Question about Sharp AR-C270 Color Copier
IP Address on a Sharp AR-M237
How do i figure out the IP address of my sharp AR-M237?
  • Anonymous Mar 24, 2014
    do you know the ip address of the Sharp mfc ar-m450
  • Sharp Master
  • 2,794 Answers
The easy way to do it is to set the copier up for AUTO DHCP.  That way the copier will connect to the router and assign a free IP address to the copier.
Then go into internet explorer and type in the ip address of the copier.  If you can get a control panel screen of the copier to appear.  It worked.
Once you get the IP address, take it off of AUTO DHCP and type in the IP address that the router assigned to the copier.
Posted on Oct 16, 2008
En la fotocopia dora me aparece llame al servicio tecnico COD.U2-40 y no me saca copias copiadora es SHARP AR-M237 AYUDENME
Hola buenas tardes, me podrian ayudar tengo una copiadora sharp ar m237 y me esta marcando el codigo U2-40 y no se que hacer alguien pude hacesorarme
Jul 20, 2011 | Sharp AR-M237 Copier
Attempting to print to my Sharp ARM237 Network printer. It gives me the error Unable to access server. Check server address on device web page" . It used to be networked then I moved the loacation...
you must put the right IP adress for the machine: from the menu
  1. choose system setting
  2. Network settings
  3. IP address setting
  4. copy the the ip adress from your computer and type it in the special field
Dec 06, 2010 | Sharp AR-M237 Copier
How do I change the IP address for the scanner on a Sharp AR-M237 multi function
Custom Settings/Admin mode/ passworrd 000000 print settings/ network settings
Aug 27, 2010 | Sharp AR-M237 Copier
We cannot scan to email from our Sharp AR-M237 Multi-function "Error[973]: Incorrect format for Primary SMTP Server." I am using all the settings for SMTP that I use everywhere else. HELP?-pjm
Model AR-M257 - I have several Sharp MFP devices at different locations and all are set up to scan through our email server using a special account I have just for this purpose. I have all of them setup using the external IP address of our Exchange server (not its name or FQDN) and I have firewall rules setup to allow SMTP from the WAN IP addresses of our different offices to the LAN IP address of the Exchange server. It worked at all the others but this one. I was getting the following error when trying to send a status message (under Log) from the device to my email account as a test: [error 973] incorrect format for primary smtp server. And when I tried to scan through our email server I would get "network error". However, a connection test succeeded. I had everything set correctly for SMTP and DNS but as I was trying anything I could to get it working I went to mDNS under Services and it was enabled. I disabled it and then I could get a status message to be sent to me and we could send a scan through our email server.
Apr 12, 2010 | Sharp AR-BC260 Color Copier
Sharp AR-M237 EXPANSION MEMORY 8MB: AR-MM9 installation procedure
You are needing the installation manual for this. Please contact me so I can e-mail you the pages that you need. administrator@aokoffice.com
Oct 08, 2009 | Sharp AR-M237 Digital Copier
Sharp ar m237 assigned static ip address
You can print the configuration data by Simulation 22 sub 6.
This is how to :
1) #/P key (program) ON → Asterisk (*) key ON → CLEAR key ON →
Asterisk (*) key ON → Ready for input of a main code of simulation
2) Entering a main code with the 10-key → START key ON
3) Entering a sub code with the 10-key → START key ON
4) Select an item with the scroll key and the item key.
5) The machine enters the mode corresponding to the selected item.
Press START key to start the simulation operation.
To cancel the current simulation mode or to change the main code
and the sub code, press the CUSTOM SETTINGS key.
* Canceling the simulation mode to return to the normal mode
1) Press CLEAR ALL key.
Mar 11, 2009 | Sharp AR-M237 Digital Copier
I need to change the IP for my ar-m237
Try to increase the router range to include the ar-m237 or change the copier to a lower IP address within the range of the router.
Jan 03, 2009 | Sharp AR-M237 Copier
How can I get a meter reading from an AR-M237?
press and hold the the button that says "copy" on it next to the screen, the meter should show on the screen
Dec 05, 2008 | Sharp AR-M237 Copier
Sharp AR-C270 Color Copier Logo
1,763 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
