Question about Canon MP610 Photo All-In-One Printer
Cartridge cannot be recognized
I have refilled the ink cartridges both black and colour and placed in the printer ......it says cartridge cannot be recognized..........what should i do......
  • 76 Answers
What happens is the counter is stores on the cartridge chip so the chip still thinks they are empty. The only way to get round this is to put orginal canon cartridge in the machine or swap over the chip from a working one.
Just to let you know refills are cheap and easier but they can cause more damage then you see inside the machine such as printhead and purge unit.
If you change the cartridges with new chips it will then work
hope this helps
Posted on Oct 21, 2008
I have refilled the colour and black cartridges and the printer is not recognising the colour cartridge is refilled what can I do
A step you can try is to take a piece of paper or paper towel and wrap the color cartridge in it and then vigorously shake it.
Essentially what you are doing is forcing the ink to the bottom of the well and this way the sensor inside the printer will recognize ink. If this does not work you may need to disassemble the printer and clean out the heads where the ink cartridge fits.
Jul 24, 2011 | Lexmark C533DN InkJet Printer
How to refill hp deskjet 1560 black cartidge
Hi
check here
Pls vote us to keep us alive
Nov 09, 2010 | Office Equipment & Supplies
Reset the ink memory level after replacing cartridge
Have you tried to unplug your printer and plug it back in?
May 31, 2009 | Dell 962 Photo All-In-One InkJet Printer
Canon ip1200 black cartridge wont recognize after i refill
Dear lim,
Here a solution for you. The cartridge of this printer has memory chip that store ink level data inside. Once the cartridge is empty we cannot restore ink level data to be full. To continue using refilled cartridge you need to deactivate ink level detection function first. Perform this step: when the message 'The following cartridge cannot be recognized' appears press Resume/Cancel button. Do this for each cartridge you refill;if you refill both black & colour cartridge do this tip two times (once for each cartridge).
Please rate this as fixya ok.
Regards,
Dec 02, 2008 | Canon PIXMA iP1600 Printer
Printer says ink cartridge not recognized.
Take the black ink cartridge back to the person who refilled it. The Microchip that's on the cartridge was not reset properly that's why the printer is returning that error.
You can try some steps before you take it to them to verify it.
1: reseat (take out and put back in) the cartridges into place
2: buy another black cartridge just to check if it will be recognized by the printer, if it does recognize it we know the cartridge is defective. If a new cartridge is also not recognize, start to check your warranty option with the manufacturer...
Sep 05, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Refilled ink cartridges
The reason why the printer says supply expired because the ink cartridge has its own warranty. When the warranty of the ink cartridge has expired then you will get that message. Eventhough you refill it. You need to replace the ink cartridge itself.
Aug 04, 2008 | HP OfficeJet D125xi InkJet Printer
Canon pixma ip 4200 printer problems
in the printer driver there is a option that whenever you install a new cartridge it has to be reset otherwise it shows the message the above you quoted. one more option is there that is change the chip of yellow cartridge and black, after doing this please whip circuits of the cartridge and printer carriage block before installing the cartridge
Apr 15, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
I want to refill the ink cartridges (black 30 - colour31) myself....how do I do it?
Filling is easy - but messy. I use No 40 cartridges for my pixma ip2200.
For the black cartridge, carefully remove the label. Drill a 2-3mm dia. hole in the depression in the top. With a syringe fill, using about 10ml of black ink. Plug the hole with a suitable bung and away you go!
You will however lose the ink level indication as it is not a genuine cartridge - but that is unreliable anyway.
Don't refill more than a couple of times as the foam inside the case eventually perishes and all the ink runs out.
Whilst the cartridge is out of the printer give the jets a wipe with a wet tissue. This is usually quite effective in removing dried on ink.
You can do the same with 41 colour cartridges but it is a bit more tricky locating the correct place to drill.
Good luck
Apr 10, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Canon MP610 Photo All-In-One Printer Logo
124 people viewed this question
old marine
old marine
