SimpleDrive ExHD keeps disconnecting automatically.
I have a SimpleDrive external hard drive, model #96300-40001-001, 80g capacity. I have had it for several years, but recently it began disconnecting while in use. I do not keep it on all the time, only when I need to transfer files. I tried to replace the USB cable but when I did the new cables (I tried two different ones) seemed to make things worse. With one I just got a message stating that my computer could not read the connected disk and with the other the blue light (signaling activity) came on and stayed on (it usually flickers and dances while reading the disk). I am using a Mac Mini Intel Core Duo 166mhz with 2g RAM.
I've wondered if perhaps it takes a special cord, but the writing above the USB site just says USB.
  • lefreak9 Nov 10, 2008
    i have the same problem with my memorex ultra traveldrive.
    trying to look for answers. its random. however... when i also plug in my cell phone via usb... there is a 50/50 chance it will happen right when i do that. but not all the time. its very confusing. it soiunds like the drive isnt getting enough power..
    anyone know for sure?
SOURCE: Need to know where to purchase SimpleTech 96300-40001-001 12V 2A AC Adaptor
My AC adapter is fried too and I have only used this maybe a dozen times in the last year.
Posted on Aug 19, 2008
ashishd19
  • 35 Answers
SOURCE: SimpleDrive I cannot retrieve files; Model No. 96300-40001-001
I feel the problem can be something else as well.
The message "Photo Gallery can't open this picture because it might have been deleted or is in a location that is not available" can be because the Photo Gallery program that you use to view pictures in your computer.
First, try this, right click on the picture and click on "Open With". This will give you a list of all programs.
Here, you can select "Windows Picture and Fax Viewer" and place a check in the check box below that says "Always use this Program.." and click OK. See if this works.
I would also like to know if you are able to open other files on this drive except picture files.
Also, the document that you are trying to open, what's the file type for this document.
You can try one more thing that will help us to isolate the issue.
Please note the next step we are going to do is just a diagnostic step and we will revert back to the original settings after this step.
  • Go to Run and type MSCONFIG and click OK
  • Now on the new window that comes up click on a tab at the top that says Services
  • At the botton check the box that says "Hide All MS Services" and click "Disable All" on right
  • Now go to last tab at the top that says "Start up" and click "Disable All" at the bottom.
  • Now click OK at the bottom.
  • It will ask if you want to restart or exit without restart.
  • Click on Restart.
  • Now your system will restart.
  • Once you come back to Desktop you get a message that says "Sys config was used to make changes to your system.
  • Click OK here and it will again open the Computer Management window.
  • Again go to the Services tab, check "Hide All MS Services" and this time click "Enable All"
  • Next go to the "Start up" tab and click "Enable all" here as well.
  • After this, click OK and this time click "Exit without restart" (now settings will be restored whenever you restart the system)
Now go ahead and try to open your pictures and documents to check if its working.
If not, then try the fixes provided by other friends above.
Even if it works after MSCONFIG, that will show that there is some other program/spyware creating this problem and in that case try uninstalling any recent programs you installed and Run the complete virus and spyware scan.
Please let know if you need any further help.
Posted on Nov 21, 2008
  • 7 Answers
SOURCE: Light doesn't turn blue at all
Plug it into another computer if possible, clear ALL files on it.
You must of been sending something to it when you flicked the switch, they would normally go off straight away.
(Backup on the other computer first)
If this does not work then you may want to see if you can see a usb stick in your USB ports. If you can it's a fault with the harddrive, nothing else you can do.
Posted on Jan 14, 2009
SOURCE: USB external hard drive driver
If you go into Computer Management and go to Storage > Disk Management. You'll see the partition there. Right click on it and assign it a drive letter. You will be able to access it from there.
Posted on Jan 30, 2009
chrisy3000
  • 63 Answers
SOURCE: External Hard Drive Not Recognized
you may have to download a new driver, but sorry to say that the drivers ive only been able to find is for windows nothing for mac pcs, its possible to try the mac website and see if they have and drivers to download, i will have a look and see, please let me know if you are able to find anything, good luck , thanks
Posted on Dec 12, 2009
When I access properties, it only shows 32GB of total storage capacity, not 250GB...any ideas why?
Probably that your motherboard is not able to recognise a drive that big. See if there is a Firmware update? Follow the instructions VERY carefully.
Aug 18, 2015 | SimpleTech SimpleDrive 250GB, 7200RPM,...
Seagate Stay3000102 ExHD Problem
Download testdisk and run it to see if it recognised in the list. If so use the intel option to find a boot sector
Jun 07, 2017 | Seagate STAY3000102 Expansion 3TB 3.5" USB...
Hello , Are there drivers for Vista available for the Simple drive 160gb external drive Model number 900000-40479002 FV-U35/160
Once plugged into your computer, Automatic Update should find the drivers automatically and install them for you.
May 02, 2011 | SimpleTech SimpleDrive 160 GB External USB...
My SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive suddenly disconnects a Reconects again....
You may have a power supply that is defective or is failing. Try another power supply, 12V, 2A, center pin positive.
Jan 24, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
Device no reconized , my W7 don't want install drivers for simpledrive 640 GB pinifarina
The usb device not recognized error generally means the right drivers are not present on the computer. I would expect that Windows 7 can recognize most external HDD automatically, but you might need to install a driver for it.
But try the disk on a different USB port, or even computer, to see if it still works properly.
Jun 28, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
SimpleTech SimpleDrive 640 GB external USB harddrive wont turn on
Loose connection inside the Drive case. Remove drive and check internal wiring.
Dec 23, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
SimpleDrive External Hard Drive
If you click on the apple logo, top left of scree, select force quit and then click eject.
Disconnect the drive and reconnect it. Wait for the drive to show in Disk Utility and select Mount for use in your Mac. Not Dos!
Sep 30, 2017 | SimpleTech SimpleDrive...
HD doesn't show up!!
Hi
please goto utilities and diskutilities and check the dd is shown over there if yes just try to select the hdd an verifiey the hard drive and say repair it should be fine unless there is any hard ware problem
thanks
Jun 09, 2008 | SimpleTech SimpleDrive Pininfarina 500GB...
Computers & Internet Logo
347 people viewed this question
David Payne
David Payne
