By Bouncy - usenet poster
I currently use a Win98SE system and backup the 80Gb HD to an identical drive
in a removable caddy using Drive Image Pro. This system works well for me, if
the first drive fails (and it has), I just install the backup unit as the
primary drive and everything is fine.
I am now considering a new PC with XP as O/S, my question concerns the hardware
checking XP does on the PC, will repeatedly swaping the removable drive cause
me any problems with XP? And will I still be able to simply substitute the
backup drive for a failed primary?
Keith Davison
Solution #1
posted on May 28, 2006
Melissa - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Hehe, the old saying, if you want to something right you have to do it
yourself, is very true. :)
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Phoebe - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
I just went through this because I thought my old 80G was
dying (high pitched whine that varied irregularly in volume
developed suddenly).
Depends on how lucky (and knowledgeable) you are. I did
just what you are talking about. Couldn't get my system to
clone the old 80G on to a new 120G. It finally did, but I
still don't know for sure what the problem was. Second, I
cloned the old 80G onto a new 80G, but it took several
tries. I had originally tried with the Western Digital's
Data LifeGuard Tools, which copied the data ok, but would
not make a bootable drive. I think I managed to mistakenly
put EZ boot on the original 80G, and that may have caused
most if not all of my problems with cloning to the 120G and
definitely caused a problem with cloning to the new 80G.
Other possible problems on the original 80G may have been
fixed through defragmentation and various checks.
Both the new 80G and the 120G, will boot fine now. However
a couple of extra lines were put into the boot.ini on the
120G (probably by some stupid thing I did). The system then
thought that there were two operating systems and ask if I
wanted to boot with XP. After removing the 2 extra lines,
it no longer asks that question.
These drives were swapped in and out, in various
combinations, many times. Other than the problems stated
above there have been no problems with XP. I have XP Pro,
and used Partition Magic and Drive Image in my attempts at
cloning. The final clones were made with Drive Image.
I would say that if your system is in good shape and you
have a clue what you are doing, you probably won't have any
problem. BTW, Gateway told me I wouldn't be able to clone
the drive and would have to reinstall the software.
Cheers.
Cheers.
Suggest a new solution for this problem
Post a New problem for Gateway 80G / 80GB for laptops /
Email this problem
Email this problem
Can you Help with these Hard Drives problems?
Repair Service
Find Hard Drive Repairman Near You:
