Optical port doors on my av reciever ( sony ) broke off and now the optical cable does not have a tight fit
  • Gaspare Bianco
    Gaspare Bianco Jan 30, 2014
    The port door keeps the cable in exactly the right spot for transmission. It is a key element. The cable will probably not work without the door. You will have to use the conventional set up if available. I have not been able to buy this door. All the manufacturers want you to return the equipment for repair.
    Scholar:
  • 47 Answers
Hi vbuell!
On most AV equipment, the door on the optical port is there more to keep dust and debris out of the port than anything else. I suppose it could put a small amount of pressure on the cable end as well, but I don't think it should be significant.
If your sound quality has not deteriorated, then the optical cable is still working OK and I wouldn't worry about the situation too much. There are many ways that you could tighten up the fit, but most risk getting debris into the fitting, which is obviously not a good thing.
If your sound quality has deteriorated, I would first get a can of compressed air (you can get one at any store that sells computer parts for a few dollars) and blow out the "hole" where the optical cable plugs in. Plug in the cable again and see if your sound quality has returned. If so, you are good to go. If not, I'd make sure that your cable is working (if it's plugged it at the other end, the end that goes into the receiver should be lit up). If still no sound, you may need to take the unit to an authorized Sony repair facility, which you can find at www.sony.com.
Good luck, and I hope your problem is resolved. If you feel it is appropriate, I would appreciate a rating on my advice that I've given.
Bob
Posted on Oct 16, 2008
Cant get sound using digital optical cable with pd3000
IT DOES NOT LOOK LIKE THE RECIEVER HAS A OPTICAL INPUT YOU WILL HAVE TO USE AV CABLE STERO RIGHT AND LEFT FROM TV TO RECIEVER THEN CONNECT BLUE RAY AND GAMING SYSTEMS WITH THE AV CABLES
Feb 19, 2014 | Pyle PD3000A Amplifier
Ok so the issue is that after i have ran a hdmi cable from reciever to monitor, and 2 hdmi inputs (dvd and video2) into the reciever where im running a ps3 into the video2 port and foxtel/satellite tuner...
Try this, although recivers have video pass through, it is not the best option for video to your monitor. Depending on what you have for input/output on your TV/monitor, and, if you can, you should run all your video components directly to TV via(best)HDMI(video and sound) or, component and digital optical(best) or RCA, Then run digital optical out from you TV out to receiver in. You can use your monitors menu to chosse what you view and only have the onr input to you reciever. ASll you have to do then is go through you recievers menu to get the audio. Less connections less hassle. In other words, you would run your sat tuner to tv inputsat or cable, then dvd to dvd, PS3 to video 1 etc., on TV/monitor, then the single audio output to reciever.
Dave
Jul 03, 2011 | Audio Players & Recorders
I have an LG DVD Reciever HT462 which i want to connect to my PS3. My PS3 is all set up correct as I have spoke with Sony. I have the PS3 connected via a HDMI cable to my TV and an optical cable running...
It would appear from what you have said that you have everything connected properly. Maybe a silly question, but make sure you select the digital input on your LG to get the sound from the PS3. If there is still no joy, unplug the optical from the back of the LG unit. Look at the end of the Optical cable that should still be connected to the ps3. Is there what looks light a red light there? if so it means that the optical is getting to the LG system and the LG sytem's digital in port is Duff. If there is no "Red Light", unplug it from the PS3 and look directly at the optical out port on the ps3. Is there a Red Light there? if there is, you need a new optical cable. If there is no red light, you need to enable the digial output on the ps3. If you have and it's still not "red". the optical port is duff.
Jan 07, 2011 | LG Audio Players & Recorders
Sony strdh500 will not recognize sony ps3
your hdmi port doesnt carry audio to all speakers what is perfectly normal for low end receiver, hdmi pass through audio only
Nov 30, 2009 | Sony STR-DH500 A/V Receiver
I used an optical cable from my ps3 to my receiver but no sound
change the sound output to 'optical' on your ps3
system menu
Sound
Sound output
(select optical)
I think you may have to change the channel on your AV reciever to Input or audio or something
Jul 08, 2009 | Audio Players & Recorders
Can't plug optical cable on MDS-JE500
optical will work any way you connect................connect mini out( play mode) to cd-r rec (in) recording or cd player (out) to mini (swithch to record, optical/line in/mic) the optical cable you have should work if all connection are fitted well. i record cd to mini using optical and vice versa all the time. just make sure you are connected correctly to what you wanna do
Mar 01, 2009 | Sony MDS-JE520 Mini Disc Player
360 help
This is a picture of the HD AV cable:
http://secure.llamma.com/catalog/images/xbox_360_hd_cable_component.jpg
On the back of the part which connects to the 360, there's an optical output.
If you then get one of these leads:
http://www.thericheygroupllc.com/images/optical%20cable%20toslink.jpg
It should send the 5.1 digital audio from your Xbox to your HD. I'm sure your TV should have an optical input on it somewhere!
Jul 18, 2008 | Microsoft Xbox 360 Console
No digital to reciever??
This tv will only output the sound from a digital tv channel through the optical output when using the tv's digital tuner. So if you are connecting a DVD etc it will not output through the optical output on the tv. ONLY digital chanels through the tv's tuner will give you sound. Refer to the tv's owners manual for more info.
Dec 27, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Connect PS3 for playing/viewing blue-ray thru surround sound
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Oct 27, 2007 | Sony DAV-HDX500 System
332 people viewed this question
 Grubhead
Grubhead
