Question about Lexmark P4350 All-In-One InkJet Printer
Horizontal line print errors
Whilst printing, even on the printer test page, errors occur. Paart of the line is printed (horizontal) is printed, then a space and then the lower part of the line. Help Please.
    Genius:
  • 2,035 Answers
  1. Hold the cartridge upside down, with the bar-code label facing you.
  2. Take a damp paper towel and use it to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
  3. Continue doing this until the printhead looks clean.
  4. Then dab the cartridge on the towel to make sure the ink is flowing.
  5. Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
    1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
    2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
    3. And then perform This
  6. Press the Mode button on the operator panel until the Copy light comes on.
  7. Press the Menu button once to enter the menus.
  8. Press the down arrow button until you see Clean Cartridges.
  9. Press Select. The 'Clean nozzles' page will now print.
Posted on Oct 16, 2008
Horizontal lines on page
Your printer head - the ink cartridge in case of most HP deskjet printes, in most cases is defective and you need to replace it to have a clean print.
Anyway, read this tutorial, has some good tips:
HP Deskjet D2500 Printer Series Horizontal Streaks or Lines in the Printed...
For Epson printers, read this
Epson Stylus Color Ink Jet Printer
Epson Printer Horizontal lines
Same for Cannon priters
Horizontal lines when printing with Canon ip4500 Forum Thread
Aug 23, 2015 | Office Equipment & Supplies
Hp p4014n, erro 55,00,00 controlador, cc
55.XX.YY DC CONTROLLER ERROR
A temporary printing error occurred.
1. Turn the product off and then on.
2. Remove any third-party memory or USB
device, and then turn the product off and
then on.
3. Remove and then reinstall the formatter. (the formatter is the logic board)
4. If the error persists, remove the
formatter and perform an engine test***. If the engine test page fails to print,replace the DC controller. If the engine test page prints, replace the formatter.
***engine test
To verify that the product engine (all product components except the formatter, formatter DIMMs,
EIO products, and the stacker or stapler/stacker) is functioning, print an engine-test page. Use a small, non-metallic, pointed object to depress the test-page switch, which is accessible through a slot in the right-side cover.
The test page should have a series of horizontal lines.
A damaged formatter might interfere with the engine test. If the engine-test page does not print,
try removing the formatter and performing the engine test again. If the engine test is then successful, the problem is almost certainly with the formatter, the control panel, or the cable that connects them.
Jun 01, 2011 | HP LaserJet P4014n Printer
Horizontal lines (red) on first 1 - 2 pages of initial print-out
Do you refill ink tank? Print blank pages. Is there horizontal lines appear? It might be caused bay ink leakage. Check respiratory hole at ink tank and rubber seal at bottom of ink tank. Print blank pages until no horizontal lines and try to use new ink tank.
Aug 17, 2009 | Epson Stylus Photo 1270 InkJet Printer
Faint horizontal dark line about 2 1/8 inches down from the top
You can easily fix this yourself, one of the quickest ways to fix it is to print 10 doublesided blank pages and it will clean the inside of the machine for you and the line will vanish.
For further print quality problems on this machine follow these instructions to troubleshoot.
When troubleshooting image quality problems, it is important to understand the situations in which the problem occurs.
Print a copy of the color test pages to determine whether the problem is in one color or more than one color.
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Print Quality Problems], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Color Test Pages], and then press the [OK] button to print the test pages. If the problem occurs with one color on the test pages, perform the solutions for this problem. If the problem occurs in more than one color on the test pages, restart your search and select a case for the image quality problem occurring through all colors.
Mar 27, 2009 | Xerox Phaser 7400/DXF Laser Printer
Horizontal white lines through the text
Your ink cartridge (s) is dried up, even some new ones are dried up, even tho' they're sealed.
Some self-tests don't use black.
Sep 21, 2008 | HP DeskJet 6122 InkJet Printer
Xerox phaser 7700 having problems printing transparencies and accumulator belt problems
Hi xander4265:
I
Streaks in direction of paper travel
There are dark lines running along
the page in the direction of paper
travel from the leading edge to the
trailing edge (B-size print shown).
The printer displays no error code.
Note A-size prints are processed
through the printer with the short
edge of the print parallel to the
direction of the paper path --
making horizontal print artifacts
parallel to the shot edge of the
print.
B-size prints are processed
through the printer with the long
paper path -- making horizontal
artifacts parallel to the long axis
of the print.
1. Check the end of life for each of
the consumables by printing the
supplies usage page. From the front panel’s Printable Pages Menu, select
Print Supplies Page.
2. Run the solid fill test pages; From the front panel’s Printable Pages Menu,
select Service Pages, then select Print Solid Fill Pages. If the missing bands
only occur in a single primary color, replace the print cartridge of the affected
color.
3. Swap print cartridges and run another test print.
Note Under some circumstances, streaking may occur in the margin of
SRA3-size paper. This is due to the edges of the paper extending
beyond the end of the imaging components. print-quality in the
margins of SRA3 paper is not guaranteed.
4. Inspect the Accumulator Belt cleaner; replace the cleaner, if necessary.
5. Run the Remove Print Smears routine. From the front panel’s Support Menu,
select Improve Print-Quality?, then select Remove Print Smears.
6. Replace the Developer Housing Assembly (RRP 27, on page 7-171).
7. Remove the print cartridge and (with a flashlight) check for debris along the
edge of the developer housing.
3041-42
Leading Edge
hope that this will help you.
Sep 18, 2008 | Xerox Phaser 7700 Laser Printer
Prints Faint green horizontal lines
Go to control panel and printers and faxes and right click on printer icon then hit printing preferences, go to maintenance and do head cleaning cyles and print nozzle check. if it comes out fine trash and reinstall driver
download driver from support.epson.com site after selecting the printer mdel on the lists
Apr 12, 2008 | Office Equipment & Supplies
Horizontal line on prints
Put plain paper in the printer and try to clean the nozzles.
-Start->All Programs->Lexmark 5400 Series->Lexmark Solution Center->Maintenance->Clean to fix horizontal streaks.
Steve
Sep 12, 2007 | Lexmark X5470 All-In-One InkJet Printer
Printer
I need to know if this is a sudden occurence or has it happened before. Is cartridge new or refilled or older, and did it print right until now. Also need to know if you have made any recent system changes and if you run anti virus and spyware.
Mar 12, 2007 | Lexmark X1195 All-In-One Printer
Lexmark P4350 All-In-One InkJet Printer Logo
55 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
