Question about Philips 50PF7320A 50 in. Plasma HDTV
Philips plasma tv. has green line on left side of screen.
In hdmi mode there is a green line on the right side of screen. pix is ok in other modes
  • drmarkm Dec 31, 2008
    i have a 42" philips and it does the green vertical line on the right. it did it with an hd dvd player (now returned) via hdmi and with my new magnavox blu ray player via hdmi. strangely, no green line with my comcast cable box via hdmi.
  • Bob Abaya Jul 14, 2013
    I also have a greenline on the right side that only shows up when I'm watching HD programming. It totally goes away during regular HD programing or when I watch a DVD (even blu ray). Any advice???
Using your TV's remote control press the right cursor button three times and it will adjust the Screen to the right and the green line will disappear. Use the left button if your green line is on the left.
Thanks to:
Posted on Nov 25, 2010
  • 3 more comments
  • mnmtitus Nov 26, 2010
    DOH! This really worked!!! Thanks! The fit to screen option was not in my menu, you really just hit left on remote.
  • mlupardus Nov 30, 2010
    You all rock! I thought my TV was on it's last leg. Really appreciate the help. Happy Holidays!
  • ryan cain Sep 11, 2012
    That fixed my problem!! awesome !!
  • Anonymous Feb 10, 2017
    Worked thanks for your help, Philips chat support was useless suggesting changing HDMI cables, downloading updates blah blah blah!! you are awesome!!
  • Andrew Fingerson
    Andrew Fingerson Jan 21, 2018
    OMG this totally worked on my Philips 26PF5321D. I was going crazy trying to find a fix to this!
OMG Thank you! I was going CRAZY going thru the menus and it was such a simple fix. SO APPRECIATED!
Posted on Dec 08, 2012
How do I fix my LED TV that has horizontal lines
How old is the LED TV Shaaz? It could be going bad
Jul 12, 2016 | Sony BRAVIA Televison & Video
How to fix LG TV Vertical lines.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 30, 2015 | LG 47LA6200 47" 1080p 3D Smart TV 120Hz...
Sanyo dp42848
That sounds like a Tcon board issue. You can get the Tcon board from
Oct 19, 2012 | Sanyo DP42849 42 in. HDTV
Does my tv have audio outputs?
42PG20 Connections
  • Connector Type
  • 1 x Composite video/audio input ( RCA phono x 3 ) - Rear ,
  • 1 x S-Video input ( 4 pin mini-DIN ) -
  • Rear , 1 x Digital audio output (optical) ( TOSLINK ) - Rear ,
  • 1 x Remote control ( Mini-phone 3.5 mm ) - Rear ,
  • 1 x Serial ( 9 pin D-Sub ) - Rear ,
  • 2 x Component video input ( RCA phono x 3 ) - Rear ,
  • 2 x Audio line-in ( RCA phono x 2 ) - Rear ,
  • 2 x HDMI input ( 19 pin HDMI Type A ) - Rear ,
  • 1 x VGA input ( 15 pin HD D-Sub (HD-15) ) - Rear ,
  • 1 x Audio line-in ( Mini-phone stereo 3.5 mm ) - Rear ,
  • 1 x Composite video/audio input ( RCA phono x 3 ) - Side ,
  • 1 x HDMI input ( 19 pin HDMI Type A ) - Side
42PG20 Audio System
  • Sound Output Mode Stereo
  • Surround Mode Yes
  • Sound Effects SRS TruSurround XT
  • Audio Controls Bass , Treble , Balance , Sound mode
  • Speakers Included 2 speakers
  • Output Power / Total 20 Watt
  • Additional Features Auto volume adjustment
  • Speaker(s) 2 x Right/left channel speaker - Built-in - 10 Watt
Feb 04, 2011 | LG 42PG20 42 in. Plasma HDTV
When connecting ps3 to Hdmi tv via hdmi lead or av connection ,ps3 is powering up ok but error message appears on tv screen saying game mode not supported.
hello,,when you connect a hdmi you have to into the menu and select hdmi this should give you a 1080p picture mode
Oct 08, 2010 | Sony Playstation 3 (PS3) Console
"no signal" showing on tv screen
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 29, 2010 | Sony Playstation 3 (PS3) Console
Blue vertical line at reght side of screen
This is normal. Depending on what you have connected to it the lines could be white, black and white specs, or green. Just mode will show the entire picture event the parts that aren't supposed to be seen. I would not recommend that setting. Full is the best mode if you want to see the entire picture in the correct ratio.
Apr 24, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Picture problem on Toshiba 42inch WH36 series
These capacitors are on Hyper Board. You have to replace in order to fix the problem. See the link:
Apr 17, 2017 | Televison & Video
Can't change channel
Most remotes have the source button at the top right hand side all the top left hand side it should be called sauce or it might just have three lines if you have a black lever on the right hand side then you need to press that in and wait it should put you to the av screen then if you let go you can press down or up that will let you chose av or video of hdmi ok if you want to send me a pic of the Tv so I could help you more if you can't find it I don't mind ok
Jul 10, 2017 | Toshiba Televison & Video
Philips 50PF7320A 50 in. Plasma HDTV Logo
4,087 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
