HP psc 2110 all in one: check and remove cartridges (error)
I have a hp 2110 all in one printer.For some reason it keeps telling me to check and remove cartridge. I have done this half a dozen times. no matter what I try nothing seems to work. I've uninstalled and re-installed the software, nothing works. I've cleared the memory, shut it down, unpluged it I'm at a loss as to what to do. Have you any ideas. Thank you
  • go_4_it Oct 16, 2008
    it gave it to me when old cartridges were still there, like all of a sudden. I removed the color cartridge (which was already empty) and that apparenty fixed the problem. However, the same note (check and remove cartridge) appeared the following morning...
  • Fran Bednar
    Fran Bednar May 11, 2010
    Did you change a cartridge that caused this note or did it give it to you when old ones were still in there ?
    Novelist:
  • 159 Answers
Usually it will give you that note right away and not wait till morning !!??
Try this if you haven't already.
open the lid so the cartridges center. unplug the power.
Take out the cartridges, use a clean cloth with a touch of water to clean the back of the cartridges where all the contacts are and do the same inside the cardridge carriers. Then do it again with some denatured alcohol. Make sure it is all dry then reinstall them making sude you here them click into place.
power in back up and you'll have to run the align cartridge utility if it doesn't do it autoomatically. Then a print test page.
good luck
Fran
Posted on Oct 16, 2008
Hp psc 2110
hello, let me start by asking a question giving a few tips. Hopefully things will work out.
First, you said, "you have replaced the cartridge. "
Did you just replace it?
Remove the cartridge and make sure you take off the little sticker tab the covers the print head. I have had many customers over the years that have made this simple mistake.
If this is done. I want you to place the ink cartridge back in properly.
Next power off and unplug your printer.
Wait about 1 minute and plug back in a power back on.
at this point and time it should ask you to do a new new cartridge printer alignment calibration page.
If it does not prompt you to do so please refer to your manual on how to manually do one.
If you do not have your manual let me know. I can do further research and help you with that too.
More that likely this simple procedure will reset your printer and help it recognize there is a new cartridge placed in the machine.
hope my advice helps .. if you appreciate my help lease remember to leave a good rating and a testimonial.
If problem is unsolved please write back for more problem solving.
Mar 28, 2010 | HP PSC 2110 All-In-One InkJet Printer
Installing a new black ink cartridge and i keep
chech the part number of your cartriges, and also the expiration date for both cartridges
Mar 17, 2010 | HP PSC 2110 All-In-One InkJet Printer
Won't print: "remove and check color cartridge"
remove your new color cartridge and make sure you have removed the safety tape on the botton of the cartridge.
Mar 07, 2010 | HP PSC 2110 Color Printer
Print cartridge will not align
This could be an issue from remanufacturing. Try a new cartridge from HP.
Many manufacturers have hardware in the cartridge and the printer that tell the printer "new cartridge". When a cartridge is refilled, you can have that giving a "bad" message.
I wish that I could be of more help.
Feb 18, 2010 | HP PSC 2110 Color Printer
Put in new cart. in 2110 psc it says to remove and check cart.won't accept and operate
OPEN THE TOP UNIT.remove the cartridges .you can see metal contacts in the printer carrage unit.clean the contact with soft tissue cloth.
Oct 24, 2009 | HP PSC 2110 Color Printer
HP psc 2110xi all in one printer scanner copier
When I turn on the 2110 printer the scan light just keeps moving forward a small amount and to goes back to the home position. It will do this for about 5 minutes and then shut donw.
Mar 05, 2009 | HP PSC 2210 All-In-One InkJet Printer
Hp psc 2110xi all-in-one
In the below document read the section titled solution5:Remove and reinsert the ink cartridges
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&dlc=en&cc=uk&docname=c00042573
Sep 13, 2008 | HP PSC 2110 Color Printer
HP psc 2110 Printer keeps telling me to Align print cartridges. I follow the steps but it always comes up alignment failed and starts printing Instruction page all over again. I can print from my computer...
Press the cancel button. Then press the "setup" and top "copy option" buttons together to enter maintenance. Use the right arrow (right copy option) button to scroll through the options if you like, but then hit the cancel button to skip the alignment.
May 18, 2008 | HP Office Equipment & Supplies
Hp psc 2110
there are 2 catridges. You need to lift the top half of the machine (the rlease is wehre you put the paper in), the catridges will come to the middle position, then simply lift the clip and remove the cartridge
May 03, 2008 | HP PSC 2110 All-In-One InkJet Printer
187 people viewed this question
jasbo
jasbo
