Question about HP LaserJet 1020 Printer
Usb device not recognised HP 1005
Hp 1005 was imstalled and worked fine but after about 2 weeks of use a "usb device not recognised message appears"
reinstallation did not help.But when istalled on another machine it worked fine
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 145 Answers
Version of your OS, please... 1. replace USB cable 2. uninstall last updates for your OS
Posted on Oct 16, 2008
Hp 1005 Scanner error 20 please suggest the problem
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
If a surge protector is being used, remove it. Plug the device directly into the wall socket.
Use thepower switch to turn the device on.
Jul 08, 2011 | HP LaserJet M1005 Printer
We have had this HP printer for under a year, and it has worked perfectly. The last time we tries to print it gave a message that USB device has malfunctioned and the computer does not recognize it. we had...
Printer's USB port is probably bad.
Best thing is to contact HP and Have them repair or replace it.
  • Technical support in English and Spanish-just call 800-474-6836
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
    Thanks, Joe
    Feb 01, 2011 | HP Officejet 6500 Wireless All-in-One...
    When i attach my 4gb kingston usb then the usb do not work and a message appears that ,please insert a disk into drive G PLEASE SOLVE MY THIS PROBLEMM I AM VERY THANKFUL TO YOU
    1. Download and install the HP Drive Key Boot Utility
    2. Open the desktop icon and select the correct flash drive under device
    3. Select the file system you want to format to (FAT, FAT32, NTFS)
    4. Tick Quick Format
    5. Click start
    6. Officially this software (HP Drive Key Boot Utility) is meant for HP disks, but unofficially it seems to work fine at formatting most flash media, even digital camera cards.
    Aug 24, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
    When i connect the printer hplaserjet p1005 using window xp it says usb device not recognised
    This error gets due to of printer usb cable problem. If the cable is good, check your usb post, it means some voltage problem in udb port, last one drivers.
    Try to download drivers from hp.com of other websites and in stall it.
    http://go4download.com/hp-laserjet-1005-printer-drivers
    http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=214539&lang=en&cc=us&prodTypeId=18972&prodSeriesId=240170&taskId=135
    May 20, 2010 | HP LaserJet 1005w Printer
    HP 1005 Scanner error 6
    dear Sirs i have HP 1005 did't work and have this message Scanner Scanner error 6
    please if you can help me
    Sep 07, 2009 | HP LaserJet M1005 Printer
    Printer not working
    • Unplug the printer cable from the computer.
    • Unistall the printer drivers from Device manager and also unistall the all the printer appications
    • restart the computer
    • try to download drivers from the website
    • after installing the cannon drivers and software it will ask you to connect the printer.
    • then you can connect the printer and print a test page.
    Hope this help. Please Rate My Response! Thanks!
    Prem
    Mar 02, 2009 | HP Color LaserJet 2600n Printer
    HP Solution Center No HP Devices Detected
    Try this
    1.Right click on MY computer ->Properties->Hardware->Device manager.
    2.You will get Device manager window popping out.
    3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
    4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:wE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : HP DESKJET F2100
    5.Disconnect the USB and reboot the PC.
    6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
    Thanks
    Riz
    Jan 03, 2009 | HP Photosmart C8180 All-in-One InkJet...
    Normal 0 Could have a corrupt driver.
    Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
    Hope this helps. Bud
    Dec 30, 2008 | HP LaserJet 1005w Printer
    USB to Ps2 keyboard adapter
    i think your usb to ps2 connector is faulty.
    change it and try again
    Apr 01, 2008 | Computers & Internet
    HP LaserJet 1020 Printer Logo
    113 people viewed this question
    Ben Johnson
