Question about Directed 473T Remote Control
Need help i have a valet remote start alarm on my car made by Directed 477T & I think it automatically cut electric off the car, the alarm works fine but when I go to start the car there is no power
  • vedok Jan 18, 2009
    used remote starter hit brake before putting in key, car turned off and now it won't start
  • 344 Answers
Under the dash there should be 1 or 2 red wires going into the the 477T, take the fuse out of the holder and try to start your car with the key, if it still doesn't start there might be a start kill relay hooked to the starter look for a small black cube with 4 wires going into it, it will be hooked to your starter wire, if you use a jumper wire and hook it to pin 30 and 87 it will bypass the relay and your car should start
Posted on Jan 31, 2010
Is there another way to program a remote start remote, The way its suppose to work doesnt.:door open, ACC on, push valet then again and hold. I think the door is not hooked up to read open.
563T Your Valet Alarm W/Remote Car Starter - Dr.Detail
www.drdetailshop.com > MAIN > YOUR VALET
Featuring: Viper, Hornet, Directed Amps, Viper Audio, Compx Subs, Your Valet ... 563TYour Valet Alarm With Remote ... A Free Wiring diagram, Installation parts
Sep 24, 2015 | Televison & Video
Toyota Sienna 2004 already installed Valet 561R+556U model, All good ,except one thing (when I start engine with Valet remote , alarm system turn on too ( horns , lights))
only one thing to say here and that is ,---but you will not like it thats for sure --- take the side cutters from tool box and remove it completely ,they go wrong after a whaile as the microprocessors fail and the olny thing to do is cut it out ..
Oct 29, 2011 | Directed Dei Valet 561r Remote...
Car shut down , will no start, or reconize remote keypad
check your antenna, should be mounted on the windshield. unplug it for a couple of minutes and then plug it back in, then check the remote. make sure the alarm has power, try putting the alarm in valet mode, if it goes into valet with no problem then the alarm is fine, then you can re-program the remote. if it doesn't go into valet then the problem may be the alarm and not the remote. hope that helps, dave
Oct 11, 2010 | Directed Electronics 479V Remote Gen 2...
So I have a viper alarm system in my car and awhile ago the remote got wet, so in order to be able to start my car i had to disable the alarm by turning the ignition on and pressing that eraser like...
You have to turn off your ignition and immediately press that 'eraser like button'(valet switch) for a second and release it. Alarm will then come out of valet mode and your remote should work, if it's good.
Jun 01, 2010 | DEI Valet Keyless Entry System
2002 jeep grand cherokee with valet remote start. when remote start is activated jeep starts then shuts off immediatly
Apart from the inginition wires ( you must check if there are 12 volts), the alarm needs to read the tach reading properly from the car to stay running. If the tach rate is not learned by the system, it will cut out almost immediately. You need to ensure that this tach wire is connected to the tach under the hood. When this has been connected, you need to ensure that the alarm learns the rate. This can be done automatically on some models or manually on others. Ensure that the appropariate wire is connected to your tach wire; it should work properly after that
Jan 02, 2010 | Directed Dei Valet 561r Remote...
I have a 561r that was professionally installed and working fine for about a year. Now all of sudden my van will not fire or start the engine. The theft light continues to blink. I cant start the van with...
Try disconnecting the alarm putting in a valet mode and start the vehicle with the car key. If you don’t know how to put in a valet mode, check your alarm manual. After if the car start them the problem is the car alarm, make sure all the doors, trunk, hood are close if still not working check if the hood, trunk switch are working properly.
Jan 01, 2010 | Directed Dei Valet 561r Remote...
My valet remote control RPN491 Starts vehiclr and unlocks doors but will not lock doors do I need to reprogram remoteto unlock doors?
Ok you said "unlock doors' but you said it already unlocks the doors. This remote should lock and unlock door on same button, if you are describing the 2 button remote. If it is not then it could be alot of things. Does the alarm lock itself? Does the alarm lock the door when you turn on the ignition? More info is really needed. Like what veh and what model alarm.
Sep 11, 2009 | DEI Valet Keyless Entry System
Car starter not working
look under the dash for a small silver toggle switch....this is a disable switch for the remote start portion of the system..you may have kicked it / bumped it with your foot, causing the remote start portion to be deactivated. Just flip the switch the opposite way and try again..
Also, there may have been a pin style switch installed under the hood...Check to see if it is bent or broken, if it is, simply disconnect it and insulate the wire that was going to it.
This wire is used as a safety to keep the vehicle from remote starting while the hood is up..to keep people from being injured if the remote start is activated while the engine is being worked on.
Have whatever shop installed the system replace your pinswitch if that is the problem.
Dec 16, 2008 | DEI Valet Keyless Entry System
My car alarm is blinking but the remote doesn't work. I already replaced the battery to the remote so I know that's not the problem. If I open the car the alarm goes off and doesn't allow me to start the...
You need to first look under the drivers side dash area near the hood release/fuse panel area and see if there is a valet switch. The switch will look like a little toggle or a push switch. After you locate it, turn the ignition switch to the on position(dont start it) and flick the valet to the opposite position it is in now. If done correctly in most cases the red system light will stay a constant instead of off or blinking indicating you are in valet mode. Next try to start the engine. If this doesnt work you need to remove the alarm system and repair the ignition switch wiring or replace the electrical portion of the ignition switch. The aftermarket alarm cuts into the ignition switch wires and bypasses the start circuit through the alarm module. When disarmed the alarm completes the circuit and allows the car to start. Good luck hope this helps and please rate this.
Nov 05, 2008 | 1997 Nissan.5 Altima
Directed 473T Remote Control Logo
318 people viewed this question
Top Directed Televison & Video Experts
ted dux
Christopher Stearns
Are you a Directed Televison and Video Expert? Answer questions, earn points and help others
