Question about Baby Gear
Dealership... Dear Sir, I am interested in taking up dealership for Nano Car in Gujarat. I am a bussiness man dealing with industrial generators well experienced in Engines of different makes. I am also an Advocate. I would like to have your requirements to become a competent dealer. Hope you will consider my application and suggest me with tips Now i look forward to have your feedback at the earliest. Thanks & Regards Kamlesh M. Chodvadia +91 9825413211
How to Buy or Lease a Car when You Have Bad Credit?
YOU go to a reputable dealer like..car hop and have a descent amount of cash for a downpayment and thers shouldnt be much hassle.. Now, your interest rate on the loan may be as high as 27% depending on yoir credit situation. MAKE SURE THAT THE DEALERSHIP YOU DEAL WITH IS ACCREDITED WITH the BBB! Good luck, hope bis helps
Oct 20, 2016 | Cars & Trucks
I am going to buy a car, and I am thinking of taking a loan at a bank, but wonder what was best: whether to take the loan at the dealership or at the bank itself. Do you think banks are offering nice
Generally, if you're buying a new car, a bank or even a credit union can't come close to the low interest rate you can get at a dealership. Bottom line, go with whomever offers the lowest interest rate.
Aug 07, 2014 | U.S. Bank Green Auto Loan
Ombudsmen i need help with more information about bad service and dont know how to get hold of a ombudsman in amanzimtoti durban
There are two ways of approaching it- if it is a dealership then they will be RMI registered. This is the Retail Motor Industry. It acts as the watchdog over the motor industry but had little clout if it is a smaller company who is not registered.
The other route to go is to try escalate your grievance within the company until you get to someone who can make a decision. We often deal with the man on the ground who is merely a puppet!
Failing that, it becomes a legal battle which could cost a fortune and never achieve much. It does help to know your rights with regards to the CPA and if anything there is relevant for a bit of leverage.
Email me on wayne.wep@gmail.com and lets discuss your problem and maybe I can advise as to a route of action.
May 15, 2014 | Cars & Trucks
- A Toyota dealership in Virginia sold a 2005 Range Rover HSE. I noticed a flickering battery light and within a week the vehicle navigation and radio display reboots several times while I was driving....
These are complicated cars but these guys are just trying to run out the warranty on you. By suggesting you drive the car, they want you to take delivery of the vehicle, and as you said, you cannot register thus you cannot drive it. If they wanted to help you, they would have one of their own drive the car for 500miles and then check it.
If you want to continue with the purchase, have them write out another 30 day warranty for you then you will know they are genuine.
Have them refund your money and look for another car if you feel that this is not for you and they refuse the deal. At the end, the dealership is out for profit and you are not profiting their business, so be very cautious.
The good thing though is you can always find another car that is less problematic. Range Rovers are expensive cars to keep when they are problematic.
Hope that helps you.
G.
Feb 20, 2011 | Emission System for Land Rover Range Rover...
I have a 2003 vw passat turbo the dealer said it needed a coolant flush due to sludge. I paid $75 for flush, then they said need diagnostic another $79. After they said oil cooler leaking. How do I know if...
Switch mechanics. You can get free diagnostic from parts stores. If the oil cooler is leaking, you will see it--and $450 is too high. The part is less than $100!!!
Oct 22, 2010 | 2003 Volkswagen Passat
Transmission/Oil Leak
Your transmission cooling line was rubbing because the radiator support was pushed rearward in the collision. If indeed the dealership did do the necessary repairs, than there should be no problem. I'm assuming they got a great deal of cash from the insurance people and used it wisely. However, your problem has not been solved and there is no reason for you to be going through this mental anguish. You might try a quick fix until you bring the vehicle back in. Take a large cable tie (found at all hardware stores) and tie off the line that is rubbing to one side away from the belts. Usually there is another fluid line nearby at which point you'll be able to anchor the line at fault to the one further away. Get that vehicle back to the original repair place and mention the words "Attourney General" in your discussion, that will expidite your repair. Thanks, Dana
Feb 10, 2010 | 2008 Dodge Charger
Potential remanufactured engine
Hey man, here's the thing.. Dealerships always tell you to take your car to them for service because they record everything done to a car so in times like this you could just look the info up..
but..
For instance.. My timing belt broke and ruined my engine so i took it to my best friends import tuning shop and had him do an engine swap, no big deal, altho my receipt from his shop is THE ONLY way anyone would ever know that i swapped unless i told them. I did the right thing and had it added to my car's "history" when I replaced recalls at the dealership but even the dealership couldn't tell my engine was not the original and your dealership COULD tell, so man.. you need to contact the ppl that sold you the car, because lawfully you are due a refund or at the very least an intense history report of when they or any other previous owners had the car. Also the dealership is completely correct in that there is definitely a code on that tab coming off the cylinder head.. and if it has been milled off, it was milled for a reason, to hide something obviously so contact your previous owner (get it off the title if you forgot who they are) ask them everything they know about the engine, you'll be able to tell if they are honest.. and if they know nothing, then next step is contacting the shop that changed the timing belt and tell them you want answers to what happened to your "original" engine. This is a tough one..
Good luck
Mar 15, 2009 | 2003 Volkswagen Jetta TDI
Norms of tata nano dealership
Respected Sir,
This is Praveen from Chickaballapur(karnataka) I am interested in Tata Nano Dealership.
I have my own land on around 15000 sp ft.
Please reply me with the procedure for application on my mail.
It is praveen.ys2004@gmail.com
Waiting for favorable reply.
Thanking You
With best regards
Praveen
Ph - 9886446806
Feb 16, 2008 | Baby Gear
Printer Is Not Printuot
I can solve it through instructions my email is syedimran555@yahoo.com.
Nov 07, 2007 | HP LaserJet 2200dn Printer
Baby Gear Logo
18 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
