Question about HP LaserJet 4350 Printer
HP LaserJet 4350 started printing slow for multiple users. It worked fine before today. We are on a Novell network. Printer drivers in the environment haven't changed.
  • Paul Douglas
    Paul Douglas May 11, 2010
    How much memory do you have in the printer. you can print a configuration page and it will tell you or you can go through webjet admin. Just type in the IP address of the printer in the URL section of your browser and you can access the config from your office. You may have to add more memory.
    Genius:
  • 2,120 Answers
Set to Print directly to printer.
Posted on Feb 06, 2009
Slow printing
Slow printing I have a Laserjet 4200
Jun 26, 2013 | HP LaserJet 4200 Printer
LaserJet 4350 Printer: HP 4350 printer, 49.2F9D service error...
1st thing to do is upgrade the firmware. Go to hp.com and look for the software and drivers. Drill down to the firmware and read the instructions.
May 16, 2010 | HP LaserJet 4350 Printer
How to share hp laserjet m2727nf in network
Easiest way is to connect the printer to a router as this printer has a built in network card. Print out a configuration report and check to see if the printer configured an ipv4 address. Once that is ready add a network printer on the other computers, this will allow for multiple users to use the printer without slowing any of the computers up.
Al
Eliteprintersolutions@gmail.com
Apr 10, 2010 | HP Laserjet M2727nf Multifunction Printer
Print job stops HP 4350
iPAQ hp 4300 palmtop broken screen
Jul 14, 2009 | HP Computers & Internet
Hp4350n
Set it in JetAdmin.
Jan 15, 2009 | HP LaserJet 4350 Printer
Printing problem
ISSUE: A blank page prints after every print job using an HP LaserJet series printer. SOLUTION: A separator page may be turned on in the printer driver, within the application, or on the network. Try printing from several applications. If a page prints out in only one application, that application may have a summary page selected to print out. If a page prints out from different applications, a separator page may be turned on in Windows or on the network. Use the following sections to turn off separator pages. Windows 95/98/Me Follow these steps to turn off the separator page in Windows 95/98/Me:
  1. Select Start .
  2. Select Settings .
  3. Select Printers .
  4. Highlight the appropriate HP LaserJet printer icon.
  5. Select File .
  6. Select Properties .
  7. In the section labeled Separator Page, select None .
  8. Click Apply .
  9. Click OK .
Windows NT 4.0/2000 Follow these steps to turn off the separator page in Windows NT4.0/2000
  1. Select Start .
  5. Select File .
  7. In the Advanced tab, select the Separator Page button.
  8. Delete the location for the separator page.
  9. Select OK .
Windows XP Follow these steps to turn off the separator page in Windows NT4.0/2000
  1. Select Start .
  3. Select Printers and Faxes .
  5. Right-click on the highlighted printer icon and select Properties from the Advanced tab.
  6. In the Advanced tab, select the Separator Page button.
  7. Delete the location for the separator page.
  8. Select OK .
Software or applications See documentation for the specific application that is printing a separator page. The following steps are an example of how to turn off the summary page in Microsoft(R) Word 97:
  1. Open Word 97 .
  2. Select File .
  3. Select Print .
  4. Select Options .
  5. Deselect Document Properties in the Include with Document section.
  6. Select OK .
Novell environments Banner pages can be sent to the printer in several different ways in a Novell environment. The following instructions detail several ways to disable the banner page. NOTE: Banner pages can also be sent from the HP Jetdirect device itself. This page can be enabled and disabled through a telnet session to the HP Jetdirect device. The telnet banner will only print in an lpd/unix ® environment. Novell's Capture Command To disable a banner page using a Novell DOS capture command at a system prompt, type the following commands: capture L=x Q=queuename NFF NB NT TI=x where:
  • L = x -- The value of x would be 1, 2 or 3 depending on the lpt port being used.
  • Q = queuename - The value of the queuename would be the Novell queue setup for this printer.
  • NFF -- No form feed.
  • NB -- No Banner.
  • NT -- No Tabs
  • TI = x -- The value of x would be the timeout amount in seconds. NOTE: If the client workstation is restarted, and if a capture command is part of a login script that is being used, these settings will be reset.
Printer Properties The banner page for Novell networks can also be enabled or disabled in the Printer Properties using the following steps:
  1. To open the Printers Folder ; click Start , Settings, and Printers .
  2. Right-click the appropriate HP LaserJet printer icon and select Properties .
  3. Select the Printer Settings , or Capture Settings tab. The banner page can be enabled or disabled here.
NetWare Clients Follow these steps to disable the banner page for Novell NetWare clients:
  1. Right-click Network Neighborhood and select Properties .
  2. Select the Configuration tab in the Network window.
  3. Highlight Novell NetWare Client and select Properties .
  4. Select the Default Capture tab. The banner can be enabled or disabled here.
Feb 23, 2008 | HP LaserJet 1010 Printer
Hp LaserJet 5 si
Check the print processor settings in the advanced tab of the printer properties. This should be set to Winprint, and not anything else.
May 01, 2007 | HP LaserJet 5si Printer
Hp laserjet 4350 printing slow down
Look on the left side of the tray. There should be 3 white fingers that stick out. Make sure they aren't broken or out of place. Also slide the paper size lever and make sure they work properly. There is also a custom and standard switch. Try to print out of the MP tray(fold down tray). If it prints normal speed, you probably have a problem with the tray.
Nov 15, 2006 | HP LaserJet 4350 Printer
HP LaserJet 4350 Printer Logo
387 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
