Question about Indesit W 123 Front Load Washer
Indesit W 143 S UK Sounds
My machine sounds like its gonna take off. is this the bearings? how easy are they to change?
Thanks
Pady
  • monkimagic Oct 18, 2008
    Thanks mate, but why are they a pig?
Bolts holding spider in are fixed with loctite. only way i found of releasing them is to use heat. it is a lengthy nasty job all round
Posted on Oct 18, 2008
    President:
  • 1,462 Answers
Either bearings or a foreign object in machine
bearings are a pig to replace on this machine
Posted on Oct 16, 2008
Hi my machine is really loud sounds like is gonna smash in to bits when spining also when empty if you spin drum with hand feels like its rubbing on something ??? my question is is it worth repairing cos...
Is your load evenly distributed when spinning? The drum will not spin freely when empty and pushed by hand so don't worry about that. Run a full cycle on empty to see if it still makes the noise. If so you probably need a visit from the repairman.
Feb 02, 2018 | Indesit Washing Machines
Indesit W123 drum not moving. Will turn freely and quietly both directions if spun by hand. Sounds like going through cycle and dial turns as is going through programme. Made a whirring noise when ini
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jan 20, 2013 | Indesit Door Handle Kit for W123, W133,...
Indesit WIXL 143 washing machine noise
there maybe a coin or something stuck between the two drums, when the machine spins fast it lifts the item up, unplug the appliance and remove the botton drum hose to see if you can get it out.
Apr 05, 2010 | Washing Machines
Sounds like the bearings on my W63T are noisey.
take my advice ;even for an expert this is no easy job, the bearings you refair to are pressed on useing a hydraulic press so removing them is not easy if i were you i would forget this one.adrian
Feb 27, 2009 | Indesit W 123 Front Load Washer
Bearing noise on Indesit WDG1295
you will have to open the machine lid to see if its a plastic drum or metal.
the metal drum is easier as it has a 'spider asssembly'. remove this after taking off the pulley by taking out the bolts that hold it and bang it off being carefull of the heater element. remove the bearings and seal and refit in reverse order you took it off.
i would not advise replacing plastic drum bearings as they are a pain, removal of the rear of a plastic drum easy but not putting it back !
Feb 01, 2009 | Washing Machines
Indesit 15 60v uk tumble dryer . there is a banging sound like that of a loose drum in a washing machine . i have taken off a grey plastic cover at the back and can see a lot of black dust inside. ser no...
is60v bearings We have made a few videos on these dryers and there are some very good repair guides on these.
if you need parts please feel free to see site or contact me with the full model number of the ID plate How-to-Repair
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair Need help fixing your appliances Need help fixing your appliances
Dec 10, 2008 | Dryers
Indesit wil 143 washing machine
It is automatic half load you dont need to do anything.
Oct 04, 2008 | Indesit W 123 Front Load Washer
Indesit wash machine drum bearing
depends on the model that you have some indesit machines you only have to undo the spider and others can be a bit of a pain because you have got too split the drum would recomend an engineer regards jason
Jun 13, 2008 | Indesit W 123 Front Load Washer
Indesit W123s
There is a bearing at the back of the machine that normally goes.don't just replace the bearing.buy a complete bearing kit and replace that.
Feb 23, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
299 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
