Subwoofer not making any sound and a red light is showing up on the amp labelled prot. its a jucie amp JA490. Whats the problem???
    Scholar:
  • 47 Answers
Hi nexanutter,
On almost any amp, they go into protected mode when they have detected a short somewhere. When a speaker is involved, it usually means that the "+" wire and the "-" wire are touching somewhere between where they are connected at the amp and where they are connected at the speaker. This can also mean that the wire might be cut or pinched somewhere along the way, like by a piece of furniture or when the wire is pushed under a piece of moulding to be hidden. Often, it can be a single strand of one wire touching the connector of the other wire at the "lug" or connecting point.
The easiest way to test for shorts is to disconnect all your current speaker wire, then run a new set of "test wires" (you can move the speaker close to the amp or do whatever you need to do to make it easy for you to get to both sets of connectors. Since this isn't permanent, it doesn't need to be pretty, but make sure that no part of the "+" wire touches the "-" wire, especially where the wires connect.
Good luck, and I hope this is helpful. Please let me know how this works, and if you feel it is appropriate, I would appreciate you posting a rating for me.
Bob
Posted on Oct 16, 2008
Can't get cable sound to run through surround sound
You would have to have a cable box, from the cable box, you would hook up the yellow to your tv, and then the red/white audio would go to the subwoofer on your DVD765 where it is labeled (TV), you then hit the switch on the subwoofer to TV. Another option is if your TV has audio output, you could just run RED/WHITE audio from your tv to the back of the subwoofer where it is labeled (TV).
Jan 30, 2013 | Coby DVD765 Theater System
Overload light on can't get any sound
here is your guide:
http://www.fixya.com/support/t13907270-sony_str_de925_stuck_in_protect_mode
Note : output transistors are embedded inside the Hybrid IC
on some models.
Aug 07, 2012 | Technics Audio Players & Recorders
Light stays red, will not switch to green. I hear no sound from the subwoofer
Red Light Constant On - Means the Amp Is Not Turning On - Signal Problem or Most Likely Burnt / Non Working Components - There Is A Guy On Ebay Who Repairs these amps.
Jun 19, 2011 | JBL Venue SUB10 Subwoofer
When i turn on my Samsung HT-C550 IT showing PROT and DVD turn off. What this is mean PROT?
PROT means that the AMP is protecting itself from damage due to bad or incorrect wiring or damaged and or incorrect speakers. Check your wiring and speakers.
If you find no problem then, DISCONNECT YOUR SYSTEM FROM THE POWER, disconnect your speaker wires...all of them, then reconnect the power ONLY, turn on the system and see if it still says PROT. If it does then your amp is damaged.
Feb 20, 2011 | Samsung HTC550 Theater System
Marathon 2000 amp... PROT light
Ok this means the AMP is in protection mode!..most likely the cause is a short in your wireing from the speaker wires! check all wires going in and out of amp! Look for stray wires touching metal or other contacts! (If this does not fix it the short may be inside of amp!
(This has nothing to do with a fuse!)
Please rate this FREE response!
THANK YOU!
Jan 19, 2009 | Marathon DJ-2000 Amplifier
RED Port light on AMP?
are you sure its not PROT?
the amplifier is protecting itself from fire because of something.
Disconnect the subs. and turn on.
if it comes on normally, the subs are at fault and will need attention. If the light still stays on, you hafe probably blown an output on the amplifier and it will need repair.
Dec 24, 2008 | Sony XM-2200GTX Car Audio Amplifier
Powers on but no sound
Check the main amp fuse under the hood, even if it looks good just change it. Often times that light on the amp can come on just from the power amp tunon wire. Try a friends subwoofer box just to make sure the connectors on your box are good, and if that doesn't work then give me some more details....year/make/model of car, what kind of sub, what types of things do you see on the side of the amp....is there a green light as well as a red light?
Aug 18, 2007 | Xtant A3001 Car Audio Amplifier
Orange light
I have the same speaker and it sounds like its behaving properly.
if you look on the back of the amp, you will find a switch that allows the speaker to automatically switch the speaker on or off based on the level of the audio coming from the tuner that it is attached to. If the switch is set to the auto mode, then it will listen for audio on the line and if the signal level coming into the subwoofer is high enough, the amplifier in the subwoofer will turn on and play. If the signal is not strong or loud enough, then the subwoofer will not turn on. There are two solutions to getting the speaker to work.
1. When you turn on the tuner or audio source that is feeding the Subwoofer speaker, you will need to turn it up loud enough to trigger the circuit in the subwoofer to switch on.
2. Alternatively, you can bypass the automatic circuit and set it to the "ON position all the time. In this position the subwoofer is always ready and waiting and should play any signal that is fed to it regardless of the loudness or volume of sound from the tuner. The switch is located on the back of the speaker cabinet just to the right of the red and black speaker wire connections. It is labeled "AUTO" and the switch positions are labeled ON and OFF.
Hope this helps!
Jul 09, 2007 | Acoustic Research S112PS Subwoofer
110 people viewed this question
 Grubhead
Grubhead
