Question about Roper RGX4634KQ Gas Dryer
Roper gas dryer mdl RGS7646KQ2
Dryer will heat up when started after burner kicks off It will not kick burners back on. If you let dryer sit for awhile it will do the same thing. all sensors have been replaced in back and flame sensor also still no luck. Could it be the colis on gas valve? My email is keith.apgar@yahoo.com Thank you for your help. Keith Apgar
  • Antagonizer Oct 17, 2008
    Thanks dude!! I replaced everything else so I went ahead and replaced the coils too and it worked ... Too bad I didnt start there first
  • 943 Answers
Hi keith. yes replace the 2 coils on the gas valve. it will solve the problem. thanks the appliance doc.
Posted on Oct 16, 2008
  • john gagnon
    john gagnon Oct 17, 2008
    good glad it worked please rate me its a fixya. thanks
I have a Roper gas dryer (RGS7646KQ2) which is not heating up to dry clothes. The drum turns and the timer works as well. It appears to be acting normally, except it is blowing cold air instead of warm...
You have a bad thermostat, flame sensor, thermal fuse, gas valve solenoids, or the high limit thermostat. Below is a video to walk you thru the diagnostic testing and repair.
Jan 03, 2011 | Roper RGS7646KQ Gas Dryer
Roper gas dryer will not heat. Igniter?
Well if your dryer tumbles, but there is no heat then you may please check out the following -
1. First of all you can check out for proper air flow - Check the vent for proper air flow by placing your hand over the exterior vent while the dryer is running. You should feel a strong flow of air. If not then check the lint trap. It is located either on top of the dryer or possibly just inside the door. Remove any lint that has built up in the lint trap. Cleaning the lint trap should be done regularly, even as often as after every load. Do not operate the dryer without a lint trap in place.
2. Secondly you can check out the Ignitor - gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes.
Post comments for further help or information.....
Good Luck!!
Thanks for using FixYa!!
Sep 10, 2010 | Roper RGX4634KQ Gas Dryer
No Heat. Burner shuts down after a minute or so.
You will find a limiter usually on top of the burner with two wires going to it thast needs to be replaced. to check it jump the wires and start the dryer be sure to tape the wires to b prevent a short, Thats almost always i. also check the two coils on the burner ussualy the first burner.
Apr 22, 2010 | Whirlpool LGV4634JQ Gas Dryer
Gas dryer does not get very hot.
the dryer dries after two or three tries
Dec 29, 2009 | Kenmore Dryers
Dryer burner does not kick on every time that I use the dryer. If I hear the heat kick on, the clothes will dry, but if the heat does not come on, the clothes will tumble on just a cold air dry and the...
Replace both coils on the burner valve . After heating up , they will not open to let gas thru again until cooled down for a short period of time . With no heat , timer will not cut off unless set for timed dry .
Aug 09, 2009 | Maytag Dryers
Dryer heats up and then stops heating
My gas one just did this. I tested the fuse myself located on the side of the lint trap. It was fine using my electrical tester. I then took the 2 coils off which are easy they are located on the burner. 2 screws removed the plate under are the 2 coils. Took them to ACE hardware were they tested them. The 2 prong was stuck in the open position. The three prong was fine. , I still replaced both and it works great now. What happened was the burner would kick on then when it hit operating temperature it would shut off. Then when it needed to kick on again the 2 prong being stuck in the open position wouldn't ignite burner again.
Jun 22, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Gas dryer not heating
REPLACE THERMAL FUSE #3392519 AND CLEAN YOUR VENTING GOING TO WHERE
IT EXITS THE HOUSE.
Jan 13, 2009 | Roper RGS7646KQ Gas Dryer
Heats up once after initials start.
HI the problem you have is with the 2 coils on the gas valve. replace the coils and clean out the lint in all vents thanks the appliance doc
Aug 04, 2008 | Roper RGX4634KQ Gas Dryer
Heat to start, then no heat..
replace both coils on gas valve ..those are the blacks things with wires attached they are bad for not pulling valve oper=n after warm up
Jul 02, 2008 | Roper RGX4634KQ Gas Dryer
My gas dryer only heats up the first time...
replace both coils on the gas burner (the round black dohickeys)after first ignition they tend not to pull valve open next time heat is called for
Jun 06, 2008 | Hotpoint NBXR463GBWW Gas Dryer
Roper RGX4634KQ Gas Dryer Logo
144 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
