Question about Casio Watches
Casio module no. 2524 watch. The 10 year battery don’t work.
5 Suggested Answers
SOURCE: Casio spf 40 Module 2273
Your Watch is in Auto or demo mode. Hold down the "Mode" button for 3 - 5 seconds and it will return to time keeping mode.
Cheers,
Murray
Posted on Dec 29, 2007
landsend
  • 1066 Answers
SOURCE: dive watch battery replacement
a local jewelry store or Walmart. while you wait.
Posted on Apr 03, 2009
  • 183 Answers
SOURCE: Changing the battery on My Casio watch module 1848. Two
The contact springs most likely have nothing to do with your screen being black.
The watch will have an "AC" or all clear function that needs to be performed. Check the back lid for AC or reset instructions. If there are no instructions there then you will have to visit a watch repairman/technician to have this procedure performed as it involves touching the AC pad on the circuit board to the back of the battery already installed. The circuit board is easily damaged if not performed properly.
Posted on Sep 17, 2009
  • 2501 Answers
SOURCE: I have a casio illman...watch wr-50.. its a
Go to the Casio site "casio.com".
Select "support", then "manuals", then "watches",
Accept terms and conditions,
Then select "watch manual archive"
enter the number off your watch and click on "search"
Posted on Jan 18, 2010
news775
  • 699 Answers
SOURCE: how do you remove a
Have a look at the links nearest the clasp.
These should have markings on to say which are removable. An arrow or some other indication.
Not sure if this watch has press pins that go through the whole bracelet or flip up catches on each band.
Please dont forget to vote this answer was helpful.
Many thanks
Posted on Mar 01, 2011
CHANGE TIME AT CASIO TOUGH SOLAR
Today my 6-year old Waveceptor has adjusted itself to daylight Savings time without my intervention. I was agreeably surprised. For all the years I have had the watch, I kept the module manual by my side just for the two times a year I have to adjust the time.
All this to tell you that you imperatively have to read the module's manual. If you do not have it visit the Casio Worldwide web site and download it. You need the module number. You will find it on the back of the watch. It is a 4-digit number inside a rectangle.
Apr 01, 2013 | Casio watch Casio Tough Solar Mens...
GW-1500A Casio has to be sunlight every day otherwise it stops
Hi gregbrands,
If your watch is several years old, I would recommend sending it back to Casio for service and battery replacement. Contrary to what you may hear about solar-powered watches, the rechargeable batteries do not always last for 10-20 years. I've seen some go out in 2-3 years. This is a shorter lifespan than most standard lithium watch batteries.
You may have an authorized Casio service center near you also. If not, contact Casio at the following numbers:
For Repair support in USA at 1-800-706-2534 during regular business hours (currently Monday-Friday 9:00a.m. - 5:00pm EST, Saturday / Sunday 10:00 a.m. - 8:00 p.m.) For Technical support in USA at 1-800-435-7732 during regular business hours (currently Monday-Friday 9:00 a.m. - 8:00pm EST for all products, Saturday / Sunday 10:00 a.m. - 8:00 p.m)
The cost of your watch well justifies this kind of service, plus, they will assure it remains waterproof up to its specifications.
Let me know if I can help further.
Thanks, Bill
Sep 15, 2010 | Casio GW1500A-1AV G-Shock Atomic watch
Changed battery .A square piece of metal the size of match head fell out. No alarm or light, casio forester FT200
mcdevito75 here, Of couse without the watch and piece of metal that fell out it"s very hard to say. Most likely it was part of the lock-down tab to keep the battery in place, in any event don"t lose that piece of metal. If your casio is working ok don"t worry about it, just don"t lose that piece of metal that fell out.
Jul 05, 2010 | Casio Forester PAS400B-5V Wrist Watch
I have a casio illman...watch wr-50.. its a telememo world time 3 alarms countdown ith a 10 year battery...i need the instruction on how to set the watch
Jan 18, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
Casio 81cs-36 watch
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
May 02, 2008 | Casio Black Casual Sports Watch W7521AV...
Alarm
Apr 11, 2008 | Casio Black Casual Sports Watch W752D1AV...
Casio pro-trek PRG-60T Buttons no longer activate anything.
Send it into repairs and they will send you an estimate on what it would cost to fix it. Give them a call at 800-706-2534 option 2.
Feb 19, 2008 | Casio Triple Sensor Pathfinder PRG60-1AV...
Cheers,
Murray
Nov 19, 2007 | Casio PRG-40T-7 Pathfinder
Watches Logo
386 people viewed this question
Top Casio Watches Experts
Jimmy Accardi
k24674
Are you a Casio Watch Expert? Answer questions, earn points and help others
