Question about HP Computers & Internet
Hp1210 printer would not respond to print function.Tried everything but no success. It would print when making copies. Finally deleted program from computer with intent to reinstall only to find software disc missing. Can you help???
  • 1,901 Answers
Here's a link to the HP support page for your printer. Once there click "Software & Driver Downloads". You will have to select your operating system on the next page and then select the software you need/want.
Posted on Oct 16, 2008
Lexmark X4550 Scanner not working
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 05, 2012 | Lexmark X4550 Multifunction Wireless Color...
HP J4680- change copy settings so printouts are fast draft
Change settings and copy from HP Solution Center
  1. Open HP Solution Center.
    • Windows 2000: Click Start , click Programs , point to HP , and then click HP Solution Center .
    • Windows XP: Click Start , click All Programs , point to HP , and then click HP Solution Center .
    • Windows Vista: Click the Start icon (c01319360.gif ), click All Programs , point to HP , and then click HP Solution Center .
  2. Click Make Copies . The Copy window opens.
  3. In the Paper section, click A4 on the Size drop-down list.
  4. In the Start Copy section, click Black or Color .
  5. In the new window you can also change the copy settings
Jun 21, 2009 | HP J4680 Office Jet All-In-One Printer
Communication error
Click on start-control panel-printers and faxes. Do you have more than one copy of the printer installed? If so, my advice is to uninstall them all and then do a new installation. But FIRST, make sure there are no jobs left in the print queue. Double-click each printer icon in turn and delete/cancel any print jobs listed. Then delete each "copy" of the printer and finally uninstall the printer using the Control Panel-Add/remove Programs-Epson Printer Software. After you have done all this, turn OFF the printer, reboot the computer and then re-install the printer. Make sure you keep the printer turned off until the installation program asks you to turn it on.
If none of this helps or is appropriate, or you want further information, please report back.
Feb 06, 2009 | Epson Stylus C46 InkJet Printer
LaserJet 1100 printing problem
did you select the correct printer on the print details screen? also try go to the conrtol panel and delete the hp prinret program then re install/download it on line from hp.also if when you get it going if it feeds more than one piece of paper at a time they make a kit to fix this{its a little piece of plastic}. also if you cant find the program in the cp you may have deleted it al ready, just go downloaded it. good luck..
Jan 14, 2009 | HP LaserJet 1100 Printer
Won't print. Red light blinking
Reboot your computer and power down your printer. Leave them off for about 30 minutes or even overnight. (In other words, leave the computer and printer off more than a few minutes--some of the printers take more than 5 minutes before they'll clear their memories--a quick reboot won't do it.)
When deleting print copies it is safer to use the delete button on the printer than to delete from your computer, as then the copies don't get hung up in spooling.
I've had to do this a few times with Vista and printers, as things get held up in spooling on a regular basis.
Jan 05, 2009 | Brother HL 1440 Laser Printer
I have a c4200 hp Printer cc200-90006 i need to know how to get the printing larger.Can't read my bankstatements to small when I try to copy.
Make sure you have the proper drivers installed for the printer, then cut and paste the information into a word processor or similar that accomidates the desired print format.
Finally, change the text size and print.
The issue is not with the printer, but the program you are using to facilitate the print job. If this is a web based program, look for a "Printer Friendly" print option on the site.
Alternately, you may have limited success in changing the text size under "View" in your browser, and try printing with the larger text size selected, and in use. If truncating occurs in the printing, then you will have to cut and paste the text into a manageable format, like a Word Processor program.
Nov 19, 2008 | HP Office Equipment & Supplies
Can not print at all. Tried command prompt, test page, status of printer is online also checked printer port and restarting both printer and computer,etc; I'm still unable to print. printer does not...
Not that it is a help for your problem but the file name should be PSW_RE.DLL - a dot belongs before the '.DLL'
If you haven't tried it yet, delete the printer from the 'Printers and Faxes' folder in the Control Panel, make sure the printer is connected and turned on, then reboot the computer.
This will force Windows to reinstall drivers for it and should return functions.
Aug 20, 2008 | Lexmark X1240 All-In-One InkJet Printer
ImageRunner 400S works, but prints a blank page
check the drum is seated well or not,check the drum drive lock, check the drum is rotating freely or not.check the chargin g rollor are seated well or not
finally replace the drum and see the result.
best of luck.
Aug 13, 2008 | Canon imageRUNNER 400S Copier
Computers & Internet Logo
32 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
