Question about Bosch Refrigerators
The frezzer part on our fridge freezer seems to keep icing up a lot and water coming out of the bottom - do you know why this could be?
  • 943 Answers
Hi thanks for your question. the drain tube is clogged. turn off fridge for 24 hrs, pull fridge from the wall. remove back panel clean all coils. the drain tube is by the drain pan by the compressor. use a small hose to push up the drain tube and blow air up to dislodge debris, thanks the appliance doc
Posted on Oct 16, 2008
Issue with Kenmore Refrigerator/Freezer
ok,1st check on fridge side toward upper back of the top and feel for air coming thru, and there is another one down possibly behind crisper .I had this same deal. Had to do total defrost,, put food in cooler,, theres two blower fans in these types of fridges,,one in the bottom back,, and one in the back of the frezzer,, I used an old hair dryer and let it blow warm to top interior of frezzer,, careful not to let any cords hang/drop in any water!!,ok once done dry out as much water as possible, turn fridge on set both controls to 4,when fridge kicks on do the feel test,, you may need to close the frezzer door, air should be felt near top inside of fridge,if so than shut fridge side and feel inside frezzer near bottom and air should be felt,, side-by-side need to circulate air from frezzer to fridge, then back to frezzer
Jan 23, 2013 | Refrigerators
I have a ffa90 futre fridge & bottom frezzer. the fridge is frezzing the food in the door & in the fridge. have tryed water in botles & they get ice on it .in the door the food frezzers so
Find where the supply air is coming into the fridge part. It comes from the freezer and could easily be supplying -18 air direct to the door. This would give you a 2 in the fridge but anything in the direct air path could freeze.
Sep 07, 2012 | Hotpoint FFA90 Bottom Freezer Refrigerator
My Kenmore refrigerator is not cooling properly. Freezer portion works fine but not refrigerator. Came on suddenly.
I had the same problem. The frezzer worked but the fridge was not getting cold. What I have learned is that the frezzer make the fridge cold, so if the frezzer is working then something is blocking the cold air to get into the fridge. Most likely ice. The air come in at the bottom of the inside of the fridge next to the frezzer. Pull everything out of the frezzer, then unscrew the plannel that runs along the back and you see if there is ice. If so turn frezzer off and dry out the frezzer. I used hot water.
Sep 28, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water in fridge coming from freezer
the drain line in the frezzer is blocked
Jun 09, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
My chest type freezer ice up around the top but does not freeze except in the bottom portion
Check the gasket. Sounds like you have a leak somewhere causing the ice formations on the bottom. Easy way to check this is to have a steamer or a small pot of boiling water (steaming hot) while the frezzer is runing hold the pot of steaming water and watch the steam. You will see the steam going into the frezzer. BINGO leaking gasket. May need to replace the gasket or may beable to fix. You will see and know what to do. Keep me posted. Good luck.
Apr 06, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Bosch Frost Free Frdge Freezer Icing Up
Switch off fridge. Put a pedistal fan in front blowing into the cabinet and leave until all ice has defrosted. Locate the drain hole in the back of the freezer compartment, try to defrost ice which blockes up about the first inch or two of this pipe. If water does not run through you need to force it through with a turkey baster. This should sort your problem. ratemeplease
Mar 12, 2009 | Freezers
Freezer ices up on bottom where the drain outlet is
clear it again and then go underneith and make the drain hose to shape like a j-trap and it will fix the problem ,,, if you have to, cut a piece of clothes hanger and slide it up the hose and then shape it / larry
Nov 29, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Water dispenser / ice maker whirlpool fridge frezzer
Check that you haven't turned the ice maker off in the menu.
thanks J
Jan 15, 2008 | Freezers
Refrigerators Logo
115 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
