: HP PSC 1510 will not print after new ink cart. was installed
You have to reinstall the printer drivers
SOURCE: HP 6310 printer says HP 95 tricolor is empty.
Ray,
It sounds like you need to replace the cartridge with a new one. The electronics may have went out. We see this usually during the winter months when the static electricity in the air is high and we shock the cartridge. I would also NOT recommend cleaning the head/jets of the cartridge with alcohol. The electronics are fine to clean with alcohol both inside the printer and on the c artridge, but the head will dry out. We recommend taking a damp warm wet paper towel, placing it on a protected surface, and placing the head of the cartridge on the paper towel until you see some ink appear. Then put it back in your printer and let the printer clean off the bottom. If the printer is not cleaning off the bottom of the cartridge, the printer cartridge wiper on the carriage may be broken or stuck.
I have this same problem and some sites said to uninstall the software then download the software from the HP site and reinstall it. So I am giving that a try tonight
I’m happy to assist further over the phone at https://www.6ya.com/expert/barbara_87cfe34e34050f26
SOURCE: hp psc 750 won't print with new color ink cartridge
To solve the
printing problem..
# Hold the cartridge upside down, with the
bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the
cartridge on the bottom (where the ink comes out). Wipe the printhead
horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure
the ink is flowing.
# Next, look inside the printer and locate the
carrier that holds ink cartridges. Caution: Make sure the cartridges are not
installed at this point.
1. Look for a shiny piece of metal underneath the
contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and
wipe along the bottom of the shiny metal piece. Note: You may need more than
one swab.
# Reinstall the cartridges, making sure you snap
them correctly into the printer.
Hope this help. Please
Rate My Response! Thanks!
Yes! I have the exact same problem! I have a older HP Deskjet 3845 printer and I just replaced both the color AND the black ink cartridges. The pop up keeps telling me that my black in is still low, and shows a picture of a cartridge with hardly any ink in it. The picture of the color cartridge shows fuller than it was before but never completely full even though I installed a completely full, brand new cartridge. I just bought these cartridges from Staples for about $30 and I KNOW they are new and not recycled refilled cartridges. How can we fix this problem? How will I know when these cartridges are actually running low next time? I don't want to just wait til it runs out! I may be working on something important and I don't want to wait until it's too late! HELP!
I have the exact problem--can anyone help!
