Question about Neff 24 in. S5456 Built-in Dishwasher
Neff dishwasher door - think the spring has gone
The door on my dishwasher appears to have lost its spring as when you open it, it goes all the way down - I want to try adn fix it myself - any ideas?
  • M CONDON Oct 16, 2008
    I have a NEFF dishwasher and the door, when I open it, doesn't stay horizontal but flops further down - presume that the spring has gone - any idea how to fix it please
  • 258 Answers
I have just done this on my own dishwasher, and managed to bend the next curl of the springs to replace the broken ends, see instructions and pictures here:-
http://www.howtofixanything.co.uk/howto-260.html
Posted on Jan 15, 2009
Deactivate childlock on fully integrated neff dishwasher
If door won't close and you don't have a child-lock, just push the door closed a lot harder than you normally would - NEFF manual says to do that, and it worked for me! I think it just forces it to engage and 'releases' the catch, as after that it closed with just normal pressure applied.
Apr 09, 2012 | Neff 24 in. S5456 Built-in Dishwasher
Door Open but latch in closed position - HELP!
You need to operate the door release handle at the same time as applying pressure to the latch you can see just inside the door (imagine which way it would move if the thing was working as designed), the tech has possibly simulated a door closed position for testing purposes.
Apr 22, 2010 | Neff 24 in. S5456 Built-in Dishwasher
Frigidaire dishwasher door squeaks when opened and closed
I had the same problem and this worked like a charm:
http://www.blog.applianceoutletservice.com/2008/12/frigidaire-dishwasher-door-squeaks.html
All you'll have to do is take off the kick plate, actually remove the cords, and lubricate with soap (lower tech than spray silicon, but it's worked so far...)
Aug 22, 2009 | Frigidaire PLD4555RFC Dishwasher
Neff dishwasher door problem.
The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
May 21, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Right hand door spring appears to be shot -
It sounds like the spring is dislocated. May just need putting bck in the right place.
May 02, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Door spring does not work.
bryan,
I do not have a place to order parts for a Neff dishwasher, but I know these dishwashers have springs in each hinge that will wear out/break over the years.
Replacing those springs will stop the door from drooping open.
Good Luck!
Apr 05, 2009 | Neff 24 in. S5409X0 Built-in Dishwasher
Neff built in dishwasher
these arms rotate only by water jetting out of angled jets at the end. it is likely that these jets are blocked - not always obvious
Nov 10, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Neff integrated dishwasher
there are some screws inside the door, around the edge. These would be the first to undo then I think the door would have o be pulled up slightly to relaease.
Mar 28, 2008 | Neff 24 in. S5443X2 Built-in Dishwasher
Adjusting the door on a neff dishwasher
I have the same problem with my newly installed Miele integrated dishwasher. The door does not stay open when you are trying to load dishes. I heard that there is an adjustable internal mechanism to adjust the tension on the door. But, I am still working on solving my problem.
Mar 16, 2008 | Neff 18 in. S5943 Slim-Line Built-in...
Microwave door hook broken
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Oct 20, 2007 | Microwave Ovens
Neff 24 in. S5456 Built-in Dishwasher Logo
587 people viewed this question
Top Neff Dishwashers Experts
Cesar Quant
Cesar Quant
Michael Galve
Michael Galve
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
