Question about Hannspree Televison & Video
Using LCD (32") as extended desktop (monitor) for Vista laptop
Hi. I have a Hannspree 32" LCD TV that I plan to use as a computer monitor to extend the desktop of my laptop (with Vista). I know this is possible because a year ago I got the same Hannspree TV (but an older version) which we use as monitor for the desktop.
Problem is that the image appears unstable and shakey. This may be becuase the only option for resolution is 1280x728. On the desktop, the resolution is set 1360x728.
Any ideas?
micromend
  • 748 Answers
SOURCE: Extended Desktop is set as primary monitor
Go to Start, Control Panel, Display, Settings. Here you can change the primary for the secondary and then selecting which will become the primary again.
Posted on Apr 02, 2009
dsacco86
  • 1077 Answers
SOURCE: i would like to register
Here's the Vizio link for extended service plans:
https://crm.admin.waca.com/WaCA/WarrantyCenter/registration/secure/Vizio/ESCLookup.jsp
And here's for registration for the TV.
https://crm.admin.waca.com/WaCA/WarrantyCenter/registration/secure/Vizio/Registration.jsp?masterModelOID=SF-1116689077-37635&purchasePrice=500
Posted on May 10, 2009
rencomp_sand
SOURCE: Extended monitor wont extend
can you now see 2 monitor properties i.e. 1 & 2... then identify running monitor ... if it is 1 then select 2 in properties and set it again to be used as extended desktop... open any application and pull or drag it holding it from title bar to the extended desktop....
Posted on May 31, 2009
dsacco86
  • 1077 Answers
SOURCE: Sharp Aquos Resolution
According to the manual for the TV, you need to change the resolution on the computer itself first.
The computer resolution should be 1024 X 768 at 60Hz or 1360 X 768 at 60Hz.
After the adjustment made on the laptop, then try the resolution change option.
Posted on Jun 12, 2009
  • 4 Answers
SOURCE: I connected my laptop to my LCD TV using VGA
Easy way:
Press and hold Fn key, and then look at the F1-F10 keys.. Most likely it is F7, and has a picture like a computer screen.
So, press and hold Fn key, and then press F7 (or whatever key it is for your laptop). This will change your "presentation" settings, and thus switch back and forth from laptop screen, laptop screen + external screen (TV), just external screen (TV).
If this doesn't work as you expect, just try:
Instructions for Windows XP:
Open the Display Properties window by:
Start -> Run -> %windir%\system32\control.exe desk.cpl,@0,3
(this is the same window where you can change screen resolution).
There you will see two or more "screens", labeled: 1, 2, 3.
Click on "1", and you'll see:
[X] Use this device as the primary monitor
[X[ Extent Windows desktop onto this monitor
Click on "2", this is your TV.. Mark
[X] Extent Windows desktop onto this monitor
Then change the resolution to 800x600.
Click Apply
=> now your TV should start showing you a picture.
You can move your mouse between the laptop screen and the TV screen.
If you want just the TV, you can make "2" to be your primary monitor, by clicking on [X] Use this device as the primary monitor.
Posted on Nov 04, 2009
Why is desktop green like theres way to much yellow hue
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
May 03, 2014 | Emerson LF320EM4 32" 720p 60Hz Class LED...
Screen keeps displaying "adjusting...."
- Flickering screen
- Dim screen
- Slow start
Apr 08, 2014 | Hannspree HANNS.G HU196D - LCD display -...
Dual monitor won't extend, it's clones the screen
Make sure the resolution is set up to split the screen.
Nov 11, 2013 | Acer Aspire 7741Z-4433 PDCW 17.3 Win7...
How do you get a pic to extend desktop to tv monitor using vha to vga cord? I had no problem when I used a s-video hook up. I plugged in the pc and tv using the s-video cable, Choose Display, extended the...
What is occurring is the TV monitor is extending your desktop, where what you were doing in the past is switching between the two. When you plugged the VGA cable in, what occurred is your desktop was increased to account for the size of the TV, and it is acting like a second monitor, If you go into the display properties on your computer you will see a monitor with a 1 and one with a 2. The monitor with a 2 on it is the television, and whatever side it is to the #1 monitor (most likely to the right) if you scroll your mouse to the right of the monitor on your computer you should see it appear on the TV, to play or have a window on your TV, simply click and drag the window into the TV screen Frame, and then maximize the window, this will allow you to continue to work on your computer monitor while the other program runs on the television. It's basically like having two monitors instead of switching between the two
Jul 23, 2011 | Dell Latitudeā„¢ D510 PC Notebook
Dual Monitors. #1 works fine. Plug inb #2 and #1 goes to sceeen saver and #2 stays blank.
Both monitors must be plugged in when the computer is started for the second monitor to be detected, and you must configure the second monitor once the computer has started
In windows XP: control panel -> display -> settings tab -> select second display -> check "extend my windows desktop onto this monitor" -> click apply
In windows vista/7: control panel -> adjust screen resolution -> select second display and then under "multiple displays" select "Extend desktop to this display"
Mar 08, 2011 | Acer AL1917 LCD Monitor
May 31, 2009 | Acer AL2016W 20" LCD Monitor
Monitor
Right click on your Desktop (depending on what OS your using) and go to properties! Click, on the TAB that shows monitor. See if any info is available, any problemd, email me!
Apr 06, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Connecting laptop to tv
1. If your tv has a PC input, use a vga cable, from any normal computer monitor.
2. If you use those HD connectors, match them to the correct colour coded inputs on the tv.
In each case, do all the connecting with the computer POWERED OFF. Then when connected, boot the computer, and allow Windows to auto-detect the 'new monitor', as it will 'see' it.
Then you shoud right click on your desktop, choose properties, and goto 'settings'. From there you will see monitors 1 and 2. click on the new monitor and 'enable' it.
You also have the option of 'extending' windows to the second monitor, as well as making this your 'default monitor'. Experiment to see what best suits your needs,
Erik.
May 16, 2008 | Dell Precision M60 Notebook
Televison & Video Logo
223 people viewed this question
Top Hannspree Televison & Video Experts
Are you a Hannspree Televison and Video Expert? Answer questions, earn points and help others
